Not sure if I am in the right forum so sorry if not! I am working on UDI and the project charter / presentation etc. to start this project.
The devices I am referring to are Class II serialized, re-usable (reprocessed as we instruct to clean (wipe down) the device between patient use).
I began to make a list of the devices by model number thinking that each model would require a UDI. I thought I was on the right path until listening to a Reed Technology webinar where by the QA session addressed a question about serialized devices with multiple configurations.
I am now second guessing myself. The devices are built and depending on what fittings and adapters are requested by the customer, are shipped with those fittings/adapters which creates a new part number.
The base part is given a number ie; XXXX-XXXX-XXX. The middle 4 x's contain the base model number. The last 3 digits continuously change depending on the fittings and adapters.
The current label affixed to the device contains a serial number (which is for the base model).
The device is plastic on the surface so, I don't think etching will work - not sure of what other options may be available (other than a seperate UDI label).
Question: Is the UDI determined by the base model or would I need to apply a UDI to every possible configuration?
Question: Since space is limited (very small labels), and given that the device is re-usable, is it appropriate to apply the Direct Marking in the form of a label that is attached somewhere else on the device (on the side / under the current label)?
Question: If a seperate label is acceptable for Direct Marking, wouldn't it need to be validated or tested in some way to assure that cleaning/wiping does not affect the integrity of the label (since it needs to remain intact for the lifetime of the device which is approx. 12 yrs.)
I know I have asked a lot of questions here - sorry!! I am on "overload". I could use some help and definitely some training. So far, I have watched just about all the "free" webinars I can find. If anyone has information as to where I can get training, please let me know. Been to CDRH Learn, Reed Technology, GS1........I need more.
Thanks in advance to all - all help is much appreciate!
