Understanding ILAC policy P14:12/2010 6.3 part a)
4
426Hemi
I need help understanding ILAC policy P14:12/2010 6.3 part a), it states:
6.3 The numerical value of the expanded uncertainty shall be given to, at most, two significant figures. Further the following applies:
a) The numerical value of the measurement result shall in the final statement be rounded to the least significant figure in the value of the expanded uncertainty assigned to the measurement result.
Can someone explain this requirement, maybe in the form of "ILAC For Dummies", and provide a few examples.
I asked A2LA and have yet to get an answer.
dv8shane
WIki http://en.wikipedia.org/wiki/Significant_figures. So if you are reporting say % uncertainty and had a resolution of 3 significant figures you would round up per the GUM the least significant digit of the first 2 significant digits. Example measurement uncertainty before rounding 1.234 % This would round to 1.3% expressed with 2 significant figures. Ex 2 Measured value 10 V uncertainty 1.14 uV/V +/- 1.00 uV, This would be expressed as 1.2 uV/V +/- 1.0 uV
4
426Hemi
Thanks for the examples. I interpret it as the measured result and the unc should be rounded to the same resolution. Here is an example of how my purchased software formats the calibration data for a balance with 1 g resolution: Nominal Value (standard mass) = 1000.0 g, As Found (DUT measured or displayed value) = 1000 g, Unc = 0.58 g. Does the Unc look correct or should it be 580 mg, 0.6 g, or 1 g? Thanks.
Hershal
Metrologist-Auditor
The other point to remember is P14 is in revision and discussion today may not work a few weeks from now. Personally, I would not stress that much at this time.
stefanhg
The correct uncertainty with two significant places is: 0.58 g or 58*10^1 mg
The correct uncertainty with one significant place is: 0.6 g or 6*10^2 mg
dv8shane
I would disagree as the measured value is stated as 1000 not 1000.0, and the ? 0.58 would cause the display to go up or down by 1. You could not resolve the measurement by any less. Therefore the uncertainty would be ? 1 least significant digit.
stefanhg
According to official regulations and guidelines (GUM, Supplement 1 to the GUM, EA-4/02) the numerical values of the measurement results should be rounded to be consistent with their uncertainties.
This means, you can report the measured result with less or the same decimal places as the uncertainty, but never with more decimal places.
What you suggest is the opposite of the prescriptions in the standard - you are rounding the uncertainty by using as reference the measured value.
This is totally wrong, because the uncertainty is the defining parameter in the rounding procedure.
The complete result in this example should be: (1000 ? 0.58) g or (1000 ? 0.6) g
dv8shane
In this case the measurement result is limited to ? 1 significant figure. As the measurand can only be resolved to this how can you you claim less? The example quoted would be OK if you could resolve the measurement to 0.6 but you can not.
P
Pezikon
You are quoting section 7.2.6 of the GUM. The example given in that paragraph shows a situation where the measurement result has more precision than the uncertainty. As the example follows, the measurement result is rounded to match the precision of the uncertainty.
I would argue that 7.2.6 doesn't specifically address a situation where the measurement result has less precision than the uncertainty. What I consider to be "consistent" is when the precision of the measurement result and uncertainty match. Look in any guide on measurement uncertainty and it will be written that measurement uncertainty should be expressed as, at most, two sig-figs. It is necessary that the measurement result and reported uncertainty have the same precision for the sake of significance arithmetic.
Using significant figures rules, the result is rounded to the position of the least significant digit in the most uncertain of the numbers when adding or subtracting. For example:
1000. + 0.58 = 1000.
1000. - 0.6 = 1000.
1000. + 1. = 1001.
For the result to show no impact of uncertainty is to suggest that there is no uncertainty, which is erroneous. Considering uncertainties are the result of statistical calculations and sig-fig rules are used for scientific and statistical calculations, it should go without saying that significance arithmetic is extremely relevant here.
You said, "...you can report the measured result with less or the same decimal places as the uncertainty..." I would have to disagree with the "less decimal places" part.
Q Understanding "free movement" for CE-marked products EU Medical Device Regulations 2
D High level understanding of EUDAMED EU Medical Device Regulations 3
A 60601-1 understanding of stationary device IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Qualification and Validation (including 21 CFR Part 11) 5
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Informational Health Canada has launched an e-Learning tool to aid in understanding the premarket regulatory requirements for medical devices in Canada Medical Device and FDA Regulations and Standards News 0
S Understanding UDI requirements - Class 2 medical device (hearing aids) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Informational Understanding Costs And Risks For HFE Usability Studies — Part 1: Testing In-House Medical Device and FDA Regulations and Standards News 0
P Understanding FDA draft "Management of Cybersecurity in Medical Devices" Medical Information Technology, Medical Software and Health Informatics 3
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
R Understanding a few points on ISO 9001's Design and Development Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Understanding Cycle Time - Why the time of the other activities are left out Lean in Manufacturing and Service Industries 11
J Understanding ISO 9001:2015 - 10.3 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Understanding ISO9001:2015 - 8.3: Design and Development of Products and Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
E Understanding of TS 16949 Clause 7.6.2 IATF 16949 - Automotive Quality Systems Standard 5
K Understanding IEC 60601-2-68 requirements ISO 13485:2016 - Medical Device Quality Management Systems 1
A Training material for interpretation & understanding Part 11 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
N Understanding, Challenging & Approving Supplier Control Plans FMEA and Control Plans 7
M Definition Recommendations - Understanding "recommendations" and "recommended corrective action" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
S Understanding UDI (Unique Device Identification) Other US Medical Device Regulations 10
T Understanding USP <1112> Water Activity as applicable to Medical Devices Other Medical Device and Orthopedic Related Topics 4
K Understanding Risk Management Requirements according to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S MIL-HDBK-217 - Understanding the various Environmental Conditions Reliability Analysis - Predictions, Testing and Standards 1
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
C Understanding the relationship between 62304 and the MDD ER IEC 62304 - Medical Device Software Life Cycle Processes 7
S Understanding Subgroup Size - Multi Cavity (Minitab) Statistical Analysis Tools, Techniques and SPC 4
R Understanding clause 15.4.2.1 d) of amendment 1:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M Understanding accreditation, MoUs, certifications Other ISO and International Standards and European Regulations 28
L Mobile Medical App - Understanding 21 CFR Part 820 Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Understanding and implementing ISO 17025 ISO 17025 related Discussions 9
M Understanding Versions of Collateral and Particular Standards IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Understanding, Analysis and Monitoring Quality Defects on Composite Components Statistical Analysis Tools, Techniques and SPC 3
S Understanding PMS (Post Market Surveillance) and PMCF (Vigilance and PMCF) Quality Manager and Management Related Issues 1
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
Q Beginner's Understanding - The Purpose and Applications of QMS/ISO Standards Philosophy, Gurus, Innovation and Evolution 12
Q Understanding Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
W Understanding PPAP Appearance Approval APQP and PPAP 22
V Understanding Automotive Coating for Seating Mechanism Components Manufacturing and Related Processes 1
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
H Understanding 8.2.3 M&M of Processes for our Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Understanding ISO 26262 Road Vehicle Functional Safety Other ISO and International Standards and European Regulations 2
A Understanding adoption of a product to an existing Sterilization Cycle Other US Medical Device Regulations 1
