Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach
DuncanGibbons
Hi all,
With Operational Qualification being the understanding and characterizing process limits (worst-case scenarios) and parameters, and Performance Qualification being ensuring the reliability of the process remains within these characterized parameters and limits. From my limited understanding, DoE can be used at the OQ phase to determine which parameters are of importance but does it also ensure reliable processes as per the PQ phase or not? Additionally, are screening experiments a method that falls under the DoE principle?
Thanks,
Duncan
William55401
Typically (from my experience), there is an exploratory phase outside the scope of validation where you learn what process parameters are important. Orgs have different names for it. Engineering Eval is one. Before you execute OQ, you need to be confident that when you formally explore the corners of your process during OQ (at defined assurance levels), you will succeed. You want to enter OQ and PQ with confidence of success, Evaluations (based on DOE principles) that gather this information gets you there. Running OQ (or PQ) based on hope is not a recipe for success. Defending validations that had failures and re-execution is no fun. Your goal (coming from a compliance professional who consults on consent decrees, warning letters, 483), is to have clean boring validation packages. Product Development has a phased approach. Think of Validation in a similar manner. Often, you will need to explore the process to gain the confidence to formally execute OQ at the corners and replicate PQ at the center points. Sure, there are cases like replicate equipment where Eval may not be needed. HTH. Have fun. Enjoy the ride.
chris1price
Yes, DoE is usually used as part of the OQ (or as William55401 says, prior to the OQ) to determine which parameters have most effect on the outputs. It can also indicate how significant of a change in the parameter will have on the output. However it is not a substitute for performing the PQ which provides the evidence that you can reliably operate within the set limits.
Screening experiments are used to narrow the large field of input characteristics to a reasonable list of possible important characteristics and they often cant distinguish between main effects and interactions. typically the results of screening experiments is to then run full factorials or other smaller fractional factorials to confirm and further reduce the field to only important characteristics. then a response surface type of experiment or experiments are run to determine the tolerance zones that will provide acceptable results. these are development activities. (of course this is not the only critical characteristics and tolerances are selected.) So running a screening experiment in OQ is way too late.
OQ is intended to validate that you have determined the right input tolerances such that the output is still acceptable at the min/max of the tolerances. it is not a time for development.
Q Understanding "free movement" for CE-marked products EU Medical Device Regulations 2
D High level understanding of EUDAMED EU Medical Device Regulations 3
A 60601-1 understanding of stationary device IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Informational Health Canada has launched an e-Learning tool to aid in understanding the premarket regulatory requirements for medical devices in Canada Medical Device and FDA Regulations and Standards News 0
S Understanding UDI requirements - Class 2 medical device (hearing aids) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Informational Understanding Costs And Risks For HFE Usability Studies — Part 1: Testing In-House Medical Device and FDA Regulations and Standards News 0
P Understanding FDA draft "Management of Cybersecurity in Medical Devices" Medical Information Technology, Medical Software and Health Informatics 3
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
R Understanding a few points on ISO 9001's Design and Development Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Understanding Cycle Time - Why the time of the other activities are left out Lean in Manufacturing and Service Industries 11
J Understanding ISO 9001:2015 - 10.3 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Understanding ISO9001:2015 - 8.3: Design and Development of Products and Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
E Understanding of TS 16949 Clause 7.6.2 IATF 16949 - Automotive Quality Systems Standard 5
K Understanding IEC 60601-2-68 requirements ISO 13485:2016 - Medical Device Quality Management Systems 1
A Training material for interpretation & understanding Part 11 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
N Understanding, Challenging & Approving Supplier Control Plans FMEA and Control Plans 7
M Definition Recommendations - Understanding "recommendations" and "recommended corrective action" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
S Understanding UDI (Unique Device Identification) Other US Medical Device Regulations 10
T Understanding USP <1112> Water Activity as applicable to Medical Devices Other Medical Device and Orthopedic Related Topics 4
K Understanding Risk Management Requirements according to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S MIL-HDBK-217 - Understanding the various Environmental Conditions Reliability Analysis - Predictions, Testing and Standards 1
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
C Understanding the relationship between 62304 and the MDD ER IEC 62304 - Medical Device Software Life Cycle Processes 7
S Understanding Subgroup Size - Multi Cavity (Minitab) Statistical Analysis Tools, Techniques and SPC 4
R Understanding clause 15.4.2.1 d) of amendment 1:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M Understanding accreditation, MoUs, certifications Other ISO and International Standards and European Regulations 28
L Mobile Medical App - Understanding 21 CFR Part 820 Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Understanding and implementing ISO 17025 ISO 17025 related Discussions 9
M Understanding Versions of Collateral and Particular Standards IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Understanding, Analysis and Monitoring Quality Defects on Composite Components Statistical Analysis Tools, Techniques and SPC 3
S Understanding PMS (Post Market Surveillance) and PMCF (Vigilance and PMCF) Quality Manager and Management Related Issues 1
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
Q Beginner's Understanding - The Purpose and Applications of QMS/ISO Standards Philosophy, Gurus, Innovation and Evolution 12
Q Understanding Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
W Understanding PPAP Appearance Approval APQP and PPAP 22
V Understanding Automotive Coating for Seating Mechanism Components Manufacturing and Related Processes 1
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
4 Understanding ILAC policy P14:12/2010 6.3 part a) General Measurement Device and Calibration Topics 28
H Understanding 8.2.3 M&M of Processes for our Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Understanding ISO 26262 Road Vehicle Functional Safety Other ISO and International Standards and European Regulations 2
A Understanding adoption of a product to an existing Sterilization Cycle Other US Medical Device Regulations 1
