UN Class 5 Tolerances - Thread Setting Plug Gage 7/8-9 UNC 5
stefanhg
#21
Re: UN Class 5 tolerances - Thread setting plug gauge 7/8-9 UNC 5
W Thread-Setting Plug
Nominal Size: 7/8 -9 NC-5
Max. Material (for GO Ring gauge)
Major Diameter Truncated: 0.8527 - 0.8520
Major Diameter Full Form: 0.8685 - 0,8692
Pitch Diameter: 0.8144 - 0.8142
Min. Material (for NOT GO Ring gauge)
Major Diameter Truncated: 0.8444 - 0.8437
Major Diameter Full Form: 0.8685 - 0.8692
Pitch Diameter: 0.8095 - 0.8097
Wayne
Gage Crib Worldwide
#22
... the tolerances for the thread setting plugs (rings) class 5, can be admired at page 25, Table 12, ASME/ANSI B1.12-1987....
Loosh;
I am courious. :) Did the data provided in the 10:45 AM 26th May 2010 PDF attachment match the data you found in Table 12?
Stefanhg;
The data provided in the previous post does not match :nope: the data provided in the 10:45 AM 26th May 2010 PDF attachment. I freely admit that I extrapolated that data based on some assumptions :mybad: and calculated the result using ThreadTech Software. Where did you get the data provided?
The tolerance you have listed is the W-tolerance and I used the X-tolerance. As a result of that we will differ on the tolerances. :truce: I can live with that.
We agree on the basic GO Pitch Diameter. :agree1:
We differ on the basic NOGO Pitch Diameter by 0.0002". I was certain that I started with accurate pitch diameters. :read: I will check my original source on Monday when I am back in my office.
Where I am most confused is the major diameters. :confused: Here we differ greatly. This is why I ask about the source of this data. This is also why I made the above request of Loosh.
Aren't numbers fun? :lmao:
Wayne
stefanhg
#24
Hi Wayne,
Where I am most confused is the major diameters. Here we differ greatly. This is why I ask about the source of this data.
Here more explanations:
(a) Materials of the external and internal interference-fit threads compress elastically and flow during assembly and when assembled.
(b) During driving, plastic flow of materials occurs, resulting in either an increase of the external thread major diameter or a decrease in the internal thread minor diameter, or both.
(c) Relieving the external thread major diameter and the internal thread minor diameter to make allowance for plastic flow eliminates the main causes of seizing, galling, and abnormally high and erratic driving torques.
(d) Relieving the major diameter of external threads and minor diameter of internal threads requires an increase in the pitch diameter interference in order to obtain driving torques within the range established. (In driving studs, it was found that the minimum driving torque should be about 50% greater than the torque required to break loose a properly tightened nut.)
(e)The major diameter tolerance for all external threads is twice the National Class 3 pitch diameter tolerance.
Stefan Golemanov
Qualisyst Ltd.
K What are Class H9 and F7 Tolerances for Aluminum Material Various Other Specifications, Standards, and related Requirements 1
shimonv Clinical evaluation report for class I device EU Medical Device Regulations 3
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
D Electrical Medical Devices class I EU Medical Device Regulations 0
K MDR Class 1 Self Certification - Competent Authority or Notified Body? EU Medical Device Regulations 6
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
L Class IIb devices marked EC according to the 93/42/CE - Portugal CE Marking (Conformité Européene) / CB Scheme 3
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
J Reusable surgical Instrument is under class IIa? EU Medical Device Regulations 4
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
G Voluntary Class I Device Filing Other US Medical Device Regulations 4
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
N Validating Software before getting approved as Class 2 device US Food and Drug Administration (FDA) 5
D Can a diagnostic device be class I? EU Medical Device Regulations 1
A AMSQQP416E Class 2 type 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S IVD risk class II devices for Brazil and MDSAP Other Medical Device Regulations World-Wide 0
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Medical watch Class II (AP Type CF) with USB connection IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
L Radiology software Class I exemption Medical Device and FDA Regulations and Standards News 3
K CE Marking for Class I Medical Device? CE Marking (Conformité Européene) / CB Scheme 8
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
Z Class I marketing regulation and supply chain Other Medical Device Regulations World-Wide 0
S We are looking for EU authorised Representative for both Class I and Class IIb devices EU Medical Device Regulations 7
S How is the service life for class I reusable medical devices described in MDR? EU Medical Device Regulations 7
S How is the service life described for class I reusable medical devices in MDR? Elsmar Xenforo Forum Software Instructions and Help 1
R Class 1 Convenience kits for home teeth impression, NOT smile direct or other for alignment purposes Canada Medical Device Regulations 0
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Intervertebral body fusion cage, MDR Class II or Class III? EU Medical Device Regulations 4
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
R Nanomaterials used as coating on class I MD - rule 19 EU Medical Device Regulations 4
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
D Class IIB Medical Device Accessories - OTS Tablets Other Medical Device Regulations World-Wide 1
K Doubt on insulation class of a device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
A First CE-mark class III implantable device under MDD EU Medical Device Regulations 8
P ISO Class 8 particle count (annual certification vs monitoring) ISO 13485:2016 - Medical Device Quality Management Systems 4
I IVD - 98/79EC - class IIa - Annex to the EC from the NB states the CM as one of the facilities? CE Marking (Conformité Européene) / CB Scheme 2
Z MDR Class Ir deadline (Reusable surgical instruments) EU Medical Device Regulations 27
D Adding a Class I to a sample box Canada Medical Device Regulations 5
