UN Class 5 Tolerances - Thread Setting Plug Gage 7/8-9 UNC 5
L
Loosh
Would you please let me know the tolerance of a thread setting plug gauge 7/8-9 UNC 5.
Also, where are stated the tolerances for UN class 5 setting plugs?
Stijloor
Re: UN Class 5 tolerances - Thread setting plug gauge 7/8-9 UNC 5
Any thread gage experts who can help?
Thank you.
Stijloor.
jerry_Malaysia
I think maybe you would like to look at ANSI/ASME B1.12, Class 5, interference fit thread, for more detail. There are so many tolerance defined, example pitch diameter tolerance, major and minor diameter tolerances and etc. Also, the TPI also plays an very important role here.
L
Loosh
Gentlemen,
Thank you for the replies.
Umang, thanks for the welcome. Unfortunately, none of the websites gave me the requested tolerances.
Jerry, it seems like ANSI/ASME B1.12, Class 5,is not available anymore. I am trying to get the Fed-Std-H28/23.
jerry_Malaysia
Gentlemen,
Loosh
Here's the Fed-Std-H28/23. Hope it help. I have got ANSI/ASME B1.12 as well, but i am afraid it will violate to copyright issue, so i can't attach for you. If you need, maybe you could let me know you need which portion, i may let you know the content.
L
Loosh
Loosh
I do not know if I downloaded the entire file, but the tolerances for the setting plugs for class 5 threads are not listed on this spec.
I will try to get the ANSI/ASME B1.12...
It is unbelievable, not being able to find the tolerances:mad:
Thanks again for your help!:thanx:
jerry_Malaysia
For sure you have downloaded the entire file. Problem is the tolerance that you wanted is not listed in Fed-Std-H28/23
See attachment, probably you will find this useful. It's from ANSI/ASME B1.12
L
Loosh
Hi again Jerry,
I am looking for thread SETTING plug tolerances.
Regarding class 5 threads, here, there, you can find some info, but for the set plugs......
:frust:
K What are Class H9 and F7 Tolerances for Aluminum Material Various Other Specifications, Standards, and related Requirements 1
R Nanomaterials used as coating on class I MD - rule 19 EU Medical Device Regulations 2
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
K Doubt on insulation class of a device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
A First CE-mark class III implantable device under MDD EU Medical Device Regulations 8
P ISO Class 8 particle count (annual certification vs monitoring) ISO 13485:2016 - Medical Device Quality Management Systems 4
I IVD - 98/79EC - class IIa - Annex to the EC from the NB states the CM as one of the facilities? CE Marking (Conformité Européene) / CB Scheme 2
Z MDR Class Ir deadline (Reusable surgical instruments) EU Medical Device Regulations 27
D Adding a Class I to a sample box Canada Medical Device Regulations 5
T Class A PRTD beyond 300°C General Measurement Device and Calibration Topics 0
F How to register class I device to all European Competent Autorities(CA) when we are European manufacturer EU Medical Device Regulations 4
K Sterile barrier system symbols - Label redlines for a Class III device (Kit Box) EU Medical Device Regulations 0
D Class 3 Device - Change of supplier of material Canada Medical Device Regulations 6
A FDA Class Classification for a cabinet 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
W Protective earth for Class I ME equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
K Class III Kit Box - Are translations mandatory under EU MDR? EU Medical Device Regulations 5
Edward Reesor FDA DM and /or Class I Life Saving US Food and Drug Administration (FDA) 0
A Interpretation of GMP Requirements for class 1 medical device manufacturer (device GMP exempt, only General controls applicable) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F UDI - Unit of Use and Class I, single-use devices EU Medical Device Regulations 4
H MDD Article 12 Labeling for Class IIa Medical Device - Please Advise EU Medical Device Regulations 3
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
R IVDR CE Mark for Class A products - Declaration of Conformity CE Marking (Conformité Européene) / CB Scheme 2
A Medical Device Vigilance decision tree for Japan for class 2 devices. Japan Medical Device Regulations 1
K Contamination Control - Class Is medical devices (Clause 6.4.2 ISO 13485:2016 (E)) ISO 13485:2016 - Medical Device Quality Management Systems 12
W Seeking Guidance Verification Test Strategy for Class B Medical Devices IEC 62304 - Medical Device Software Life Cycle Processes 1
S Shipment of a CE Approved Class III Device to the EU Member States Other US Medical Device Regulations 1
S Technical File for Surgical Mask in Class 1 MDD Elsmar Cove Forum ToS and Forum Policies 1
Edward Reesor EU Authorized Representative for a Class I Medical Device CE Marking (Conformité Européene) / CB Scheme 11
S Class I MDR Article 10 – QMS EU Medical Device Regulations 1
Q Old products new class - Dental Devices - Choosing tests EU Medical Device Regulations 2
dinaroxentool Former Class I device that is upscaled to IIa if the MDR is delayed EU Medical Device Regulations 2
J Class Fixed ME Equipment (US Deviation) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
W Direct to customer export of medical device (class I: prescription lenses + frame) US Food and Drug Administration (FDA) 2
M CE self-certification for Class I device (face mask) EU Medical Device Regulations 9
C New Class III medical device application for Health Canada Canada Medical Device Regulations 6
T First 510(k) submission - Class II software as medical device US Food and Drug Administration (FDA) 1
Y Retrospective Validation - Class I device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C ISO 13485 Requirement in Australia/NZ for class 1? ISO 13485:2016 - Medical Device Quality Management Systems 1
S How to register class IIA medical device accessories EU Medical Device Regulations 1
M Post Market Surveillance for Class II Medical Devices Medical Device and FDA Regulations and Standards News 2
M Special Controls and Class II Medical Devices Medical Device and FDA Regulations and Standards News 18
T HF testing / Summative evaluation for MDDS class I necessary? Human Factors and Ergonomics in Engineering 2
U Medical device trial budget - 2 hospitals for Class IIa medical device in Sweden Other Medical Device and Orthopedic Related Topics 2
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
G Class IIa medical products - PMS report and PSUR EU Medical Device Regulations 6
M Class I - International Registrations EU Medical Device Regulations 3
M Notified Body audits -Class Ia medical device product EU Medical Device Regulations 4
