Understanding clause 15.4.2.1 d) of amendment 1:2012?
Roland chung
Hi all,
Clause 15.4.2.1 d) of amendment 1:2012 states that loss of function of MEE caused by operation of a thermal cut-out or over-current release shall not result in the loss of ESSENTIAL PERFORMANCE.
But in the real world, clinical function will usually loss when the protector operates since the power supply of equipment (or of part of equipment) will be shut down. So it is difficult to fulfil this requirement.
Could you please share your point of view?
Thanks,
Roland
Re: How to understand clause 15.4.2.1 d)?
Hullo Roland,
Slight correction,
Loss of function of the ME EQUIPMENT caused by operation of a THERMAL CUT-OUT or OVER-CURRENT RELEASE shall not result in a HAZARDOUS SITUATION.
Compliance is checked by inspection of the design documentation and the RISK
MANAGEMENT FILE.
But there will be times where clinical performance has to be maintained. I guess then you would need duplicate temperature control systems rather than a cut-out.
Roland chung
Hi Pads38,
Thank you. The requirement you quoted is from 60601-1:2005, but I am talking about A1:2012.
Regards,
Roland
Peter Selvey
In A1, essential performance is separated under normal condition and single fault condition. Typically we don't expect full performance under fault condition, but for higher risk devices there may be minimum functionality or special limits that apply.
For example a surgical laser may have the following specs:
EP/NC: +/-5% of set power
EP/SFC: not exceed more than 20% of set power
For lower risk devices, there may be no EP in SFC (in which case it should be explicitly stated as such). For example a low risk temperature monitoring function:
EP/NC: +/-0.3C
EP/SFC: No requirement
A thermal cut out should only operate in SFC, so it would pick up the EP/SFC limits, not the EP/NC limits. A high risk device might define EP/SFC as being able to provide an alarm in case of loss of function, i.e. when the TCO opens.
Roland chung
Does it mean that alarm is an alternative to the loss of essential performance for high risk equipment (e.g. infant warmer)? From the risk analysis, it is convincing. But from the literal meaning of standard, essential performance should be maintained (no matter NC/EP or SFC/EP).
No clinical functions are possible if the thermal cut-out inside the infant warmer operates under single fault condition.
Peter Selvey
A1 clearly indicates that EP is not static and should be considered separately for normal condition and SFC, so at least two distinct specifications. But I expect eventually we will see that essential performance is highly context sensitive, not just these two levels. Different abnormal events like operator error, low battery, loss of mains supply, genuine hardware faults, EMC interference all occur at varying probabilities, so variable specifications make sense.
For example a electronic home use thermometer might have the following EP:
Ambient temp 15-40: +/-0.2C accuracy
Ambient temp 0-50: +/-0.4C accuracy
Low battery: blank display, show low battery symbol
After 20cm immersion test: no effect (specified accuracy)
After being dropped from 1m 3 times: no effect (specified accuracy)
After vibration test: No effect (specified accuracy)
After ageing test: No effect (specified accuracy)
High humidity test: No effect (specified accuracy)
EMC 3V/m: No effect (specified accuracy)
EMC 10V/m: Specified accuracy or blank display
SFC (in measurement circuit): blank display, show error function
SFC (excluding measurement circuit): no requirement
This is just a conceptual example off the top of my head, not a real suggestion for a design specification and obviously not a complete list of conditions (contexts).
Peter Selvey
In the revised Clause 4.3:
The MANUFACTURER shall then specify performance limits between fully functional and total loss of the identified performance in both NORMAL CONDITION and SINGLE FAULT CONDITION.
Also check out the note, it has an example which fits exactly with the start of this thread
E Understanding of TS 16949 Clause 7.6.2 IATF 16949 - Automotive Quality Systems Standard 5
E Understanding TS 16949 Clause 8.2.3 and How to Audit according to it IATF 16949 - Automotive Quality Systems Standard 7
M Understanding AS9100 Clause 7.5.1.4 Post-Delivery Support Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P Understanding IEC 60601-1:2005, Clause 8.1 b) - Short Circuiting Double Insulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
S Understanding of Process Validations - ISO 9001 Clause 7.5.2 Validation Qualification and Validation (including 21 CFR Part 11) 9
A Understanding AS9100 Clause 7.5.2 Validation of Processes for Production and Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Understanding clause 4.4.3 - Communication ISO 14001:2015 Specific Discussions 1
K Verification of Purchased Product - Help Understanding Clause 7.4.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Determining Competence - Understanding clause 6.2.2 a) of ISO9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
D TS 16949 Clause 7.4.1.2 ? Is my understanding correct? IATF 16949 - Automotive Quality Systems Standard 8
Q Understanding "free movement" for CE-marked products EU Medical Device Regulations 2
D High level understanding of EUDAMED EU Medical Device Regulations 3
A 60601-1 understanding of stationary device IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Qualification and Validation (including 21 CFR Part 11) 5
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Informational Health Canada has launched an e-Learning tool to aid in understanding the premarket regulatory requirements for medical devices in Canada Medical Device and FDA Regulations and Standards News 0
S Understanding UDI requirements - Class 2 medical device (hearing aids) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Informational Understanding Costs And Risks For HFE Usability Studies — Part 1: Testing In-House Medical Device and FDA Regulations and Standards News 0
P Understanding FDA draft "Management of Cybersecurity in Medical Devices" Medical Information Technology, Medical Software and Health Informatics 3
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
R Understanding a few points on ISO 9001's Design and Development Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Understanding Cycle Time - Why the time of the other activities are left out Lean in Manufacturing and Service Industries 11
J Understanding ISO 9001:2015 - 10.3 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Understanding ISO9001:2015 - 8.3: Design and Development of Products and Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
K Understanding IEC 60601-2-68 requirements ISO 13485:2016 - Medical Device Quality Management Systems 1
A Training material for interpretation & understanding Part 11 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
N Understanding, Challenging & Approving Supplier Control Plans FMEA and Control Plans 7
M Definition Recommendations - Understanding "recommendations" and "recommended corrective action" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
S Understanding UDI (Unique Device Identification) Other US Medical Device Regulations 10
T Understanding USP <1112> Water Activity as applicable to Medical Devices Other Medical Device and Orthopedic Related Topics 4
K Understanding Risk Management Requirements according to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S MIL-HDBK-217 - Understanding the various Environmental Conditions Reliability Analysis - Predictions, Testing and Standards 1
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
C Understanding the relationship between 62304 and the MDD ER IEC 62304 - Medical Device Software Life Cycle Processes 7
S Understanding Subgroup Size - Multi Cavity (Minitab) Statistical Analysis Tools, Techniques and SPC 4
M Understanding accreditation, MoUs, certifications Other ISO and International Standards and European Regulations 28
L Mobile Medical App - Understanding 21 CFR Part 820 Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Understanding and implementing ISO 17025 ISO 17025 related Discussions 9
M Understanding Versions of Collateral and Particular Standards IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Understanding, Analysis and Monitoring Quality Defects on Composite Components Statistical Analysis Tools, Techniques and SPC 3
S Understanding PMS (Post Market Surveillance) and PMCF (Vigilance and PMCF) Quality Manager and Management Related Issues 1
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
