Understanding the general Philosophy with Complaints and CAPAs
Q
QACen
Looking to understand general philosophy with Complaints and CAPAs and get the opinion of how other QA Gurus handle it within their companies.
We generated a CAPA to capture the trend of complaints for an issue. If we receive service calls afterward that is related to the same issue. Must we transfer the service call to a complaint, route the complaint for closure in reference to the CAPA?
Thoughts?
Thank you.
Randy Lefferts
Re: Complaints and CAPAs
Thoughts?
Thank you.
Correction fixes complaint.
Corrective action fixes cause of complaint.
I am probably misunderstanding what you are asking. If you are continuing to get complaints on something that has had a corrective action assigned and closed then either a system breakdown is occuring or the correct root cause of the complaint hasn't been identified and handled.
Either way, something is amiss if you are continuing to get complaints on an item that was supposed to have been fixed by a prior corrective action.
Q
QACen
Thanks Randy. We just initiated the CAPA to do a corrective action on the issue and still working on it with our supplier. So the issue has not been resolved yet. We are continuing to receive service calls that are tied to the issue. Such service calls are documented on a service report form not a complaint form. My question was more relating to documentation.
Technicians or Engineers will make the initial determination if the service call is a complaint. If so, they will create a complaint form. (Our QA department will review the service calls throughout the month to review if whether or not service calls should be complaints.)
If a CAPA form has been documented to capture the trend. Is it necessary to document the service call on a complaint form OR can the service report be referenced to the CAPA directly. Trying to avoid an overkill of documentation. We do not specify in our processes how such should be managed. I hope this makes sense.
v9991
even if its related to same issue; we need to assess the service call... for eg.,
1)whether its report_able... (regulatory requirements)
2) whether its occurring in the areas/customers after implementation of last/previous corrective&preventive actions? (here point is whether RCA was effective are not!!!)
3) if service call is coming from new area? ( here point is whether CAPA was effective...otherwise you would not have received the call on same problem)
and depending upon above assessment, you would see if there is another investigation required, or whether CAPA needs to be strengthened...etc.,
hope this helps.:2cents:
Randy Lefferts
I just noticed this is in the Medical Device Related Standards. I am not familiar with any of these standards and what they may require you to do.
In the ISO 9001 requirements it reads :
8.5.2 Corrective action
The organization shall take action to eliminate the causes of nonconformities in order to prevent recurrence.
Corrective actions shall be appropriate to the effects of the nonconformities encountered.
A documented procedure shall be established to define requirements for
a) reviewing nonconformities (including customer complaints),
b) determining the causes of nonconformities,
c) evaluating the need for action to ensure that nonconformities do not recur,
d) determining and implementing action needed,
e) records of the results of action taken (see 4.2.4), and
f) reviewing the effectiveness of the corrective action taken.
It would be in our procedures how we handled new issues after a formal corrective action was in place. Assuming it doesn't violate your standard, I see no reason you couldn't cross reference the new service calls with the existing corrective action. So it would be up to you to define within your procedure on how you handle this. Of course, your standard may say otherwise.
Q
QACen
Thanks Randy and v9991. Great advice and believe that will help me. There are many changes I need to make to our SOPs based on last audits so I plan to definitely throw this in their.
NikkiQSM
If you continue to receive a service call on a known issue, why not send out an advisory notice of some kind. Get information from the customers before they call you?
Deep Krothapalli
On a cautious note, make sure that CAPA scope also includes service calls, as it relates to the same issue.
I think you can reference CAPA in complaint files for closure, but you would still want to include all the basic investigation details: state the issue, samples evaluation, risk assessment, MDR evaluation. You could conclude the complaint referencing that increasing trend will be addressed by CAPA.
Since you are referencing CAPA in complaint files, you would want to make sure that CAPA is addressed in timely manner.
Deep
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Reliability Analysis - Predictions, Testing and Standards 0
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Informational Health Canada has launched an e-Learning tool to aid in understanding the premarket regulatory requirements for medical devices in Canada Medical Device and FDA Regulations and Standards News 0
S Understanding UDI requirements - Class 2 medical device (hearing aids) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Informational Understanding Costs And Risks For HFE Usability Studies — Part 1: Testing In-House Medical Device and FDA Regulations and Standards News 0
P Understanding FDA draft "Management of Cybersecurity in Medical Devices" Medical Information Technology, Medical Software and Health Informatics 3
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 29
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
R Understanding a few points on ISO 9001's Design and Development Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Understanding Cycle Time - Why the time of the other activities are left out Lean in Manufacturing and Service Industries 11
J Understanding ISO 9001:2015 - 10.3 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Understanding ISO9001:2015 - 8.3: Design and Development of Products and Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
E Understanding of TS 16949 Clause 7.6.2 IATF 16949 - Automotive Quality Systems Standard 5
K Understanding IEC 60601-2-68 requirements ISO 13485:2016 - Medical Device Quality Management Systems 1
A Training material for interpretation & understanding Part 11 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
N Understanding, Challenging & Approving Supplier Control Plans FMEA and Control Plans 7
M Definition Recommendations - Understanding "recommendations" and "recommended corrective action" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
S Understanding UDI (Unique Device Identification) Other US Medical Device Regulations 10
T Understanding USP <1112> Water Activity as applicable to Medical Devices Other Medical Device and Orthopedic Related Topics 4
K Understanding Risk Management Requirements according to AS9100 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
S MIL-HDBK-217 - Understanding the various Environmental Conditions Reliability Analysis - Predictions, Testing and Standards 1
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
C Understanding the relationship between 62304 and the MDD ER IEC 62304 - Medical Device Software Life Cycle Processes 7
S Understanding Subgroup Size - Multi Cavity (Minitab) Statistical Analysis Tools, Techniques and SPC 4
R Understanding clause 15.4.2.1 d) of amendment 1:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M Understanding accreditation, MoUs, certifications Other ISO and International Standards and European Regulations 28
L Mobile Medical App - Understanding 21 CFR Part 820 Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Understanding and implementing ISO 17025 ISO 17025 related Discussions 9
M Understanding Versions of Collateral and Particular Standards IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Understanding, Analysis and Monitoring Quality Defects on Composite Components Statistical Analysis Tools, Techniques and SPC 3
S Understanding PMS (Post Market Surveillance) and PMCF (Vigilance and PMCF) Quality Manager and Management Related Issues 1
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
Q Beginner's Understanding - The Purpose and Applications of QMS/ISO Standards Philosophy, Gurus, Innovation and Evolution 12
Q Understanding Configuration Management AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 16
W Understanding PPAP Appearance Approval APQP and PPAP 19
V Understanding Automotive Coating for Seating Mechanism Components Manufacturing and Related Processes 1
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
4 Understanding ILAC policy P14:12/2010 6.3 part a) General Measurement Device and Calibration Topics 28
H Understanding 8.2.3 M&M of Processes for our Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Understanding ISO 26262 Road Vehicle Functional Safety Other ISO and International Standards and European Regulations 2
arios Understanding adoption of a product to an existing Sterilization Cycle Other US Medical Device Regulations 1
M Learning ISO 13485 - Getting a better understanding of the requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
S Understanding FDA rules regarding MDDS Status and Clinical Trials 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
G Understanding Identification of Design in QSR 21 CRF Part 820.30 Design Control (f) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Understanding DC Patient Leakage Failure from 0.3VDC IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Understanding TS 16949 Clause 8.2.3 and How to Audit according to it IATF 16949 - Automotive Quality Systems Standard 7
