UDI "Version or Model" for Stand-Alone Medical Device Software
keldez
We have a Class II stand-alone software device. This device is web-based and has no components in which a physical label could be placed. All updates are applied through the web and users cannot control the "version" used. Every couple weeks we release a new version of software that fixes certain bugs, adds features, etc, all within the defined Indications for Use.
Are we to obtain a new DI for every software release? Everything I've read indicates the DI must change along with changes to "versions of models". This all depends on how you interpret "versions or models". When looking at 21 CFR 801.3, "version or model means all devices that have specifications, performance, size, and composition, within limits set by the labeler". This doesn't seem helpful except for the hint that this threshold is defined by us, the labeler(?)
I've only found one other source online with a discussion relating specifically to this for what it's worth https://www.tapatalk.com/topic/4433...s-that-require-use-of-a-new-device-identifier
Would you agree that our DI would stay the same for new releases as long as we stay within the boundaries of our 510k? - With this, our PI would be revised every release, as our manufacturing date is reflected in our software version number in our "About" section.
Hope that makes sense. Thanks!
DEVigil
Re: UDI "Version or Model" for stand-alone software
My company also produces standalone software that the customer receives via an electronic installer. We have interpreted the GUDID guidance consistently with your own - that is, the PI changes with each release/version (which is the Batch/Lot number for FDA GUDID purposes) but the DI does not change unless there is a significant enough change to warrant a 510(k) submission. We've updated our relevant procedures accordingly.
As you noted, FDA leaves it to the labeler to determine whether device upgrades or variations constitute different models or versions. That seems key, in that FDA commentary indicates they believe this, combined with the definition you quote and the language of section 820.50, addresses industry concerns that each software update would require new a UDI. See the commentary on final rule in the Federal Register published 09/24/2013 - you can search for "820.50" or "software" and skip to the relevant sections. Apparently I can't make a direct link to the rule online since I have not posted enough here - sorry.
If we're wrong, we'll be wrong together ;).
Mark Meer
IMO, I think your system is fine.
If you use a Major.Minor version system, I think it would be justifiable to simple state that the DI "Version" simply applies to the major version level (e.g. DI = version 1.x of the software).
...and then, as you say, just update the PI with each minor revision.
Only when there is a major revision, you'd make a new DI.
NOTE: Just my input for the purpose of discussion (I, unfortunately, have no authoritative references to refer you to, but this seems reasonable...)
mihzago
that is my approach too.
If you search for other software devices, you'll notice that under "Version or Model" some actually don't define a specific version, but rather list the model name of the device.
If you supply your software on a media, that will probably not work though.
SSchoepel
I know this thread is old but I'm hoping those on it or someone who finds it knows the answer. (I asked the FDA help desk but just got quoted regulations.)
I am trying to set up the product in the GUDID. It says there can only be one DI and for each product you need a new DI. We have standalone software and are using a model number with our business identified in the DI and putting the major.minor release in the PI.
Can I enter each major.minor release we have in the GUDID using the same DI (though it says you can only use it once)?
For example we would have:
DI = INC123DeviceModel1
PI = xxxx16xxxxx
(pretend the xxxs are the other parts of the PI and 16 is for release 1.6)
If I have release 1.7 or 1.8 or 3.0 and none of them change our intended use but I need to enter the new UDI, I would be reusing the DI. That reuse seems to go against the user guide for the GUDID interface.
Have you entered more than one product release under the same DI in the GUDID?
SSchoepel
Nope. I have been bumping the DI number by one digit to match the major revision level just in case. We only have one product and not very many releases so this is sustainable for a while.
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
C How to place software version for SaMD product in HIBC secondary data structure (UDI-PI)? Other US Medical Device Regulations 4
R Shall a new UDI-DI be required when stand-alone software device's version is updated? EU Medical Device Regulations 1
N UDI for OTS Components Other US Medical Device Regulations 1
J Assigning UDI's for own brand products EU Medical Device Regulations 0
M UDI IVD Medical Device Class III US Food and Drug Administration (FDA) 0
E UDI on product/packaging levels EU Medical Device Regulations 2
O 14-digits UDI EU Medical Device Regulations 3
L Looking for SOP Template for UDI under MDR EU Medical Device Regulations 4
P MDR Article 27 - UDI - Keeping records of UDIs EU Medical Device Regulations 1
S BASIC UDI-DI for a class IIa device marketed in a Procedure kit EU Medical Device Regulations 1
C UDI assignment and labeling. EU Medical Device Regulations 4
C Labelling and UDI Requirements - Implications of serial numbers US Medical Device Regulations 1
D Basic udi-di to not appear on IFU? EU Medical Device Regulations 4
R Legacy Device UDI Requirements EU Medical Device Regulations 5
R UDI Requirement at home patient use EU Medical Device Regulations 2
P UDI on devices exclusively intended for retail point of sale EU Medical Device Regulations 3
J UDI and Labelling hierarchy and requirements for separate device components EU Medical Device Regulations 7
M UDI barcode quality EU Medical Device Regulations 3
C Issues with UDI-DI and LAA/LUA registration in Eudamed EU Medical Device Regulations 2
Watchcat Mobile app - Different UDI for different smartphones? Other US Medical Device Regulations 7
Watchcat One UDI per country? ISO 13485:2016 - Medical Device Quality Management Systems 3
Watchcat UDI Timeframes? Other US Medical Device Regulations 7
A UDI-PI for IVDs used in house EU Medical Device Regulations 5
G SRN, Basic UDI, Legal Manufacturer EU Medical Device Regulations 6
A Basic UDI and UDI-DI for hip implant systems EU Medical Device Regulations 1
T FDA UDI Question - Class II Medical Device Other US Medical Device Regulations 2
R UDI Number Identification EU Medical Device Regulations 5
I Eudamed UDI-Module EU Medical Device Regulations 9
L Configurable UDI mdr EU Medical Device Regulations 0
L UDI implementation in Saudi Arabi (KSA) Other Medical Device Regulations World-Wide 1
L UDI-DI - Device will be sold by itself in a box EU Medical Device Regulations 2
P Basic UDI-DI and Legacy Devices EU Medical Device Regulations 19
C UDI for consumable/replacement components under the MDR EU Medical Device Regulations 7
K UDI for two units with different S/N on the same package/case Other US Medical Device Regulations 10
C Validation of process for releasing the UDI EU Medical Device Regulations 4
A MDR requirement where unit of use packaging is too small for UDI carrier EU Medical Device Regulations 1
L UDI needed when we submit to ON? EU Medical Device Regulations 5
S Does a refurbished product required a new UDI? US Food and Drug Administration (FDA) 3
A UDI for product already packed up EU Medical Device Regulations 0
M Brand owner or manufacturer responsible for Basic UDI-DI and UDI-DI? EU Medical Device Regulations 8
Aymaneh UDI-PI Software CE Marking (Conformité Européene) / CB Scheme 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 3
J UDI - Where to document it? EU Medical Device Regulations 8
N UDI: GS1 or HIBC ??? EU Medical Device Regulations 1
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 4
C UDI Questions on Control Units Other US Medical Device Regulations 6
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
V UDI - OEM or OBL / Legal Manufacturer Responsibility CE Marking (Conformité Européene) / CB Scheme 0
