L
Loosh
Would you please let me know the tolerance of a thread setting plug gauge 7/8-9 UNC 5.
Also, where are stated the tolerances for UN class 5 setting plugs?
Any thread gage experts who can help?
Thank you.
Stijloor.
Gentlemen,
Thank you for the replies.
Umang, thanks for the welcome. Unfortunately, none of the websites gave me the requested tolerances.
Jerry, it seems like ANSI/ASME B1.12, Class 5,is not available anymore. I am trying to get the Fed-Std-H28/23.
Loosh
Here's the Fed-Std-H28/23. Hope it help. I have got ANSI/ASME B1.12 as well, but i am afraid it will violate to copyright issue, so i can't attach for you. If you need, maybe you could let me know you need which portion, i may let you know the content.
I do not know if I downloaded the entire file, but the tolerances for the setting plugs for class 5 threads are not listed on this spec.
I will try to get the ANSI/ASME B1.12...
It is unbelievable, not being able to find the tolerances
Thanks again for your help!
For sure you have downloaded the entire file. Problem is the tolerance that you wanted is not listed in Fed-Std-H28/23
See attachment, probably you will find this useful. It's from ANSI/ASME B1.12
