Unit Dose Packaging
In modern pharmaceutical packaging, two major trends are becoming more apparent: single-dose packaging and automated packaging. The drug in the unit dose package is equivalent to a single dose. They may also contain sufficient doses only within 24 hours.
Since the 1960s, the United States has adopted unit dose dispensing system(UDDS), in which the dispensing personnel package the solid preparations (such as tablets, capsules, etc.) of the various drugs that the patient needs to take, and heat-seal the aluminum foil or the plastic bag by a sub-packaging machine and package them separately. The package is marked with the name of the drug, the indications, the dosage, the precautions, etc., so that the pharmacist, the nurse and the patient can check it by themselves. It avoids the shortcomings that the patient has not been able to identify and cannot check, which is convenient for the patient to take, prevent the wrong medicine or repeated medication, and ensure the correctness, safety and economy of the medicine.
Blister packs are commonly used as unit dose packs for pharmaceutical tablets, capsules or lozenges. This type of packaging is more portable than a bottle. Patients and caregivers can use the amount of medication left to determine if they are taking the drug.
R HV Test of HF Surgical Unit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
F UDI - Unit of Use and Class I, single-use devices EU Medical Device Regulations 4
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
M What to do in SOP Phase of Head unit testing? IATF 16949 - Automotive Quality Systems Standard 0
D Torque fractional unit of measure; cN-m or N-cm? General Measurement Device and Calibration Topics 2
M Measurement Unit Rounding Nonconformity - Notified Body Audit Registrars and Notified Bodies 6
P HVAC System vs Air Handling Unit (AHU) - Differences Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
P Fan filter unit (un-ducted to air supply) vs fan filter unit (ducted to air supply) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
K Production Unit Labeling - 21 CFR 820.184.e 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P Qualification of a Temperature Controlled Unit have to be empty? Qualification and Validation (including 21 CFR Part 11) 5
M For a Type 1 Gage R&R I want to use 1 unit and measure it 30 times Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Software Unit Acceptance Criteria (5.5.4) IEC 62304 - Medical Device Software Life Cycle Processes 3
T ISO 14001:2015 cover more than 1 company or business unit? ISO 14001:2015 Specific Discussions 13
F Setting up a new sterilization unit in a new facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R VSM - Value Stream Mapping (catheter manufacturing unit) Customer Complaints 10
A 5.5.3 - Software Unit Acceptance Criteria (Risk Control Measures) IEC 62304 - Medical Device Software Life Cycle Processes 3
A Unit of Expanded Uncertainty in Percentage General Measurement Device and Calibration Topics 4
S Is 0.1 micron monitoring required for ISO Class 5 Laminar Air Flow unit ? Other ISO and International Standards and European Regulations 4
O Can unit be categorized as EMI class A when it has EMI class B power supply in it? CE Marking (Conformité Européene) / CB Scheme 2
Z Final Validation Unit Requirements - Annex D of IEC 62366 IEC 62366 - Medical Device Usability Engineering 6
T Is IEC 61010 needed for a populated PCB within a unit? CE Marking (Conformité Européene) / CB Scheme 2
G Help with an old Spectrum 1000BX FTIR unit - User Manual wanted Manufacturing and Related Processes 2
D Calibration Cert - Measurement Unit for Nominal Value of a Calibration Resistor General Measurement Device and Calibration Topics 6
R Does dental unit need to meet the requirements of clause 14 (PEMS)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
somashekar Use of Set or Pair as Unit of Measure in the Bill of Material (BOM) Manufacturing and Related Processes 5
B Blood Bag Classification - with Disposable Centrifugal Unit for processing blood EU Medical Device Regulations 4
R Does applied part of battery powered TENS unit need to be designed as type BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
F Does the SI acronym stand for Syst?me International d'Unit?s? General Measurement Device and Calibration Topics 1
W What is the applicable standard for Chair Mounted Dental Unit for CE IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Calculating MTBF (Mean Time Between Failures) for the whole Production Unit Reliability Analysis - Predictions, Testing and Standards 2
P How to set up HSE Unit? What is the difference btw HSE Plan and HSE Manual? Occupational Health & Safety Management Standards 32
N Dental Treatment Unit (aka Dentist's Chair) requirements EU Medical Device Regulations 7
I IEC 62304:2006 Definitions - Software System, a Software Element and Software Unit IEC 62304 - Medical Device Software Life Cycle Processes 13
S How to Design the Means of Protection for Home Use Unit IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
V SPC for Continuous Steam Sterilization Unit Statistical Analysis Tools, Techniques and SPC 2
S What is the remedy if Unit level testing is not documented? IEC 62304 - Medical Device Software Life Cycle Processes 13
M Decontamination Label on Unit Packages per UL (Underwriters Laboratories) Manufacturing and Related Processes 1
E Using Customer Unit as Reference Standard General Measurement Device and Calibration Topics 14
S About Ozone Concentration's Unit "pphm" and "ppcm" Reliability Analysis - Predictions, Testing and Standards 4
B GMP Compliant Flooring for Food Manufacturing unit Food Safety - ISO 22000, HACCP (21 CFR 120) 8
W EN 61000-4-4:2004 Compliance - Electrosurgical Unit Transient Voltage Pulse EU Medical Device Regulations 3
B Minitab Gage R&R using Defect Count per Unit Area Using Minitab Software 1
M Customer Complaint vs. Repair - Unit goes out of specification after the warrenty Customer Complaints 8
S Medical Gas Change Over Unit - Which Standard to use? Other Medical Device Related Standards 4
T Validation of water system in API (Active Pharmaceutical Ingredients) unit Qualification and Validation (including 21 CFR Part 11) 5
J FMEA for PMA Data Application Package - APU (Auxiliary Power Unit) parts Federal Aviation Administration (FAA) Standards and Requirements 3
R Filter cleaning procedure for Clean Room Air Handling Unit example wanted US Food and Drug Administration (FDA) 4
M V&V (Verification and Validation) Medical Device Unit Testing ISO 13485:2016 - Medical Device Quality Management Systems 4
kedarg6500 Unit Conversion Add-in for Excel Excel .xls Spreadsheet Templates and Tools 7
R TS16949 certificate for business unit (one half of the company) IATF 16949 - Automotive Quality Systems Standard 1
