Typical Tools for Particular Tolerances Table?
SPC_Newbie
Hi All,
I've been reading a lot about (and have conducted a few) Gage R&R lately and have noticed that even in a measurement system with very good Equipment and Appraiser variaition, we can still not meet acceptable % Gage R&R numbers if the spec is tight.
Along those lines I was wondering if some general guidelines, or even a chart, exisit that correlate machine shop inspection tools with tolerances that realistically can be measured, both for product specs and statistical processes.
We have Micrometers, Calipers, Height Gages, CMM's, 2 and 3 pt bore mics and such in our precision machine shop.
Our mic's have both resolution and accuracy of .00005 inches, (Mit 293-340), Calipers .0005 resolution, accuracy?
I realize in general we want 10 units of discrimination so I probably could take resolution and mulltiply x 10? I'm thinking it's not really that simple though.
Ultimately I'm looking to have a 'good feel' for what tolerances can and can not be measured per tool on the floor reliably for SPC. Our tightest part is +.0002, -.0001. Typical tolerances are +/- .005 and our key features are commonly +.001, -0 or +0, -.001
These include ID's, OD's and lenght & width.
I hope this makes sense and seems like a reasonable question - Thanks!
Michael_M
I am posting my reply as I 'think' I understand the requirement and if I post and am right or wrong I will find out.
If you are using 10x as your standard and are measuring a +/-.005 tolerance you have a total of .010 tolerance so the instrument needs to be able to accurately read .001 or better. Your tightest tolerance is +.0002/-.0001 leaves .0003 total tolerance so you need an instrument that can accurately read .00003.
Again, I am not absolutly sure on this myself, but this is my understanding.
Rameshwar25
Dear
Once you have selected right instrument for measurement i.e. with a least count of at least one tenth of tolerance, there are no chances your %GRR will not come below 10%. Sometimes, the range of three readings (assuming 3 trials), goes beyond UCLr, which can be seen in Range chart. If you re-check those observations and range of three readings comes within UCLr, your GRR% will be definitely come below 10%.
regards
rameshwar
SPC_Newbie
Michael - thanks for the reply, it's nice to see those 'getting involved' (like myself too!) taking a stab at it!
Rameshwar25 - Thank you also - That is an intersting assertion I have not had time to think through. I do however have some data that doesn't 'appear' to agree - of course it could be that I've messed up somewhere else.
I'm attaching what I've got. Maybe this part of the thread should be posted elsewhere as intuitivly I feel my Mic and the differences in results between (and within) operators SHOULD have been more than sufficient to measure a tolerance spread of .001.
Can anyone explain WHY I failed when 'it feels' like I should have been ok?
Thanks!!
(Please ignore stability and linearity tabs as they just have data from the original spreadsheet)
Rameshwar25
In s0me cases, your readings are in 5 decimal digits. e.g third trial of first appraiser for first part. May I know which instrument has been used in measurement? and what is the least count?
Rameshwar
N
NumberCruncher
Hi SPC_Newbie
Plot your results. Only sample 2 is clearly different to the others. With all of the other results, the total within sample variation as measured by your appraisers, is very large compared to the between sample variation. I don't have my GRR sheets immediately available, so I can't calculate the results from your data.
I will repeat this. Plot your data. Everything will become much clearer.
The ideal graph would show each sample with the spread of measurements. Each group of measurements would not overlap with the others in any way.
With your results, you can put a ruler through 5 of the 6 sets of data. Either you don't have enough variation in your parts, or your gauges do not have sufficient resolution.
NC
SPC_Newbie
Hi Rameshwar25,
They should all be 5 digits. The 5th got left off whenever it was a zero. I used a micrometer with both .00005 inch resolution and accuracy (Mit 293-340).
SPC_Newbie
Hello NC,
Thanks for taking the time to review my data and respond! I misread my xbar r by operator chart - it kind of looked like some 'R chart by operator' graphs so I thought it was close to OK. Upon review I see I don't have 50% of the points out of control.
I don't have enough variation in the parts as they are running very near the LSL with sample 2 a little too low but these are the parts that we are producing in our precision machine shop. Maybe I'm running into issues with what should be non uniform data??
If I don't have more variation among the parts am I in trouble as far as running a GR&R goes? Some notes I have say that for product acceptance 'Part Variation is not part of the calculations so ranges need not be spread across the tol range.' As far as for statistical purposes (SPC) my notes only say 'std dev of selected parts should match std dev of process when practical'. These notes are my interpretation of what Miner says is nec for part selection in 5a of his Intro to MSA series.
I chose this part and dimension because the spec tolerance range was .001 and it was easy to get a mic on it and I wanted to see what kind of numbers GR&R wise we would get. I have done GR&R before but only from a 'fill out the spreadsheet' perspective as a test engineer. Now I'm at a new company and a first time QE and need to really understand MSA.
Thank you!!
N
NumberCruncher
Hi SPC_Newbie
GRR is really simple. "Can you measure what you are making?"
As I said in my previous post, I don't have access to my GRR sheets at the moment, so I can't give you a quantitative answer to the above question.
But if your sheets are telling you correctly that the %GRR is poor and the NDC (number of distinct categories) is less than 5, then the study hasn't failed. It's done it's job correctly. It's telling you, "No, you can't measure what you are making."
If all you need to do is weed out the odd elephant from the mice (a truly surreal metaphor!!) then this is ok. You can detect big changes.
