Tyvek Pouch Seal - Visual Inspection
P
prabhatchaddha
#11
I want to understand that why u want visual inspection of pouch seal.Making a judgement of seal just by visual inspection is not reliable at all. You have to conduct burst Test and Seal strength.Equal width seal can vary a great deal even on same struture when you will be putting them on these tests.
There is a great role of pouch making process in seal integrity
rgjrgjrgj
#12
Hi Nimrod & DesiQE,
Likewise, I am in the process of developing a visual inspection procedure for pouch sealing. I have based my procedure on ASTM F 1886-98, but am struggling to produce good photographs of each failure mode.
Are you able to share your work?
rick76
#13
I just ran into the problem from a customer complaint the pouch seal was not horizontal instead it was sealed at an angle with few wrinkles, which was a concern from a sterility integrity customer needs to know the risks if the seal is not horizontal. I would like to know if anyone has a copy of a visual and burst test procedure?? I was planning to take the same route by implementing an inspection sheet with photos for our assemblers and q.c folks.
Denis
#14
There are two critical areas for testing tyvek pouchs.
Peel strength - this is performed by tensile testing.
Dye penetrant for visual assessment of leakage.
Both of these should form part of the validation for the heat sealer you are using.
Control of the inputs to the heat sealer should provide the assurance that the seals meet the necessary standard.
Think of heat settings ,pressure and time.
cutcoag
#15
Call Van der Stahl. They make awesome sealing and testing equipment and they'll help with the procedure. Ask for Charlie and tell him Lee Alexander says HI! You'll love these guys. they're the best of the best!:yes:
mkarlsson
#16
I came across this thread trying to search for the ASTM standards for flexible medical packaging.
This thread threw me off because in the OP there is a typo.
If anyone else is looking for the correct standard it is ASTM F1886, not 1866 (this one has something to do with plastic fittings)
Sybarite
#17
All: please keep in mind that burst testing and peel testing will not ensure package integrity for tyvek, as these methods only give an indication of seal-strength. These test methods will NOT detect pinholes in the top or bottom webs of the material.
An additional test method that may be considered here is an underwater-leak test.
rick76
#18
Thanks for the feedback, i went ahead and performed dye testing, drum testing and burst test to verify seal integrity.
Ronen E
Problem Solver
Moderator
#20
Just want some help if someone can share a copy of ASTM F1886:1998.
Hello and welcome to the Cove :bigwave:
The policy of these forums does not welcome sharing of copyrighted materials.
ASTM offer it for the modest price of US$38.
Cheers,
Ronen.
N Tyvek Pouch Seal - Pressure needed to conduct Vacuum Seal Leak test? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T Validation and Verification - Catheter into a tyvek pouch ISO 13485:2016 - Medical Device Quality Management Systems 2
F Sterile Barrier Package (Tyvek Pouch) Validation Question ISO 13485:2016 - Medical Device Quality Management Systems 7
H Expired packaging material - Expired unused Tyvek pouches Other Medical Device and Orthopedic Related Topics 2
V Tyvek packaging for Medical device process validation Qualification and Validation (including 21 CFR Part 11) 2
M Tyvek Blister Pack Testing Requirements - ISO 11607 Other ISO and International Standards and European Regulations 7
B DuPont plans Engineering Changes for Tyvek 1073B & 1059B - 2011 Other Medical Device and Orthopedic Related Topics 3
D What is your Sterile Medical Device Pouch Peel Strength Spec? Other Medical Device Related Standards 3
B EO Sterilization Indicators on Pouch and/or Carton EU Medical Device Regulations 4
B IVD Internal Label (Pouch) Requirements CE Marking (Conformité Européene) / CB Scheme 1
D Water in sterile pouch from Sterilization? Other ISO and International Standards and European Regulations 2
B Pouch Sealing and Peel Testing Process Improvement ISO 13485:2016 - Medical Device Quality Management Systems 10
Sam Lazzara Bar Sealer vs. Impulse Sealer for Medical Pouch Heat Sealing Qualification and Validation (including 21 CFR Part 11) 4
P ASTM F2054 specification for burst testing on sealed foil & laminate pouch Manufacturing and Related Processes 3
chris1price Sterile Pouch Peel Force of 1 pound/inch width Other Medical Device Related Standards 10
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 2
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
A Packaging seal inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
U Measurement of Water in a Seal Groove Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
N Symbol for Medical Device Sterile Packaging - "Inspect Seal Before Opening" Other Medical Device Related Standards 5
M "Streamlining Package Seal Validation" - I'm looking for this article reference Book, Video, Blog and Web Site Reviews and Recommendations 2
AnaMariaVR2 Sartorius launches device to cut and seal single-use tubes US Food and Drug Administration (FDA) 0
R Seal Packaging - Burst and Leak Specifications for a Foil Seal applied to a PTFE well Manufacturing and Related Processes 4
R Pressure Test Seal Surface - To machine or not to machine? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M ASTM F88 Standard Test Method for Seal Strength - Designation F88-09/M88-09 ver 15.1 Reliability Analysis - Predictions, Testing and Standards 6
K Seal or Logo of gluten-free foods that gluten intolerant people look for Food Safety - ISO 22000, HACCP (21 CFR 120) 7
D Critical quality characteristics on a heat seal machine - Design of Experiments help Quality Tools, Improvement and Analysis 20
ScottK ASME B&PVC Section VIII Div 1 question regarding "Seal" Various Other Specifications, Standards, and related Requirements 0
S Control Plans - Same seal now required by another customer FMEA and Control Plans 1
S Wheel seal testing facility needed Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
