Uncontrolled Pictures of Packaging Posted on Walls
Sidney Vianna
Post Responsibly
#11
JulieChisholm
#12
First question: It's fine to mark them "controlled copy" and just keep a list of where they are posted when they get updated so you can switch them out when a new revision is implemented. We put them in numbered plastic sleeves. I think visual aids are a helpful tool, especially if you're dealing with people doing a single task over and over again and seeing examples of defects. You should have a list anyway of where all your controlled documents have been distributed.
Second question: If someone writes a post-it such as "don't forget to turn in my form!" I consider that fine. The only downside is people can slowly go back to old habits and start recording more process related information on post-it's.
It's always a balancing act!
Best,
-Julie
hogheavenfarm
#13
I have used the "Quality Alerts" with good results, sometimes a picture is the best way to convey the information. Of course I make it controlled, usually filed with the WI number reference. Lately I have been making "Visual Procedure Manuals", which are essentially WI's with accompanying illustrations. The customers like them also. I make two (controlled) copies generally, one for the shop floor, and one to keep for reference in the QA lab. As changes are made during production, they are modified and revised. The old one is removed from the shop floor and reprinted with the new rev number, the QA copy is kept as is but the new material added to the back. That way I have a record of the changes that were made. When the job is over, they get marked 'obsolete' and filed with any production records. One disadvantage (?) it generally requires that the person putting it together is very familiar with the entire process, so every detail can be documented. As a result, I can now build many items we make by myself ! But that is what a good manual should enable someone to do.
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
qualprod An uncontrolled record is it a non-conformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Employee Contracts : Controlled and Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 6
R Part Prints - Controlled and Uncontrolled Documents (e.g.: The Production Floor) Document Control Systems, Procedures, Forms and Templates 13
S Observation - Uncontrolled Document (Cheat Sheet) General Auditing Discussions 14
K Medical Application Classification in Controlled/Uncontrolled by Mobile App State. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Q Documents uncontrolled when printed, if is not printed is controlled? Document Control Systems, Procedures, Forms and Templates 4
Chennaiite Controlled vs. Uncontrolled Document - Clarification requested IATF 16949 - Automotive Quality Systems Standard 11
T Living Documents which change every day - Control or Uncontrolled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K Reasons for Issuing Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 10
V Can we show Photocopied Uncontrolled Copies of Documents to an FDA Auditor? US Food and Drug Administration (FDA) 15
C Equipment Owner's Manual used for Calibration - Is it uncontrolled procedure? Document Control Systems, Procedures, Forms and Templates 15
Q Uncontrolled Hard Copy (Paper) Document Validity Period Document Control Systems, Procedures, Forms and Templates 12
T Obsolete Uncontrolled Electronic Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
bgot62 Secondary Operations and an uncontrolled document in the warehouse ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Printed Documents are considered Uncontrolled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 34
M Uncontrolled Inspection Report Templates Records and Data - Quality, Legal and Other Evidence 7
K Document Control Terms: Obsolete, Master Copy, Controlled and Uncontrolled Copy Document Control Systems, Procedures, Forms and Templates 2
W Can Calibration Procedures be uncontrolled? Document Control Systems, Procedures, Forms and Templates 2
F Referenced Documents vs. Uncontrolled Documents - Differences? Document Control Systems, Procedures, Forms and Templates 32
J What is the difference between a controlled document and an uncontrolled document? Document Control Systems, Procedures, Forms and Templates 10
D Controlled Engineering Drawings - Inspections to printed 'Uncontrolled' Prints Document Control Systems, Procedures, Forms and Templates 14
W Controlled Document vs. Uncontrolled Copy - Stamp requirements Document Control Systems, Procedures, Forms and Templates 11
W Quality Manual - Controlled vs. Uncontrolled Document Control Systems, Procedures, Forms and Templates 6
H Difference between Controlled & Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 13
A Uncontrolled Emergency Evacuation Drawings (Signs) Document Control Systems, Procedures, Forms and Templates 4
A Distribution of Controlled Copy vs. Uncontrolled Copies Document Control Systems, Procedures, Forms and Templates 4
C Control of Documents - When?? Uncontrolled forms identified days before the audit Document Control Systems, Procedures, Forms and Templates 19
J Uncontrolled Appendix? Document Control Systems, Procedures, Forms and Templates 13
J Controlling 'Uncontrolled' Documents sent to us by Customers Document Control Systems, Procedures, Forms and Templates 7
A What is an uncontrolled copy of a controlled document? Document Control Systems, Procedures, Forms and Templates 11
J Documentation/Work Instructions - Uncontrolled - Hung up at workstations Document Control Systems, Procedures, Forms and Templates 18
N Definition Controlled Copy vs. Uncontrolled Copy - What are the definitions and differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
G Excel report with pictures Excel .xls Spreadsheet Templates and Tools 5
S Manufacturing Work Instruction examples that include process pictures Manufacturing and Related Processes 3
B Relationship Pictures Coffee Break and Water Cooler Discussions 10
Randy Getting Red X 's in a box instead of pictures - I need some information.... After Work and Weekend Discussion Topics 10
Scott Catron Pictures of the May 20, 2012 Eclipse Coffee Break and Water Cooler Discussions 4
Q Please recommend NCR / CAPA Software capable of embedding pictures Nonconformance and Corrective Action 12
D Mac Users - Downloading pictures from my digital camera to iPhoto After Work and Weekend Discussion Topics 8
O PPAP Presentation - Urgent need for "selling pictures" APQP and PPAP 1
Marc My Cousin Jonny's Art Web Site - Camp Ernst Pictures Coffee Break and Water Cooler Discussions 7
N Marketing Material with Pictures that were Updated ISO 13485:2016 - Medical Device Quality Management Systems 1
Ajit Basrur Checking in on Saturn - Good pictures ! Coffee Break and Water Cooler Discussions 0
D Facebook - No one can open my pictures After Work and Weekend Discussion Topics 3
C 5S Pictures with Seiri, Seiton, Seiso, Seiketsu and Shitsuke in Japanese Coffee Break and Water Cooler Discussions 3
N Printer Calibration Requirements - Documents and Pictures (Print Shop) Calibration and Metrology Software and Hardware 11
M Measuring a tap hook angle - ANY illustrations/pictures for the correct method? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Some Funny Pictures Funny Stuff - Jokes and Humour 9
D Displaying pictures on the Web Form After Work and Weekend Discussion Topics 5
