UDI - Direct Marking and Reprocessing Clarification
Mark Meer
FDA 21 CFR 801.45 (a) states:
"A device that must bear a unique device identifier (UDI) on its label must also bear a permanent marking providing the UDI on the device itself if the device is intended to be used more than once and intended to be reprocessed before each use."
Couple quick questions:
1. So "direct marking" is synonymous with "permanent marking", and by "permanent marking" this means some kind of etching or engraving? I presume an indelible label is inadequate?
2. What is the definition of "reprocessing"? Does it include basic cleaning or disinfecting (e.g. simple wipe-down with an alcohol swab)?
MIREGMGR
I believe the expectation is: it's the device maker's responsibility to define how the device is to be reprocessed. Any means of directly marking the device is acceptable if it will remain readable across the worst-case-foreseeable number of reprocessing procedures through the device's declared lifecycle.
I'm sure this is formally defined, but I don't have a reference handy at the moment. My understanding though is that "reprocessing" includes only operations that are done to the device to prepare it for safe and effective re-use, over and above ordinary cleaning and disinfecting.
Surgical instruments typically go to central sterilization for reprocessing. Some kinds of invasive scopes might be reprocessed by the using department.
Mark Meer
Thanks MIREGMGR.
I've been trying to track down a formal definition of reprocessing...
The FDA should really have a dedicated page devoted to definitions, which all other CFR and Guidance pages can link to. Presently, all the definitions are scattered and restated.
Also, they could certainly clarify what they mean by "permanent" because, if as you say, it's based only on device lifecycle and foreseeable reprocessing, this is definitely not my idea of "permanent".
...I blame the FDA for my confusion! :notme: :lol:
Sam Lazzara
Hi Mark,
1. Etching or engraving may be overstepping depending on the intended use. I like what EN 60601-1:2013 says about this. Section 7.1.3 is call Durability of markings. It requires that markings can only be removed with a tool or by lots of force, and shall be clearly legible during the expected service life during normal use. It also says that adhesive labels must not come loose or curl. Finally a cloth hand rub test is specified that involves water, ethanol and isopropyl alcohol
2. See "Reprocess" definition below from AAMI TIR 30 (2011) - A compendium of processes, materials, test methods, and acceptance criteria for cleaning reusable medical devices
Reprocess: To make ready for reuse a device, instrument, or piece of equipment by any or a combination of the following processes: cleaning, decontamination/disinfection, repackaging, and sterilization.
Mark Meer
Thanks Sam.
I also agree that the 60601-1 marking durability description is far more comprehensive.
...But I'm more concerned with FDA interpretation of their UDI requirements.
Is this an FDA definition? If so:
- could you kindly provide a reference?
- this seems pretty all-encompassing as far as reusable medical devices are concerned. I'd think that just about all reusable medical devices have some kind of recommended cleaning instructions...
EDIT: Ah, I see that an FDA representative quote to this effect (reprocessing includes cleaning) in this thread.
O
Obama420
"A device that must bear a unique device identifier (UDI) on its label must also bear a permanent marking providing the UDI on the device itself if the device is intended to be used more than once and intended to be reprocessed before each use.":bonk::notme:
_____________________
watson
Mark Meer
Thanks for following up on that MIREGMGR!
I totally agree with your statement that the "quote from Jay Crowley would be problematic for many makers of (non-invasive, non-fluid-path-communicating) durable devices if broadly applicable", and DICE's reply seems reasonable.
I really don't see why the 21CFR doesn't simply state something to the effect of: "UDI device markings shall maintain integrity and legibility as required by 830.20, throughout the device's stated intended use and lifecycle." That would cover reprocessing, cleaning, multiple-users...etc.
Oh well...
:topic:
A bit off topic here, but is a reply from DICE carry any authority should some 510k reviewer have a different interpretation later on? (...especially if made by phone...).
MIREGMGR
Not just made by phone, but then paraphrased to you by some guy that you don't know in an Internet forum. Hey, sounds pretty authoritative to me, right?