If these parts are truly representative of your process, and you need to detect small changes in the output, you probably need a better measurement system.
This new measurement system might only involve operator training to reduce the between-operator variability. It might involve new equipment.
But here, we're getting into territory that is outside of the GRR study. Before making any expensive decisions, you need to be totally confident that your study is good. It would be more than a little embarrassing to make expensive, wholesale changes to your systems only to find that your initial study was flawed in some way.
Arguing that, someone on the internet looked at graphs of the data and said the measurement system was rubbish, probably won't work as a defence.
I will say it again, I have not analysed your data. I have just looked at the graphs and I can see that there is a lot of overlap in the data.
You need to decided if your data is a true representation of the measurement system, then make the appropriate decision. Look before you leap, said the hedgehog...
NC
H
Hodgepodge
SPC Noob
Check out this indicating micrometer. .000050" increments & IP54 coolant proof. The micrometer's gaging pressure will be constant, removing the operator controlled gaging pressure variable. The micrometer you are using is a great gage, but I would use an indicating micrometer for .0020" or less tolerance when possible.
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
T Reasons to change certification body and typical costs Registrars and Notified Bodies 16
R What is the typical industry standard for documenting Usability Risk? Human Factors and Ergonomics in Engineering 16
I AS9100 5.4.1 - Typical objectives of different functions and levels AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S OHSAS 18001 Typical Input and Output Examples Occupational Health & Safety Management Standards 4
optomist1 Typical Wire Harness Testing and Validation Testing for Automotive Applications Reliability Analysis - Predictions, Testing and Standards 8
M Example of a typical First Piece Inspection Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Is there a typical personality type in Quality? Coffee Break and Water Cooler Discussions 38
S What are typical Acceptable Quality Levels (AQL) adopted in Food industry? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
P Typical Number of NCRs for a Small Manufacturing Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T How many complaints, defects and non-conformances are typical? Customer Complaints 5
W What are "typical software risks"? Is IEC/TR 80002-1 a good place to look for a list IEC 62304 - Medical Device Software Life Cycle Processes 3
A The typical organizational set-up for Housing Services - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Typical values of MTBF for Optical Avionic Networks Reliability Analysis - Predictions, Testing and Standards 1
J What are some typical Customer Service Interview Questions Career and Occupation Discussions 5
L What typical items do auditors bring to Opening Meetings Internal Auditing 4
M What are typical Roles & Responsibilities of DHF (Design History File) Librarian? US Food and Drug Administration (FDA) 6
X Typical Auditor Questions on ISO 9001 General Auditing Discussions 6
N What are typical Software Life Cycle Metrics Software Quality Assurance 5
M Typical requirements for Internal Audit Lead Auditors Internal Auditing 5
L Typical defect ppm level for barrel surface coating process? Supplier Quality Assurance and other Supplier Issues 1
R What is a typical ppm performance level for casting suppliers? Supplier Quality Assurance and other Supplier Issues 7
J Typical Control Chart Guidance and Hypothesis Statistical Analysis Tools, Techniques and SPC 12
R MTBF to DPPM Calculation Based on the Unit's Typical Working Hours Reliability Analysis - Predictions, Testing and Standards 9
C Calibration Standards and Typical Accuracy Requirements for Force Gauges General Measurement Device and Calibration Topics 3
T Is this typical customer service? World News 12
T EMS (ISO 14001) Audit / Interview Typical List of Questions for Review and Additions ISO 14001:2015 Specific Discussions 15
R DCX PSO book 5th Edition - Does anyone have a typical index or check list? APQP and PPAP 6
O What are typical records of different documents required by ISO9001? Records and Data - Quality, Legal and Other Evidence 2
H Exponent in Excel .xls - How can I make the result typical scientific notation? Excel .xls Spreadsheet Templates and Tools 27
P What is Milliohms Typical? Cable assemblies for vehicles Manufacturing and Related Processes 6
Govind What is your typical attendance of ASQ program meetings? ASQ - American Society for Quality 33
L Seeking example of a typical Work instruction for purchasing Document Control Systems, Procedures, Forms and Templates 3
T Standard Causes of Registration Audit Nonconformances and Typical Failure Modes IATF 16949 - Automotive Quality Systems Standard 5
D What does RTYP on a Print Stand For? Radius Typical? Misc. Quality Assurance and Business Systems Related Topics 7
Marc What are the Contents of a Typical Characteristics Matrix? FMEA and Control Plans 1
R Typical Document / Record Transaction and Archive Volumes Document Control Systems, Procedures, Forms and Templates 4
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
C Risk Assessment Tools ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Informational Shainin - Books, Tools & Teq Book, Video, Blog and Web Site Reviews and Recommendations 1
C 8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R FOD Risk Assessment - What tools would you recommend for assessing FOD risk? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
cscalise Suggestions for MDR Auditing tools EU Medical Device Regulations 1
adir88 Tools for Normal and Fault Conditions ISO 14971 - Medical Device Risk Management 9
J Are DAM tools, Mobile application, clinical dashboard, etc. considered accessories to medical device or supportive functions? Manufacturing and Related Processes 4
M Defining frequency of measurement tools callibration Calibration and Metrology Software and Hardware 3
F How do you add accuracies for tools with different measurement devices? General Measurement Device and Calibration Topics 1
