UDI for two units with different S/N on the same package/case
Hi Everyone,
We manufacture a Class II Medical device and needs to include the serial number on the UDI.
How should we do the UDI for 2 Units with different Serial numbers on the same package/case?
Can we have 2 UDI labels that contain different serial numbers for that package?
Please see attached samples UDI Package Label sample.jpg UDI Device Label sample.jpg
I have tried to ask FDA Helpdesk but they just quote the rule and don't give a direct answer to this question.
monoj mon
As mentioned in this FDA Document, PI is 'conditional' (i.e. not 'mandatory).
So, based on this I would suggest you the following;
  1. Assign a package DI (say DI 98765432100000) for the package which contain two of your devices.
  2. You already have a primary DI (say 12345678900000) for both of your devices inside that package.
  3. Register your primary DI at the GUDID database and set the device count to 1. At the Package DI section, insert your newly created Package DI and set the device count 2 containing the Primary DI.
  4. In the PI Identifier flags section, indicate which PI attributes are supplied with the Primary DI.
  5. On your actual outer packaging, place a newly created label containing only the 'Package DI' while inside the package place the already existing labels which contain the 'Primary DI' along with the PI Attributes.
Welcome kevin14!
Are there two separate devices in the package? One image looks like it is an instruction booklet.
Yes, there will be two of the same device with different serial numbers in the package. We will put the UDI on the IFU booklet because we do not need to have it mark on the Unit as our unit doesn't need to undergo high-level disinfection/sterilization before each use.
As mentioned in this, PI is 'conditional' (i.e. not 'mandatory).
We are already doing steps 1-3 on what you have suggested but from what we understand we also need to include the PI Attributes on Package UDI because we have the serial number on our label, this is the reason we are confused as it doesn't make sense to me to have the PI on the package UDI.
monoj mon
In my opinion, that's not the case. Your UDI information contains exactly what's on that particular label, don't bother what's on another label at a different level. If your package DI doesn't contain a serial number then why would you put it in your UDI! Serial numbers are for your Primary DIs, as your device labels contain serial numbers. If your package DI contains any PI attribute then, yes, include it in your UDI. But, including the Serial Number as a PI attribute on the higher level labeling doesn't make sense to me.
Hi, Thank you for your reply.
We also put a sticker serial number on the package for identification.
I have had trouble finding official advice for this exact situation. What I did find was:
  • - an older Cove thread
  • - from BSI
I hope this helps.
Thank you Jen and monoj,
I will present my findings to the management and see if we should:
  1. Have just the DI on the package label or
  2. Have 2 UDI (DI+PI) to reflect the different serial numbers.
I just also talked to one of our consultants and he suggested to just do it the way we understand the rule as there is no official advice on how to do it. Basically, just fix it if it was found non-conforming on our MDSAP audit hoping that they have a better suggestion on how to present the UDI for two units with different serial number on the same package.
Our Stage 1 will happen this September and Stage 2 on October, I will try to reply back to this forum if I find the best way to do this.
Again thank you so much for your supports
C UDI Questions on Control Units Other US Medical Device Regulations 6
Watchcat Mobile app - Different UDI for different smartphones? Other US Medical Device Regulations 7
Watchcat One UDI per country? ISO 13485:2016 - Medical Device Quality Management Systems 3
Watchcat UDI Timeframes? Other US Medical Device Regulations 5
A UDI-PI for IVDs used in house EU Medical Device Regulations 5
G SRN, Basic UDI, Legal Manufacturer EU Medical Device Regulations 6
A Basic UDI and UDI-DI for hip implant systems EU Medical Device Regulations 0
T FDA UDI Question - Class II Medical Device Other US Medical Device Regulations 1
R UDI Number Identification EU Medical Device Regulations 5
I Eudamed UDI-Module EU Medical Device Regulations 9
L Configurable UDI mdr EU Medical Device Regulations 0
L UDI implementation in Saudi Arabi (KSA) Other Medical Device Regulations World-Wide 0
L UDI-DI - Device will be sold by itself in a box EU Medical Device Regulations 2
P Basic UDI-DI and Legacy Devices EU Medical Device Regulations 19
C UDI for consumable/replacement components under the MDR EU Medical Device Regulations 2
C Validation of process for releasing the UDI EU Medical Device Regulations 4
A MDR requirement where unit of use packaging is too small for UDI carrier EU Medical Device Regulations 1
L UDI needed when we submit to ON? EU Medical Device Regulations 5
S Does a refurbished product required a new UDI? US Food and Drug Administration (FDA) 3
A UDI for product already packed up EU Medical Device Regulations 0
M Brand owner or manufacturer responsible for Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Aymaneh UDI-PI Software CE Marking (Conformité Européene) / CB Scheme 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 3
J UDI - Where to document it? EU Medical Device Regulations 8
N UDI: GS1 or HIBC ??? EU Medical Device Regulations 1
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 4
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
V UDI - OEM or OBL / Legal Manufacturer Responsibility CE Marking (Conformité Européene) / CB Scheme 0
A European UDI-DI CE Marking (Conformité Européene) / CB Scheme 2
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
K Is UDI (Unique Device Identifier) symbol mandatory under EU MDR? EU Medical Device Regulations 3
M UDI procedure/ report 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
R Shall a new UDI-DI be required when stand-alone software device's version is updated? EU Medical Device Regulations 1
D Hospital Decontamination and the MDR - Technical Files, UDI and PMS EU Medical Device Regulations 3
F UDI - Unit of Use and Class I, single-use devices EU Medical Device Regulations 5
F UDI Registration - Who is responsible for Registration of the Device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
M UDI Database and EUDAMED - Will there be two separate databases? EU Medical Device Regulations 4
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Q LOT or Serial Number Symbol not used when the information is contained in the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
M Basic UDI and technical documentation EU Medical Device Regulations 1
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M MDR Requirements - UDI/Barcodes/QR codes on IFUs EU Medical Device Regulations 4
M UDI transition period and implementation EU Medical Device Regulations 6
M UDI size on packaging EU Medical Device Regulations 3
R UDI for US - Third Party device Repackager Other US Medical Device Regulations 9
M UDI placement - Packaging levels EU Medical Device Regulations 2
L UDI Requirments Gap Analysis - EU MDR vs FDA CFR EU Medical Device Regulations 8