The direct answer to your question is, depending on their seniority and their relationship with their supervisor, that 510(k) reviewers can interpret anything as they see fit. So when there's a 510(k) reviewer involved, my approach is to try to clarify every rule-interpretation as early as possible.
M Medical Device News FDA Guidance - UDI: Policy Regarding Compliance Dates for Class I and Unclassified Devices and Certain Devices Requiring Direct Marking Other US Medical Device Regulations 0
C Data Matrix and DPM (direct part marking) UDI Standards - ISO/IEC TR 29158 Other US Medical Device Regulations 2
K UDI Direct Marking Compliance Date Clarification and one other UDI question Other US Medical Device Regulations 0
JoCam UDI - Direct Labelling EU Medical Device Regulations 9
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
J UDI - Where to document it? EU Medical Device Regulations 8
N UDI: GS1 or HIBC ??? EU Medical Device Regulations 1
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 2
C UDI Questions on Control Units Other US Medical Device Regulations 6
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
V UDI - OEM or OBL / Legal Manufacturer Responsibility CE Marking (Conformité Européene) / CB Scheme 0
A European UDI-DI CE Marking (Conformité Européene) / CB Scheme 2
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
K Is UDI (Unique Device Identifier) symbol mandatory under EU MDR? EU Medical Device Regulations 3
M UDI procedure/ report 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
R Shall a new UDI-DI be required when stand-alone software device's version is updated? EU Medical Device Regulations 1
D Hospital Decontamination and the MDR - Technical Files, UDI and PMS EU Medical Device Regulations 3
F UDI - Unit of Use and Class I, single-use devices EU Medical Device Regulations 4
F UDI Registration - Who is responsible for Registration of the Device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
M UDI Database and EUDAMED - Will there be two separate databases? EU Medical Device Regulations 4
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Q LOT or Serial Number Symbol not used when the information is contained in the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
M Basic UDI and technical documentation EU Medical Device Regulations 1
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M MDR Requirements - UDI/Barcodes/QR codes on IFUs EU Medical Device Regulations 4
M UDI transition period and implementation EU Medical Device Regulations 6
M UDI size on packaging EU Medical Device Regulations 3
R UDI for US - Third Party device Repackager Other US Medical Device Regulations 9
M UDI placement - Packaging levels EU Medical Device Regulations 2
L UDI Requirments Gap Analysis - EU MDR vs FDA CFR EU Medical Device Regulations 8
M DI format for UDI after we have registered it with GS1 Other US Medical Device Regulations 0
P UDI labeling for power module IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
DitchDigger UDI, Labeling Accessories, General Insanity, Etc. US Food and Drug Administration (FDA) 1
K China UDI Implementation for October 1st 2019 China Medical Device Regulations 4
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
M UDI-PI on a package that contains more devices EU Medical Device Regulations 3
M Informational EU – Unique Device Identification (UDI) System – FAQs Medical Device and FDA Regulations and Standards News 0
F EUDAMED UDI Medical Devices User's Guide Medical Device and FDA Regulations and Standards News 7
J Class 1 Medical Device - Using a UPC over the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
Z Do we still have to put UDI if we have DI and lot number seperately on our product ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M EU Basic UDI-DI Trigger Points - When is a new Basic UDI-DI required EU Medical Device Regulations 3
P UDI-PI and the MDR - Is the UDI-PI required for all devices/classifications? EU Medical Device Regulations 8
M Informational US FDA issued the first warning letter for UDI violations to help ensure compliance Medical Device and FDA Regulations and Standards News 0
K Hospital UDI requirements Other Medical Device and Orthopedic Related Topics 7
J FDA Class 1 Medical Device UDI requirements Other US Medical Device Regulations 19
J UDI Requirements - Products that all fall under the same family 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Informational EU – MDCG 2018-1 v2 Guidance on basic UDI-DI and changes to UDI-DI Medical Device and FDA Regulations and Standards News 0
F MDR 2017/745 Basic UDI-DI, UDI-DI & UDI-PI EU Medical Device Regulations 0
