Typical Wire Harness Testing and Validation Testing for Automotive Applications
optomist1
A Sea of Statistics
Hi To All,
Does anyone know or have experience regarding "what tests comprise typical wire harness validation" for harnesses used in an automotive application?
Thank you....
Optomist1
Jen Kirley
Quality and Auditing Expert
Re: Wire Harness Testing/Validation
Tests I have seen include:
1) Layout against a template or board - I have seen them using pins where terminals are positioned. This is used to confirm the lengths are correct.
2) Electrical continuity. When using a test jig the harness can be confirmed to have the correct terminals and that no cross-wiring has been done, also that the terminals have been attached so as to allow proper conductivity. It could be argued that this functional test is done after assembly, but if the harnesses are shipped off to be installed it becomes final testing for you.
optomist1
A Sea of Statistics
Hi Jennifer,
Thank you for the response, this helps....any insight regarding any environmental tests temp/humidity, vibration tests or test plans etc??
Regards,
Optomist1
AgnieszkaSz
If you make harnesses by the print, there should be indications regarding such conditions on harness specification - quite often international / national standards or manufacturer's standards.
As for dimensional testing, I came across a requirement that all dimensions from specifications must be checked for 5 pieces and the results were sent to the customer (sometimes accompanied by the sample). You could use this method internally too when starting a new product.
optomist1
A Sea of Statistics
Thank you for the response, this helps. Do you know of a set of standard envrionemental test that are used to vlaidation or approve the final harness assembly prior to installation into a vehicle/platform?
Regards,
optomist1
Jen Kirley
Regards,
optomist1
Environmental and vibration tests are types of reliability testing aren't they? Tests of such kind, tending to be destructive, might be done on a sample and not as validation of what ships.
SAE International has published a set of standards for automotive. I found the section on wiring harnesses on page 11. The IHS Standards Store is one source for these standards.
Do your customer requirements include "Conformance to ____" and mention standards?
AgnieszkaSz
As Jennifer wrote, such tests are the type tests and are used generally when a new type of harness is released into production. You can browse the SAE site for the topic "wiring". When serial production starts, the visual control, layout control and electrical connection test for each harness are generally good enough for the customers. Validation of manual assembly is a tricky subject and as such is seldom required by customers. Unless, of course, yours is the case of automated harness assembly - here validation would be both possible and sensible. I don't have experience in automated assembly, unfortunately.
Big Jim
In high volume production of cable assemblies, it is common to have computerized testing devices that allow you to plug in each connector to each cable assembly and then check both continuity with little or no voltage and then to load check with working voltages. The tester stores the information for each cable assembly. In aircraft applications, it is common for each assembly to be serialized, so the test data is stored for each serial number.
Again, in high volume production, crimping is often validated with a test piece (coupon)at the beginning of each run using a sample and a destructive pull test. On large runs, coupons are taken and tested at regular intervals.
It is not uncommon to "calibrate" the crimping equipment. That is to use dowel pins to check the choke points of the crimping tool.
In low volume production where it is not cost effective to build a dedicated testing device, continuity is checked by performing a manual pin-out test with an OHM meter. This is very time consuming, as every pin must be checked against every other pin in the assembly.
Some uses will also dictate using a Hi-Pot tester to test the assembly under load.
Figure out how the assembly is to be used and what specifications the customer has for testing before you determine your test plan.
