UN Class 5 Tolerances - Thread Setting Plug Gage 7/8-9 UNC 5
U
Umang Vidyarthi
#11
Re: UN Class 5 tolerances - Thread setting plug gauge 7/8-9 UNC 5
Hi again Jerry,
I am looking for thread SETTING plug tolerances.
Regarding class 5 threads, here, there, you can find some info, but for the set plugs......
:frust:
Do not get frustrated, there are many experts here on the subject and someone will certainly be able to help you. Gordan Clarke and Gauge guy are the two experts you may contact.
Umang :D
Wayne
Gage Crib Worldwide
#12
I am looking for thread SETTING plug tolerances. Regarding class 5 threads...
This is not as hard as it sounds.
The current standard for this thread is: ANSI/ASME B1.12 CLASS 5 INTERFERENCE FIT THREAD. The most recent revision is: B1.12-1987(R2003). The standard can be purchased from any of a number of Authorized Engineered Standards Resellers.
I believe that the base thread call-out per the standard is: 7/8-9 NC 5. The product threads have additional modifiers (HF; CSF; ONF; IF; INF) following the thread designation which relate to the product material. These modifiers do not relate to the thread gages.
To generate the data for the set plug gages I would do the following: a) Identify the pitch diameters for the ring gages from B1.12. For the 7/8”-9 NC-5 the Pitch Diameters are: 0.8144”/0.8095”. b) Use ThreadTech Software to engineer the set plug requirements. Select the UN-series menu selection. The software offers choice: X or W gage tolerance. When prompted for what data to use, use choice ‘C’ to use the pitch diameters. You even get a choice of thread wire size. The resulting data will not be listed as 7/8”-8 NC-5 because it is not a recognized option in the software, but the data is that for which you search.
Attached is the print-out for 7/8”-9 NC-5 Class X Truncated Set Plug Gages just as it is printed from ThreadTech Software. <--Click link for free 30-day trial.
I hope this was helpful.:agree1:
L
Loosh
#13
Thank you Wayne!
If it is not too much, I do have some questions....
1)The standard is B1.12-1987 (I will buy it this week), but this standard actually, gives you the dimension and tolerance for the set plug, class 5 UN threads ???
You have the standard, but you have calculated the thread, starting from the ring dimension.
So again, is there any standard that will give you the dimensions (and tolerances) for set plugs class 5?
2) Me too, I am using a software in determining the thread dimensions, best wire size, etc., but the problem with this software is that is limited to classes 1,2 and 3.
Does you software calculate class 5 threads?
Thank you again, Wayne!:thanx:
Wayne
Gage Crib Worldwide
#14
[Does t]he standard … B1.12-1987 … actually give you the dimension and tolerance for the set plug, class 5 UN threads ??? You have the standard,... So again, is there any standard that will give you the dimensions (and tolerances) for set plugs class 5?
I admit to not owning a copy of B1.12. That being said, I cannot accurately answer your question. I ASSUME that B1.12 will give you information about the product threads but not give you information about the gage parameters. You will know for sure when you purchase the standard. I expect that B1.12 will point you to B1.2 for gage parameters because the thread is essentially a UN-series thread. I used ANSI B1.2 guidelines for calculating the gages.
... you have calculated the thread, starting from the ring dimension.
Ring gage pitch diameters = set plug gage pitch diameters = minimum/maximum product pitch diameters.
I am using a software in determining the thread dimensions, best wire size, etc., but the problem with this software is that is limited to classes 1, 2 and 3. Does you software calculate class 5 threads?
Sounds like you want to upgrade to a more versatile software. I prefer the ThreadTech software because of its versatility and ease of use. However the ThreadTech software does not have an option for class-5 threads, but the specific option is not needed if the pitch diameters are known. The ThreadTech software will work directly from the pitch diameters, regardless of the specified class-of-fit.
Again, I hope this helps some.
L
Loosh
#15
Gentlemen,
Unfortunaely, I still consider the problem unsolved...
Thanks to Wayne, I know that I can calculate the required dimensions (tolerances?) sarting from the ring gauges.
So far, I have a software showing me all the dimensions for classes 1,2,3. I have found tables for Classes 1, 2, 3 and 4.
