Uncontrolled Hard Copy (Paper) Document Validity Period
Q
quality1984
Hi All,
I was wondering if I could get some opinions on an issue regarding uncontrolled hardcopies.
I work in a manufacturing plant and we do have controlled hardcopy folders etc but this is in regards to people printing copies off the controlled system and distributing them to Contractors.
I have made the rule that the printed uncontrolled copy is valid for 24 hours from the date of print only but the maintenace planners print copies 7-14 days in advance when they plan jobs. They state that they can't print on the day because there is just too much paperwork and it wouldn't be practical. They are concerned that if a validation period is only 24 hours then some Contractors would demand that they print off a fresh copy.
Most procedures don't change and the maintenance planners are the ones that change them anyway if they were to so they are aware of which procedure is up to date.
My question is, could I scrap the validation period altogether and just simply write a statement on the uncontrolled copy - ONCE PRINTED THIS DOCUMENT BECOMES UNCONTROLLED - If I do this am I opening myself up to a gap in the future? Could an Auditor fault this statement and ask for it to be changed?
Your help is greatly appreciated and I apologise if this has been asked before. I have tried to search previous threads but none really match this situation I am in.
Regards,
Kristina
harry
Re: Uncontrolled Hardcopy Document Validation Period
Hi All,
I was wondering if I could get some opinions on an issue regarding uncontrolled hardcopies.....................................
Welcome to the Cove.
'Uncontrolled' means you are not going to control or unable to control. Hence, setting validity period after it was printed is contradictory and may even land you in trouble with auditors.
This is correct. Once printed, it is outside your control because you simply do not know what is going to happen next.
somashekar
Hi All,
Regards,
Kristina
You are quite OK, exept that you can say ...
"UNCONTROLLED WHEN PRINTED, CHECK VALIDITY BEFORE USE"
and you can have the 'Printed on date: ' also appearing as a footer.
SteelMaiden
That is an acceptable method, but by no means the only one. We just use "uncontrolled when printed". I've seen systems that say uncontrolled after xx/xx/xxxx" with the date the copy came off the printer inserted. (I don't like that one, how do you know someone didn't issue a new one five minutes later?) And, I've seen the statement that you suggest also. In all actuallity, if you make that statement in your manual or procedures for your document control and your folks are trained, you don't have to have a statement at all.:2cents:
Q
quality1984
Re: Uncontrolled Hard copy Document Validity Period
Great! Thank you to all for your help, I really appreciate it :)
Helmut Jilling
Auditor / Consultant
...ummm...interesting comments, boys and girls...but, let's see what the "good book" says...shall we..? :cool:
4.2.3 Control of documents
Documents required by the quality management system shall be controlled...
a) to approve documents for adequacy prior to issue,
c) to ensure that changes and the current revision status of documents are identified,
g) to prevent the unintended use of obsolete documents...
So, though some of these methods are "common," they are only compliant if they meet these requirements. If you do it carefully, it can meet the requirements. If you just stamp your documents, it might not meet the requirements.
The purpose is simply to ensure that information is up-to-date, accurate, approved and authorized.
So, in the case of the maintenance docs printed days in advance, are they still the same revision? If so, if they didn't change, then the printed copies are the same as the approved copy, they can meet the requirement. Though, I'm not sure why they can't be printed 2-3 days before.
In the case of stamping them "Valid for one day when printed," if they don't change during that day, then they can meet the requirement.
In the case of stamping them "Uncontrolled if printed, verify before use," if you can't be certain people are actually verifying them, then they probably won't meet the requirement to "control." Besides, do you really want everyone in your company to take time to verify all the docs before use? Doesn't that sort of defeat the purpose of doc control in the first place?
Try to get peopl to use docs electronically, off your master. Then, doc control is most simple. In many cases, printing is just a habit. In the case of "valid for 24 hrs,' usually doc chnages take longer than that to approve anyway, so it probably won't be an issue.
The point of my post, is we were discussing methods, without linking to the requirment and the intent of the requirement. I am tired of people saying "well, they other auditor said it was ok..." Don't forget to make sure your methods meet the requirements.
Q
quality1984
Thank you for your comments.
The documents have to be printed in this case and cannot be electronically accessed by Contractors.
Due to the 10,000 + documents that I have to control it is not possible to have an inflexible system. I cannot control people printing documents even though they are discouraged to. I've even set up controlled hardopies of documents but in this case with maintenance that cannot be possible.
The documents within the electronic system are approved and adequately controlled. Official controlled hardcopies are approved and adequately controlled. Anything else outside of that would be virtually impossible to police.
Helmut Jilling
I agree with your dilemna, especially if you truly have 10,000+ docs. It is not possible to police everyone, thus, your primary option is to teach the basic principles I outlined. If the various managers understand what you are trying to achieve, compliance can be maintained reasonably well. Of the various suggestions offered, the idea of printing them and remaining valid for 24 hrs, or some reasonable period of time, may be the best solution, if, you can be sure the revisions won't chnage in the midst of the project.
