Unbiased Estimators for Sigma? Is 's' an alternative to RBar/d2?
G
George Tirebiter
I would be interested to know if there is an alternative estimator for sigma than Rbar/d2 that can be used for sampling. I realize that S^2 is an unbiased estimator for sigma^2, but S is not unbiased for sigma. Is there any option other than Rbar/d2? I am writing a small program for HP calculators and would like it if the only input required was the string of Xbar values. Any help would be appreciated.
Don Winton
In Grant and Leavenworth’s Statistical Quality Control, 6th Edition, page 107, there is an alternative to the Rbar/d2 unbiased estimate of sigma. Hope that helps.
Regards,
Don
I was better but I got over it.
G
George Tirebiter
Thank you for the pointer, I am still a bit confused on whether or not S is a valid estimator for sigma or not, some texts seem to think so while others are adamant that it is not. Computationally, S is easier to calculate than Rbar/d2, for my application any way. So does anyone have any insight into the question as to S or not to S?
Don Winton
<font color=#df0016><BLOCKQUOTE>I am still a bit confused on whether or not S is a valid estimator for sigma or not, some texts seem to think so while others are adamant that it is not.</BLOCKQUOTE></font>
The answer to that question depends on one thing: How accurate do you want the estimate?
From my reference above, an unbiased estimate of sigma can be obtained by sigma=s/c4. From “Applied Statistical Methods”, Academic Press, Page 437, c4 varies by the sample size n. For sample sizes greater than 30, c4 is greater than 0.9914. For sample sizes greater than 60, c4 is greater than 0.9958. Again the question becomes: Is this error between s and sigma acceptable? If not, c4 increases as n increases.
Determine which value of c4 is acceptable, ensure n is greater than the corresponding value of c4 and use s rather than sigma.
Just a thought.
Regards,
Don
G
George Tirebiter
Thank you for a clear and concise answer. Someday perhaps I will delve into the deep theoretical meaning of it all, but suffice to say that for now I will take a pinch of caution with my S.
Don Winton
<font color=#c001c0> <blockquote>Thank you for a clear and concise answer.</blockquote></font>
No problem. The “Applied Statistical Methods” I referenced above can also be found in various other texts (Juran, Feigenbaum, Grant and Leavenworth, etc.)
<font color=#c001c0> <blockquote>…for now I will take a pinch of caution with my S </blockquote></font>
For practical usage, I have found that when n is greater than 30, the difference between sigma and s is a minor thing and when n is greater than 60, the difference is negligible. Enjoy.
Regards,
Don
G
George Tirebiter
Yes that is true as n increases S approaches sigma, my real question is that using rbar/d2 is fine when working with subgroups if you have a value for rbar. My problem was in writing this code for the HP 48G calculator that it isn't really easy to do without having people have to enter a great deal of data. I need to check my Juran's for those C4 values.
G
George Tirebiter
Well, it seems my curiosity is not quite dead. I was looking over some data and fitting some curves to some histograms, it seems that unless the actual data distribution is near or perfectly normal Rbar/d2 is much less accurate than S. SO what gives? Any ideas? I took some data sets with 25 subgroups of 5 points each and calculated the S for the subgroup averages and the overall mean of the subgroup averages. I basically calculated based on sub-group averages not on individuals. Then I calculated the Rbar/d2 and plotted the standardized histogram and normal curves using S and Rbar/d2 and found that every time S was a more accurate representation of the data distribution. Is Rbar/d2 a hold over from the pre-calculator days when it was easier to find Rbar than to calculate S? Any thoughts?