Nothing with class 5.
H28/23 sends me to section 11 of B1.12 and again, as per H28, the gaging should be in accordance with H28/6, except that gage dimensions shall be specified in B1.12-1987.
It seems like today I will receive the B1.12, so maybe I will be able to find the dimensions (and tolerances) for set plugs, UN class 5 threads.
Wayne
Gage Crib Worldwide
#16
Please be sure to return and tell us what you have found once you receive your copy of B1.12.
U
Umang Vidyarthi
#17
Gentlemen,
Sorry to hear that your problem is not yet resolved. As suggested in my earlier post#11, Godan Clarke is another expert who might be able to help you. Send him a PM since he has not seen this thread, else he would have definitely chimed in.
Umang :D
L
Loosh
#18
Umang :D
Hi Umang,
I have already contacted Clark and it seems like his area of expertise is threadind, not thread gaging, so he pointed Wayne as being the master of this topic.
I am going to check the B1.12 and I hope that I will find an answer, that of course Wayne, I am going to share it with everybody.
L
Loosh
#19
:biglaugh:
Gentlemen,
I did not read the entire standard, but after a very quick check, the tolerances for the thread setting plugs (rings) class 5, can be admired :D at page 25, Table 12, ASME/ANSI B1.12-1987.
My best regards!
U
Umang Vidyarthi
#20
:biglaugh:
Gentlemen,
My best regards!
It happens more often than not, that we miss the obvious right in front of our nose. Anyway, better late than never, I am happy you found the solution. This is how persistense pays the reward.:applause:
Umang :D
K What are Class H9 and F7 Tolerances for Aluminum Material Various Other Specifications, Standards, and related Requirements 1
shimonv Clinical evaluation report for class I device EU Medical Device Regulations 3
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
D Electrical Medical Devices class I EU Medical Device Regulations 0
K MDR Class 1 Self Certification - Competent Authority or Notified Body? EU Medical Device Regulations 6
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
L Class IIb devices marked EC according to the 93/42/CE - Portugal CE Marking (Conformité Européene) / CB Scheme 3
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
J Reusable surgical Instrument is under class IIa? EU Medical Device Regulations 4
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
G Voluntary Class I Device Filing Other US Medical Device Regulations 4
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
N Validating Software before getting approved as Class 2 device US Food and Drug Administration (FDA) 5
D Can a diagnostic device be class I? EU Medical Device Regulations 1
A AMSQQP416E Class 2 type 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S IVD risk class II devices for Brazil and MDSAP Other Medical Device Regulations World-Wide 0
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Medical watch Class II (AP Type CF) with USB connection IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
L Radiology software Class I exemption Medical Device and FDA Regulations and Standards News 3
K CE Marking for Class I Medical Device? CE Marking (Conformité Européene) / CB Scheme 8
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
Z Class I marketing regulation and supply chain Other Medical Device Regulations World-Wide 0
S We are looking for EU authorised Representative for both Class I and Class IIb devices EU Medical Device Regulations 7
S How is the service life for class I reusable medical devices described in MDR? EU Medical Device Regulations 7
S How is the service life described for class I reusable medical devices in MDR? Elsmar Xenforo Forum Software Instructions and Help 1
R Class 1 Convenience kits for home teeth impression, NOT smile direct or other for alignment purposes Canada Medical Device Regulations 0
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Intervertebral body fusion cage, MDR Class II or Class III? EU Medical Device Regulations 4
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
R Nanomaterials used as coating on class I MD - rule 19 EU Medical Device Regulations 4
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
D Class IIB Medical Device Accessories - OTS Tablets Other Medical Device Regulations World-Wide 1
K Doubt on insulation class of a device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
A First CE-mark class III implantable device under MDD EU Medical Device Regulations 8
P ISO Class 8 particle count (annual certification vs monitoring) ISO 13485:2016 - Medical Device Quality Management Systems 4
I IVD - 98/79EC - class IIa - Annex to the EC from the NB states the CM as one of the facilities? CE Marking (Conformité Européene) / CB Scheme 2
Z MDR Class Ir deadline (Reusable surgical instruments) EU Medical Device Regulations 27
D Adding a Class I to a sample box Canada Medical Device Regulations 5