Q
quality1984
I our electronic system contains over 10,000 documents, we are a big site. I did have the rule of a 24 hour period from day of print but the Maintenance crew (who do use the system quite a bit) can't work with it. The rest of the site doesn't have an issue. Unfortunately because there are a lot of maintenance staff they are quite vocal in their discontent so I am trying to come up with a compromise.
Education is fairly good across site, people understand the system and have a fair idea on what they need to do regarding document control.
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
qualprod An uncontrolled record is it a non-conformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Employee Contracts : Controlled and Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 6
R Part Prints - Controlled and Uncontrolled Documents (e.g.: The Production Floor) Document Control Systems, Procedures, Forms and Templates 13
J Uncontrolled Pictures of Packaging Posted on Walls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Observation - Uncontrolled Document (Cheat Sheet) General Auditing Discussions 14
K Medical Application Classification in Controlled/Uncontrolled by Mobile App State. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Q Documents uncontrolled when printed, if is not printed is controlled? Document Control Systems, Procedures, Forms and Templates 4
Chennaiite Controlled vs. Uncontrolled Document - Clarification requested IATF 16949 - Automotive Quality Systems Standard 11
T Living Documents which change every day - Control or Uncontrolled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K Reasons for Issuing Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 10
V Can we show Photocopied Uncontrolled Copies of Documents to an FDA Auditor? US Food and Drug Administration (FDA) 15
C Equipment Owner's Manual used for Calibration - Is it uncontrolled procedure? Document Control Systems, Procedures, Forms and Templates 15
T Obsolete Uncontrolled Electronic Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
bgot62 Secondary Operations and an uncontrolled document in the warehouse ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Printed Documents are considered Uncontrolled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 34
M Uncontrolled Inspection Report Templates Records and Data - Quality, Legal and Other Evidence 7
K Document Control Terms: Obsolete, Master Copy, Controlled and Uncontrolled Copy Document Control Systems, Procedures, Forms and Templates 2
W Can Calibration Procedures be uncontrolled? Document Control Systems, Procedures, Forms and Templates 2
F Referenced Documents vs. Uncontrolled Documents - Differences? Document Control Systems, Procedures, Forms and Templates 32
J What is the difference between a controlled document and an uncontrolled document? Document Control Systems, Procedures, Forms and Templates 10
D Controlled Engineering Drawings - Inspections to printed 'Uncontrolled' Prints Document Control Systems, Procedures, Forms and Templates 14
W Controlled Document vs. Uncontrolled Copy - Stamp requirements Document Control Systems, Procedures, Forms and Templates 11
W Quality Manual - Controlled vs. Uncontrolled Document Control Systems, Procedures, Forms and Templates 6
H Difference between Controlled & Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 13
A Uncontrolled Emergency Evacuation Drawings (Signs) Document Control Systems, Procedures, Forms and Templates 4
A Distribution of Controlled Copy vs. Uncontrolled Copies Document Control Systems, Procedures, Forms and Templates 4
C Control of Documents - When?? Uncontrolled forms identified days before the audit Document Control Systems, Procedures, Forms and Templates 19
J Uncontrolled Appendix? Document Control Systems, Procedures, Forms and Templates 13
J Controlling 'Uncontrolled' Documents sent to us by Customers Document Control Systems, Procedures, Forms and Templates 7
A What is an uncontrolled copy of a controlled document? Document Control Systems, Procedures, Forms and Templates 11
J Documentation/Work Instructions - Uncontrolled - Hung up at workstations Document Control Systems, Procedures, Forms and Templates 18
N Definition Controlled Copy vs. Uncontrolled Copy - What are the definitions and differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
C CMM Granite too hard General Measurement Device and Calibration Topics 4
J Argentina Asked for FSC Hard-Copy Edition Only Other Medical Device Regulations World-Wide 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
qualprod Non conformity, do nothing? Employee experiencing "hard times" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
W Is it required to stamp obsolete hard copy DHR's "obsolete"? ISO 13485:2016 - Medical Device Quality Management Systems 6
supadrai Just found out the hard way that only one registration per manufacturer is allowed in Yemen, regardless of OEM or private label arrangement. Other Medical Device Regulations World-Wide 0
L Do you need to save hard copies of obsolete documents? Document Control Systems, Procedures, Forms and Templates 10
Q Do hard copies of quality records have to be retained? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Alternative to keeping hard copy records that is 21 CFR part 11 compliant Document Control Systems, Procedures, Forms and Templates 0
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
W Great way to work hard for your career Career and Occupation Discussions 4
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
A Identification of Customer Property: Customer-Supplied Thumb Drives & Ext Hard Drives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Having a hard time closing CAR/ PAR Nonconformance and Corrective Action 13
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
S Why is it so hard to close out the CAPAs ? Nonconformance and Corrective Action 16