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
T Reasons to change certification body and typical costs Registrars and Notified Bodies 16
R What is the typical industry standard for documenting Usability Risk? Human Factors and Ergonomics in Engineering 16
I AS9100 5.4.1 - Typical objectives of different functions and levels AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S OHSAS 18001 Typical Input and Output Examples Occupational Health & Safety Management Standards 4
M Example of a typical First Piece Inspection Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Is there a typical personality type in Quality? Coffee Break and Water Cooler Discussions 38
S What are typical Acceptable Quality Levels (AQL) adopted in Food industry? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
P Typical Number of NCRs for a Small Manufacturing Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T How many complaints, defects and non-conformances are typical? Customer Complaints 5
W What are "typical software risks"? Is IEC/TR 80002-1 a good place to look for a list IEC 62304 - Medical Device Software Life Cycle Processes 3
A The typical organizational set-up for Housing Services - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Typical values of MTBF for Optical Avionic Networks Reliability Analysis - Predictions, Testing and Standards 1
J What are some typical Customer Service Interview Questions Career and Occupation Discussions 5
S Typical Tools for Particular Tolerances Table? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
L What typical items do auditors bring to Opening Meetings Internal Auditing 4
M What are typical Roles & Responsibilities of DHF (Design History File) Librarian? US Food and Drug Administration (FDA) 6
X Typical Auditor Questions on ISO 9001 General Auditing Discussions 6
N What are typical Software Life Cycle Metrics Software Quality Assurance 5
M Typical requirements for Internal Audit Lead Auditors Internal Auditing 5
L Typical defect ppm level for barrel surface coating process? Supplier Quality Assurance and other Supplier Issues 1
R What is a typical ppm performance level for casting suppliers? Supplier Quality Assurance and other Supplier Issues 7
J Typical Control Chart Guidance and Hypothesis Statistical Analysis Tools, Techniques and SPC 12
R MTBF to DPPM Calculation Based on the Unit's Typical Working Hours Reliability Analysis - Predictions, Testing and Standards 9
C Calibration Standards and Typical Accuracy Requirements for Force Gauges General Measurement Device and Calibration Topics 3
T Is this typical customer service? World News 12
T EMS (ISO 14001) Audit / Interview Typical List of Questions for Review and Additions ISO 14001:2015 Specific Discussions 15
R DCX PSO book 5th Edition - Does anyone have a typical index or check list? APQP and PPAP 6
O What are typical records of different documents required by ISO9001? Records and Data - Quality, Legal and Other Evidence 2
H Exponent in Excel .xls - How can I make the result typical scientific notation? Excel .xls Spreadsheet Templates and Tools 27
P What is Milliohms Typical? Cable assemblies for vehicles Manufacturing and Related Processes 6
Govind What is your typical attendance of ASQ program meetings? ASQ - American Society for Quality 33
L Seeking example of a typical Work instruction for purchasing Document Control Systems, Procedures, Forms and Templates 3
T Standard Causes of Registration Audit Nonconformances and Typical Failure Modes IATF 16949 - Automotive Quality Systems Standard 5
D What does RTYP on a Print Stand For? Radius Typical? Misc. Quality Assurance and Business Systems Related Topics 7
Marc What are the Contents of a Typical Characteristics Matrix? FMEA and Control Plans 1
R Typical Document / Record Transaction and Archive Volumes Document Control Systems, Procedures, Forms and Templates 4
N Triple insulated wire for transformer isolation IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E IPC/WHMA-A-620C: Requirements and Acceptance for Cable and Wire Harness Assemblies Other ISO and International Standards and European Regulations 2
N Thermocouple Wire Calibration - Hot Junction vs. Cold Junction Temperatures General Measurement Device and Calibration Topics 1
J Manufacturing Safety Wire Training and Certification - Who should train Manufacturing and Related Processes 4
N Thermcouple Wire Calibration with a Fluke 753 General Measurement Device and Calibration Topics 0
A Wire Holder for Resistance Measurement of Stranded Aluminum Wire Manufacturing and Related Processes 2
K Problem with Cable Composed of Coextruded Litz Wire and Tube Manufacturing and Related Processes 1
4 In-House Thread Wire Calibration General Measurement Device and Calibration Topics 5
D Wire/Conductor Elongation Tester Verification General Measurement Device and Calibration Topics 2
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
M Wire Harness Line Process and Inspection Criteria Manufacturing and Related Processes 9
WEAVER Thermocouple Extension Wire for Temperature Measurement in an Oven General Measurement Device and Calibration Topics 9
W UL standard for Lead wire - meaning of UL numbering, AWG#, no. of conductor, etc Various Other Specifications, Standards, and related Requirements 1
