Tyvek Blister Pack Testing Requirements - ISO 11607
mobylad
Is it neccessary to do leak integrity on a Tyvek Blister Pack contaning a medical device? Is Burst Test and Peel Test (visual) enough? The Blister pack contains a glass vial, so the blister pack would be considered a secondary package? :confused:
pkost
Re: Iso 11607
Would the glass vial be dropped into the sterile field? I would think there is an expectation that the glass vial is sterile therefore you can't really consider the blister pack as "secondary"
The standard does not specify exactly what tests should be carried out; it just says that you should justify the decision in selecting them. I would suggest you risk assess the packaging and use that to justify whether to include leak testing or not.
mobylad
Re: Iso 11607
Yes, I see your point.. Yes..the glass vial would be used in a sterile field. This brings up a different question: The Blister Pack would also be dropped into the sterile field, as the vial is removed from the blister pack in the sterile field/area?? Do you know how this is normally handled as the outside sterility of the vial can be ensured (leak test, seal strenght..etc) but I'm wondering how can one guarantee the sterility of the outside of the blister pack? as the outside of the blister pack is packaged within a non-airtight box.
pkost
The blister will never be "dropped" into the sterile field otherwise the field would no longer be sterile.
There are a number of approaches. The ideal is a double blister approach - this is where the outer blister contains another sealed blister. In the theatre, the non sterile staff handle this outer blister, they carefully remove the tyvek lid then invert the blister so that the inner (and sterile) blister drops into the sterile field and then be handled by the scrubbed team. The non sterile team have no need to touch the inner blister and the sterile device (still sealed in the inner blister) is never outside the sterile field.
If you don't want to go down the double blister approach then after the non sterile member of staff has pealed back the lid, the scrub nurse (who is sterile) reaches inside and pulls out the contents; the scrub nurse has to take care not to contact the outside of the blister otherwise they have to re-scrub.
I am assuming that your glass vial is not implanted, so it can act as the "inner" blister. I would take some time to consider whether you can either drop the vial into the field (i.e. it won't be secured in the blister) or how it can be very easily removed from the blister by the scrub nurse (i.e. it is secured in the blister so won't rattle around)
edit: It has just occured to me that I have given a response assuming that your device is used in theatre. This may not be the case. I am less clear how sterile procedures are carried out outside of a theatre environment however procedure packs typically have sterile wrapping which opens onto a work surface. Anything within the wrap is sterile (any instruments needed) and this provides an impromptu sterile field. Anything else that is needed would typically be dropped into the field (assuming it's sterile). Due to the reduced number of sterile staff in some of these procedures (frequently only the doctor) then it is preferable to drop the sterile product in instead of having them reach into a sterile blister to reach it.
The Specialist
Before I respond I would like to ask a couple of questions...
What (in terms of your process) is the function/purpose of the blister pack?
Is it an empty glass vial that you are placing into the blister pack?
mobylad
Blister pack is to keep the outside of the vial clean.
The vial is not empty..The vial contails the medical device (liquid form)
MIREGMGR
If the outside of the filled glass vial must be sterile, then the outer pack is a sterile barrier system. Thus it must be engineered and validated as a sterile barrier system.
Ronen E
Problem Solver
Moderator
...And to address the original question -
Burst tests and peel tests essentially test the seal strip weld strength, i.e. a strong weld could pass even if it's not properly sealing.
If you wish to maintain a sterile barrier then yes, leak test is recommended.
Please also note that as long as the barrier is not exposed to liquid, to maintain a sterile barrier, it doesn't necessarily have to be airtight (refer to the tortuous path principle; this is basically how Tyvek works as well).
Cheers,
Ronen.
H Expired packaging material - Expired unused Tyvek pouches Other Medical Device and Orthopedic Related Topics 2
V Tyvek packaging for Medical device process validation Qualification and Validation (including 21 CFR Part 11) 2
T Validation and Verification - Catheter into a tyvek pouch ISO 13485:2016 - Medical Device Quality Management Systems 2
N Tyvek Pouch Seal - Pressure needed to conduct Vacuum Seal Leak test? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B DuPont plans Engineering Changes for Tyvek 1073B & 1059B - 2011 Other Medical Device and Orthopedic Related Topics 3
F Sterile Barrier Package (Tyvek Pouch) Validation Question ISO 13485:2016 - Medical Device Quality Management Systems 7
N Tyvek Pouch Seal - Visual Inspection 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 19
G Benefits of Blister Packaging for Pharmaceutical Products Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
G Double Blister Pack for an Implantable Device Other ISO and International Standards and European Regulations 1
M IATF Icon pack /PNG IATF 16949 - Automotive Quality Systems Standard 0
U Procedure pack components EU Medical Device Regulations 3
A IVD in MDR procedure pack EU Medical Device Regulations 2
S Article 22 Procedure Pack Labelling EU Medical Device Regulations 4
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
D How to list multi-product sample pack in GUDID 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
K EU MDR Art. 22 - Device + insertion pack - User manual and Labeling EU Medical Device Regulations 4
R Real Example of a currently marketed Procedure Pack CE Marking (Conformité Européene) / CB Scheme 1
F IEC 62133 cell vs. Battery Pack - Certification on the cell only IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Labeling requirements for procedure pack 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Procedure Pack - KIT - Each has its own CE Mark CE Marking (Conformité Européene) / CB Scheme 6
C What is the best ISO 22000 template pack to purchase? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
A FMEA training pack example wanted FMEA and Control Plans 4
J Counting Bolts & Nuts to Pack - Each quantity is NOT fixed Lean in Manufacturing and Service Industries 5
W Engineers signing off the back of the Route Pack Card AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S How to make pack bolts and nuts kits with right amount Preventive Action and Continuous Improvement 3
J Medical Device Procedure Pack IFU's (Instructions for Use) ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Receiving Inspection - Quantity Received different from Pack List & C of C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B SQC Pack Software Question Statistical Analysis Tools, Techniques and SPC 1
B Can somebody tell me about Lithium Ion Battery pack related standards Other Medical Device Related Standards 4
P ISO 9001 and flat pack 'New Company' (Two companies merging) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N Seek Battery Pack (Lithium or Ni-MN) Production Flow Chart for Vehicle Application Manufacturing and Related Processes 2
S Does Windows Service Pack (SP-3) upgrade need supplementary 510(k) submission?? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
J Dog Pack Attacks Crocodile In Northern Territory, Australia Funny Stuff - Jokes and Humour 5
Jen Kirley Man is charged $23 quadrillion for a pack of cigarettes Coffee Break and Water Cooler Discussions 5
L Serial Number labeling for Class IIa Medical device packaged in multi-pack EU Medical Device Regulations 2
V Letter of Guarantee - EN 12546-3 (Mechanical & Physical testing on an ice pack) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Where can I buy TS7-K Supplier Quality Requirements QS 7 Pack? IATF 16949 - Automotive Quality Systems Standard 5
Ron Rompen Minitab for Dummies? How to use the Minitab capability 6-pack Using Minitab Software 1
L Help needed creating a 5 S pack detailing the 5 S principal Lean in Manufacturing and Service Industries 2
R Pack & Ship Company - What registration? ISO 9001:2000 or ISO-TS 16949 or Other? Other ISO and International Standards and European Regulations 4
H Launch Readiness Review - Ford's LRR Supplier Pack Customer and Company Specific Requirements 3
