Tyvek packaging for Medical device process validation
V
vsethuram
Hi everyone,
Our company is about to commence validations including Ethylene Oxide sterilization validation (overkill method), shelf life testing (ASTM F1980) and transportation validation (ASTM D4169 DC13) for a single use medical device.
The device will be packaged in Tyvek 1073B / PE Film pouch with Chevron seal. I am having trouble getting the correct size of Tyvek pouch in time, so I’m thinking of use a bigger pouch (470mm x 220mm) for sterilization validation and shelf life validation. 470mm x 100mm will be used in production. Both sized pouches will be the exact same grade, from the same pouch vendor and will be sealed using the same validated sealing machine.
Can I justify the use of the bigger pouch for the validation? Obviously, I do not want to redo all / any of the validations because we used the incorrect size pouch. Are there any concerns relating to Bioburden / bioburden recovery / EO residuals that could be impacted by the use of the bigger pouch? Any other pitfalls I need to be aware of?
Thanks for your feedback, :)
Vish
Sam Lazzara
Some opinions below. My bottom line opinion: "Don't do it".
Pouch heat seal validation - no impact since seal visual appearance and seal peel strength are the typical process outputs that must be validated
Package validation (including distribution simulation, aging, whole package integrity testing, etc) - impacted, since the fit of the contents into pouch will be different
Note - Using the correct size pouch also avoids the possibility that you might need to fold the pouch to make it fit into the shelf carton. Avoid folding Tyvek pouches to avoid leaks in the clear film at creases/folds; orthogonal folds are notorious for causing film leaks/pinholes; you are more likely to have to fold the larger pouch to fit it into the shelf carton, and folding is a bad idea in general. There are film materials that are more resistant to such pinholes nowadays but they cannot typically survive orthogonal folds. By "orthogonal folds" I mean folding the pouch once and then folding it again at 90 degrees from the first fold - it leads to a small stress point at the intersection of the folds.
Bioburden, including recovery - no impact
EO sterilization validation - impacted since smaller pouch is a worse case (the greater surface area of the larger pouch facilitates gas transfer to the contents)
EO residuals - impacted since smaller pouch is a worse case (same reason as EO validation)
H Expired packaging material - Expired unused Tyvek pouches Other Medical Device and Orthopedic Related Topics 2
T Validation and Verification - Catheter into a tyvek pouch ISO 13485:2016 - Medical Device Quality Management Systems 2
N Tyvek Pouch Seal - Pressure needed to conduct Vacuum Seal Leak test? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Tyvek Blister Pack Testing Requirements - ISO 11607 Other ISO and International Standards and European Regulations 7
B DuPont plans Engineering Changes for Tyvek 1073B & 1059B - 2011 Other Medical Device and Orthopedic Related Topics 3
F Sterile Barrier Package (Tyvek Pouch) Validation Question ISO 13485:2016 - Medical Device Quality Management Systems 7
N Tyvek Pouch Seal - Visual Inspection 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 19
T CE-IVD mark on packaging EU Medical Device Regulations 1
A MDR requirement where unit of use packaging is too small for UDI carrier EU Medical Device Regulations 1
K Re-packaging under MDR EU Medical Device Regulations 3
M Packaging standards - ASTM vs ISTA Other Medical Device Related Standards 1
M Packaging studies - ISTA vs ASTM CE Marking (Conformité Européene) / CB Scheme 0
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 4
C Packaging Long Parts Manufacturing and Related Processes 3
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
V Packaging in Distributor Practices EU Medical Device Regulations 0
R Green dot required on packaging? Medical Device and FDA Regulations and Standards News 2
shimonv Single lot release for sterile packaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Applicable ISO standards - packaging and others Medical Device and FDA Regulations and Standards News 4
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
C 21 CFR 803 malfunction detected during packaging - report? Other US Medical Device Regulations 1
E Latex in packaging Other Medical Device Related Standards 4
A GUDID - Packaging Levels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Packaging device with accessories already on the market Other Medical Device Regulations World-Wide 0
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 41
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
Q EU Rep for Packaging waste, WEEE and Battery disposal CE Marking (Conformité Européene) / CB Scheme 0
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L Packaging unsterile medical devices ISO 13485:2016 - Medical Device Quality Management Systems 6
M MDR - Packaging - Secondary Medical Device Boxes EU Medical Device Regulations 2
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
M UDI size on packaging EU Medical Device Regulations 3
M UDI placement - Packaging levels EU Medical Device Regulations 2
E Unit Dose Packaging Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
K Packaging and Damaged Parts returned from a Service Provider (Anodize) - Who is Responsible? Manufacturing and Related Processes 20
B 510(k) clearance claim on medical device product packaging Other US Medical Device Regulations 6
E Packaging Specifications Mercedes-Benz U.S. International IATF 16949 - Automotive Quality Systems Standard 4
T Colour of symbols on Medical Device labelling and packaging Other Medical Device Related Standards 1
R Labels on sterile packaging EU Medical Device Regulations 5
A Interpretation of Article 16 (2b) - Packaging, samples and Certificate EU Medical Device Regulations 10
I Medical Device Packaging Multilingual Labeling EU Medical Device Regulations 3
N Process Flow diagram steps for inspection and packaging APQP and PPAP 4
C ISO 7010 m002 mandatory action - Color requirements on Packaging IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
shimonv GTIN Number on the Packaging of a Serviced Medical Device EU Medical Device Regulations 0
shimonv Is UDI required on the Packaging of a Serviced/Repaired Medical Device? Other US Medical Device Regulations 3
C QR Code on Medical Device Packaging and Notification to Notified Body EU Medical Device Regulations 1
TheMightyWife Address Change - Medical Device Packaging Labelling Requirements EU Medical Device Regulations 7
E Use of FDA Cleared logo on packaging US Food and Drug Administration (FDA) 8
