Uncertainty Budget examples for Multimeter, Calibrator, DC Voltage wanted
dgriffith
Can u attach example excel files with uncertainty budget (multimeter, calibrator, DC Voltage)? Thank You!
What model DMM, Calibrator, and at what voltage?
Generically, you'll need the following as an example:
DMM spec for the voltage:
?(% reading + % scale + floor)
Calibrator specs:
?(% or ppm of output + floor)
The measured value/calibrator output:
10.0000 Vdc
And the other stuff:
Resolution of DMM and Calibrator
Sampled value statistics--avg and std dev or sampling mean (if you're reporting a sample average as your measurement result, then use the sampling mean).
An Excel file will only help if you already know what parameters you need and what to do with them.
There may be more but this is just an example.
Now you'll want to combine these parameters in a meaningful way. I'll post more or someone can carry on in the mean time.
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
F Learning Uncertainty Budget for Novice - Fluke 5520A Measurement Uncertainty (MU) 1
A Uncertainty Budget - Externally produced sensor module Measurement Uncertainty (MU) 1
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
N Include homogeneity uncertainty into budget table for thermocouples Measurement Uncertainty (MU) 1
M Uncertainty Budget for a Micrometer Measurement Uncertainty (MU) 5
J Uncertainty budget for IR thermometry at high T - 1000 - 1500?C Measurement Uncertainty (MU) 1
I UUT Accuracy as part of Uncertainty Budget Measurement Uncertainty (MU) 6
S Gage R&R as a wider aspect of uncertainty budget Measurement Uncertainty (MU) 3
E Uncertainty Budget with a mixture of kg and % Reading Measurement Uncertainty (MU) 4
C Optical Comparator Uncertainty Budget Measurement Uncertainty (MU) 2
Q Uncertainty Budget for Potable Water Metering System Measurement Uncertainty (MU) 2
S Calculating an Uncertainty Budget for an Optical Comparator General Measurement Device and Calibration Topics 4
J Uncertainty Budget for the Optical Microscope - Deriving Linearity Uncertainty Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M CMM Best Uncertainty - Type specific CMM Uncertainty Budget Measurement Uncertainty (MU) 3
S Measurement Uncertainty Budget (MU) of Ultrasonic Thickness gage? Measurement Uncertainty (MU) 4
G Uncertainty budget for industrial temperature controllers Measurement Uncertainty (MU) 2
J Measurement Uncertainty Budget for Comparative Dimensional Measurements Measurement Uncertainty (MU) 8
D Uncertainty Budget - Gage Blocks Measurement Uncertainty (MU) 7
M Contributing Factors in a Supermicrometer Measurement Uncertainty Budget? Measurement Uncertainty (MU) 8
L Creating Meaurement Uncertainty (MU) Budget for Infrared Thermometers Measurement Uncertainty (MU) 1
CalRich Measurement Uncertainty for Adjustable Thread Rings but No Budget Made Measurement Uncertainty (MU) 4
L % Uncertainty Budgets - Auditor wants to see my uncertainty budget represented as a % Measurement Uncertainty (MU) 5
R Measurement Uncertainty (MU) Budget for a 0-1 inch Micrometer Measurement Uncertainty (MU) 3
S Mercury in Glass Thermometer Uncertainty Budget Measurement Uncertainty (MU) 1
N QUERIES On ISO 17025 AUDIT - Measurement Uncertainty Budget, etc. ISO 17025 related Discussions 1
K Calibration Report Uncertainty Budget - Discussion and Spreadsheets Attached Measurement Uncertainty (MU) 11
L Uncertainty calculation for an average Measurement Uncertainty (MU) 1
F Missing value of Uncertainty B Measurement Uncertainty (MU) 10
F Issues in Uncertainty Estimation Measurement Uncertainty (MU) 5
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
S Uncertainty Budgets - Phase Noise (SSB), Harmonics Measurement Uncertainty (MU) 2
M Informational US FDA Final Guidance – Consideration of Uncertainty in Making Benefit-Risk Determinations in Medical Device Premarket Approvals, De Novo Classificati Medical Device and FDA Regulations and Standards News 0
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
G 3 Operator Std. Dev. and uncertainty calculation Measurement Uncertainty (MU) 2
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
G NIST SOP 29 - Assignment of Uncertainty - Question General Measurement Device and Calibration Topics 0
M Medical Device News FDA news - 05-09-18 - Draft - Uncertainty in Benefit-Risk Determinations Other US Medical Device Regulations 0
G How to include machine error in uncertainty calculations? Measurement Uncertainty (MU) 5