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Internal Audits - Are you Neutral and Unbiased? Do you react to the objective data? Internal Auditing 5
P Acceptable quantity levels/Sigma levels for reducing the frequency of quality tests. Six Sigma 7
Jim Wynne Article: Whatever Happened to Six Sigma? Coffee Break and Water Cooler Discussions 32
S Lean Six Sigma Online Training Six Sigma 1
michellemmm What is the Cost of six sigma certification? Six Sigma 10
K Looking for a good Six Sigma book Six Sigma 7
N Student trying to apply Lean Six Sigma on a Construction project in my thesis Lean in Manufacturing and Service Industries 3
eule del ayre Lean Six Sigma for Quality Management System Lean in Manufacturing and Service Industries 10
Marc ASQ Lean Six Sigma Conference March 4-5, 2019 - Phoenix, AZ ASQ - American Society for Quality 0
Bev D ASQ Lean Six Sigma Conference March 4-5, 2019 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Levels of Lean Six Sigma Certification Six Sigma 3
J Excellent Resource on Statistics / Lean / Six Sigma Book, Video, Blog and Web Site Reviews and Recommendations 2
L UCL/LCL calculations using Sbar and sigma Statistical Analysis Tools, Techniques and SPC 2
M How Organizations maintain Six Sigma and TQM in their Operations ISO 13485:2016 - Medical Device Quality Management Systems 6
M Can Six sigma support ISO9001? If yes, in what ways? Lean in Manufacturing and Service Industries 5
L Toyota doesn’t use Six Sigma Six Sigma 1
N Implementation of Six Sigma in Service industry Service Industry Specific Topics 17
J Six Sigma Green Belt (SSGB) from a college - Options? Professional Certifications and Degrees 4
Bev D ASQ 2015 Lean Six Sigma Conference: Bev D's Presentation Problem Solving, Root Cause Fault and Failure Analysis 9
K Looking for Six Sigma Black Belt projects in Customer Service Six Sigma 7
K Estimation Sigma (Within) when subgroup n=1 (MiniTab) Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Using Minitab to do 6 Sigma Studies Six Sigma 4
M Total Productive Maintenance vs. Lean, Six sigma, Business Process Reengineering, etc Quality Tools, Improvement and Analysis 9
S Quality / 9001/ Six Sigma Audio CD Recommendations? Training - Internal, External, Online and Distance Learning 1
Q Advice for the Implementation of a Lean/Six Sigma Program Six Sigma 9
A Application / Use of Hypothesis Testing in any Six Sigma Black Belt Project Six Sigma 8
T Tools Six Sigma for my Automated Machine Six Sigma 8
V Pareto Analysis - Six Sigma - 'Productivity Improvement' project Service Industry Specific Topics 1
N Lean Six Sigma Deployment Six Sigma 2
G How much to pay a Freelance Six Sigma Trainer in India Six Sigma 2
M Six Sigma in the Software Industry Six Sigma 6
B Relating DPM, Sigma Quality, and Centering Statistical Analysis Tools, Techniques and SPC 2
G Looking for live project in company for Six Sigma Black belt Project Training - Internal, External, Online and Distance Learning 3
B How to identify Six Sigma Yellow Belt Project Six Sigma 4
O Main difference between X-bar sigma chart / X-bar range chart Statistical Analysis Tools, Techniques and SPC 4
D Calculating Lower and Upper 3 Sigma Control Limits Statistical Analysis Tools, Techniques and SPC 2
M Sigma Calculation in Excel Capability, Accuracy and Stability - Processes, Machines, etc. 3
K ASQ Six Sigma Handbook - Should I purchase the Black Belt handbook now? Six Sigma 5
alonFAI Six Sigma Green Belt Certification help Career and Occupation Discussions 5
H Chosing a Six Sigma Green Belt Project - Software Industry Six Sigma 9
S Suggestions for Six Sigma Online Training Training - Internal, External, Online and Distance Learning 6
S Example of a DFSS (Design for Six Sigma) Project or a Case Study Six Sigma 4
S Lean Hospital - Implementing a quality/lean/six sigma program Lean in Manufacturing and Service Industries 3
B Calculating Combined DPMO and Sigma Level for Two or More Different Work Areas Six Sigma 3
S 6 Sigma Performance Level Six Sigma 4
K Choosing a Six Sigma training organization Six Sigma 4
C DFSS (Design for Six Sigma) project or SSBB project? Six Sigma 8
H Case Studies of Six Sigma in Service Processes Six Sigma 1
optomist1 Establishing Sigma or Capabilty Indices for Automotive Safety Quality Tools, Improvement and Analysis 1
