Understanding Subgroup Size - Multi Cavity (Minitab)
SLEEPYMUM
Hi Folks,
Hope someone can help me, myself and a colleague cannot come to agreement on what the subgroup size should be when calculating Cpk in Minitab.
We have taken 10 samples containing 32 parts (32 cavities in the tool, each sample contains 1 part from each cavity).
When calculating individual cpk values from the above, I enter in the field "cavity" as the sub group size as this is the subgroup that I want to analyze.. Is this correct
When I want to look at combined Cpk should I enter in 32 as the subgroup size or 10 or cavity? - This is the one that is causing the most confusion :mg:
:thanx:
There are two issues here. The first is that you recognize that you are mixing 32 process streams into a single analysis. This may or may not cause a problem in your analysis. It will depend on how similar each cavity is to each other. I recommend that you analyze the variation from cavity to cavity vs. over time to see whether this could be an issue.
As to the second issue. This will depend on the first issue. A subgroup is comprised of those parts collected during a very small slice of time. Again we have several possibilities.
Scenario 1: the 10 process cycles were spaced out over time: If you choose to keep your process streams mixed, your subgroup size would be 32 (all cavities from a single cycle). If you choose to separate your process streams, your subgroup size would be 1 (a single cavity from a single cycle).
Scenario 2: the 10 process cycles were consecutive: If you choose to keep your process streams mixed, your subgroup size would be 320 (all cavities from all cycles). If you choose to separate your process streams, your subgroup size would be 10 (a single cavity from all cycles).
In no scenario would you use cavity as a subgroup. I do recommend that you statistically analyze whether you have differences between subgroups using ANOVA. If you can attach your data, we can assist in this.
SLEEPYMUM
Thanks Miner for your fast response.:thanks:
Please see attached data as requested.
As part of validation we have been asked to complete Cpk analysis by both cavities and combined.
All of our data is in spec, but there is a lot of variation due to some cavities being much lower than others, this is why it is failing commbined Cpk but passing on individual cavities. Hoever depending on sample size used we are almost their criteria.
I dont want to transform data unless really necessary, but I have made them aware of the cavitiy signal seen so I dont seen the need to transform it.
Your greatest source of variation is cavity-to-cavity (see boxplot). The shot-to-shot variation was very small in comparison.
Are these dimensions fixed or closure dimensions?
If fixed, you may need to do capability by cavity then close off non-capable cavities or segregate and sort if required. If they are closure dimensions, you might be able to remove material at the parting line of the mold if this will not throw out other dimensions.
Do not transform the data. This is only an option when the data are naturally non-normal such as naturally skewed. When the cause is mixed process streams, you should never try to transform the data.
i would also ask f this is a mod that will wear such that over time the values will naturally decrease as the tool wears...when this common conditions occurs it is standard practice - and a very good practice - to start at the spec limit from which the tool will wear away from. this makes Cpk values even more meaningless than normal...
K Subgroup Size - Understanding what is meant by Subgroup Size Six Sigma 13
M ISO 12944 Understanding the thickness guidlines Oil and Gas Industry Standards and Regulations 0
N Help with understanding Process Controls Manufacturing and Related Processes 7
Q Understanding "free movement" for CE-marked products EU Medical Device Regulations 2
D High level understanding of EUDAMED EU Medical Device Regulations 3
A 60601-1 understanding of stationary device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Qualification and Validation (including 21 CFR Part 11) 5
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Informational Health Canada has launched an e-Learning tool to aid in understanding the premarket regulatory requirements for medical devices in Canada Medical Device and FDA Regulations and Standards News 0
S Understanding UDI requirements - Class 2 medical device (hearing aids) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Informational Understanding Costs And Risks For HFE Usability Studies — Part 1: Testing In-House Medical Device and FDA Regulations and Standards News 0
P Understanding FDA draft "Management of Cybersecurity in Medical Devices" Medical Information Technology, Medical Software and Health Informatics 3
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
R Understanding a few points on ISO 9001's Design and Development Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Understanding Cycle Time - Why the time of the other activities are left out Lean in Manufacturing and Service Industries 11
J Understanding ISO 9001:2015 - 10.3 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Understanding ISO9001:2015 - 8.3: Design and Development of Products and Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
E Understanding of TS 16949 Clause 7.6.2 IATF 16949 - Automotive Quality Systems Standard 5
K Understanding IEC 60601-2-68 requirements ISO 13485:2016 - Medical Device Quality Management Systems 1
A Training material for interpretation & understanding Part 11 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
N Understanding, Challenging & Approving Supplier Control Plans FMEA and Control Plans 7
M Definition Recommendations - Understanding "recommendations" and "recommended corrective action" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
S Understanding UDI (Unique Device Identification) Other US Medical Device Regulations 10
T Understanding USP <1112> Water Activity as applicable to Medical Devices Other Medical Device and Orthopedic Related Topics 4
K Understanding Risk Management Requirements according to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S MIL-HDBK-217 - Understanding the various Environmental Conditions Reliability Analysis - Predictions, Testing and Standards 1
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
C Understanding the relationship between 62304 and the MDD ER IEC 62304 - Medical Device Software Life Cycle Processes 7
R Understanding clause 15.4.2.1 d) of amendment 1:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M Understanding accreditation, MoUs, certifications Other ISO and International Standards and European Regulations 28
L Mobile Medical App - Understanding 21 CFR Part 820 Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Understanding and implementing ISO 17025 ISO 17025 related Discussions 9
M Understanding Versions of Collateral and Particular Standards IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Understanding, Analysis and Monitoring Quality Defects on Composite Components Statistical Analysis Tools, Techniques and SPC 3
S Understanding PMS (Post Market Surveillance) and PMCF (Vigilance and PMCF) Quality Manager and Management Related Issues 1
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
Q Beginner's Understanding - The Purpose and Applications of QMS/ISO Standards Philosophy, Gurus, Innovation and Evolution 12
Q Understanding Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
W Understanding PPAP Appearance Approval APQP and PPAP 22
V Understanding Automotive Coating for Seating Mechanism Components Manufacturing and Related Processes 1
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
4 Understanding ILAC policy P14:12/2010 6.3 part a) General Measurement Device and Calibration Topics 28
