Understanding AMS 2750D compliant calibration report - items under 3.2.6.2
G
ggdjr
i'm having trouble understanding a couple of items under 3.2.6.2 (Calibration documentation)
can some explain to me:
- Standard used during calibration
- difference between:
- offset as found and as left
- any intentional offset as left
- example of
- limitaion or restrictions of calibration
- it would be very much appreciated if anyone had an example cert. to show also
thanks,
gd
BradM
This is the higher order, NIST traceable standard that you used to calibrate the item under question. It could also include the applicable procedure you used. I have also seen the instrument classification from AMS 2750D listed here.
- example of
- limitation or restrictions of calibration
Generally, this is the difference from the actual displayed reading and the ideal reading, for lack of better terms. Your standard simulates 200F, and the instrument under test displays 202F. The offset is +2F. However, it's always better to adjust instruments to remove any offset if possible. Life just seems to be better than way.:D
Too, there may be an offset listed for temperature profile surveys. If you have to increase the controller 3 degrees to get a good survey, then you would list that as the offset.
As far as limitations.. Say you try to calibrate a controller from 0-1000F, and it is way off above 800F. The oven can only achieve around 500F, and the customer uses it to 375F. Thus, you could perform a limited calibration to 450F, but it needs to be marked on there.
Unfortunately I could not find any examples of this, but the certificate should not deviate from a generally accepted pattern in the industry. It will just add the required fields of interest (if applicable).
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Informational Health Canada has launched an e-Learning tool to aid in understanding the premarket regulatory requirements for medical devices in Canada Medical Device and FDA Regulations and Standards News 0
S Understanding UDI requirements - Class 2 medical device (hearing aids) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Informational Understanding Costs And Risks For HFE Usability Studies — Part 1: Testing In-House Medical Device and FDA Regulations and Standards News 0
P Understanding FDA draft "Management of Cybersecurity in Medical Devices" Medical Information Technology, Medical Software and Health Informatics 3
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 29
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
R Understanding a few points on ISO 9001's Design and Development Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Understanding Cycle Time - Why the time of the other activities are left out Lean in Manufacturing and Service Industries 11
J Understanding ISO 9001:2015 - 10.3 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Understanding ISO9001:2015 - 8.3: Design and Development of Products and Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
E Understanding of TS 16949 Clause 7.6.2 IATF 16949 - Automotive Quality Systems Standard 5
K Understanding IEC 60601-2-68 requirements ISO 13485:2016 - Medical Device Quality Management Systems 1
A Training material for interpretation & understanding Part 11 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
N Understanding, Challenging & Approving Supplier Control Plans FMEA and Control Plans 7
M Definition Recommendations - Understanding "recommendations" and "recommended corrective action" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
S Understanding UDI (Unique Device Identification) Other US Medical Device Regulations 10
T Understanding USP <1112> Water Activity as applicable to Medical Devices Other Medical Device and Orthopedic Related Topics 4
K Understanding Risk Management Requirements according to AS9100 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
S MIL-HDBK-217 - Understanding the various Environmental Conditions Reliability Analysis - Predictions, Testing and Standards 1
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
C Understanding the relationship between 62304 and the MDD ER IEC 62304 - Medical Device Software Life Cycle Processes 7
S Understanding Subgroup Size - Multi Cavity (Minitab) Statistical Analysis Tools, Techniques and SPC 4
R Understanding clause 15.4.2.1 d) of amendment 1:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M Understanding accreditation, MoUs, certifications Other ISO and International Standards and European Regulations 28
L Mobile Medical App - Understanding 21 CFR Part 820 Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Understanding and implementing ISO 17025 ISO 17025 related Discussions 9
M Understanding Versions of Collateral and Particular Standards IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Understanding, Analysis and Monitoring Quality Defects on Composite Components Statistical Analysis Tools, Techniques and SPC 3
S Understanding PMS (Post Market Surveillance) and PMCF (Vigilance and PMCF) Quality Manager and Management Related Issues 1
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
Q Beginner's Understanding - The Purpose and Applications of QMS/ISO Standards Philosophy, Gurus, Innovation and Evolution 12
Q Understanding Configuration Management AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 16
W Understanding PPAP Appearance Approval APQP and PPAP 19
V Understanding Automotive Coating for Seating Mechanism Components Manufacturing and Related Processes 1
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
4 Understanding ILAC policy P14:12/2010 6.3 part a) General Measurement Device and Calibration Topics 28
H Understanding 8.2.3 M&M of Processes for our Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Understanding ISO 26262 Road Vehicle Functional Safety Other ISO and International Standards and European Regulations 2
arios Understanding adoption of a product to an existing Sterilization Cycle Other US Medical Device Regulations 1
M Learning ISO 13485 - Getting a better understanding of the requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
S Understanding FDA rules regarding MDDS Status and Clinical Trials 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
G Understanding Identification of Design in QSR 21 CRF Part 820.30 Design Control (f) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Understanding the general Philosophy with Complaints and CAPAs ISO 13485:2016 - Medical Device Quality Management Systems 7
M Understanding DC Patient Leakage Failure from 0.3VDC IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Understanding TS 16949 Clause 8.2.3 and How to Audit according to it IATF 16949 - Automotive Quality Systems Standard 7
