Universal Testing Machine - Calibration and Measurement Uncertainty
tututu
TuTuTu
hi, all
We have univeral testing machine and we have it calibrated according to ISO 7500
Some information given in Calibration certificate as follows
Class of machine : 1,0 (accuracy class)
Decleration of Conformity: Machine is classified without taking notice of measurement uncertainty
Measurement Uncertainty: (some values were omitted)
200 kN 0,42%
1000 kN 0,66%
2000 kN 0,70%
My questions are
a) What is the relation ship between class of machine and measurement uncertainty?
b) Can measurement uncertainty be higher than class of machine?
c) If so How can I do the conformity evaluation?
...According to class of machine or measurement uncertainty?
As far as I know for class 1,0 machines maksimum allowable error of the testing machine is %1 of reading force
G
George Weiss
Some review of the Class of machine statement has determined that a class 1 tester has a specification of 1.00%
Your calibration stated Uncertainty listed is 0.42%, 0.66%, and 0.70%
It is generally desirable to have TUR, (test uncertainty ratios), of better than 4:1, (0.25%). You are showing a worst case here of 1.4:1, which is the test uncertainty of 0.70%
The uncertainty reported should never be more than the specification being tested.
Is this calibration ISO-17025? uncertainties being reported, suggests this. With large uncertainties, the possiblity of determining the device is working correctly or not requires a guard banding approach to evaluating PASS/FAIL of test points. The magnitude of guard banding will determine the level of confidence, false pass, and false reject possibility %
If you have a question about the source and magnatude of the calibration facility's uncertainties, then I would suggest asking if they might allow you to view, or send you a copy, of the uncertainty budget calculations they used to report the 0.42%, 0.66% and 0.70%
The tension/compression measurement indication display resolution would limit the device’s best possible accuracy, and be considered in an uncertainty evaluation.
Example: 100kN, 100.0kN, 100.00kN, and etc.
In these examples the best possible accuracy/resolution would be half the least significant digit.
In cases of high uncertainty an accepted practice is the use of the equipment with current calibration data.
This would mean correcting for the errors with correction factors developed from current calibration data.
J Universal Power Cord with Adapters - IVD IEC 61010-2-101 CE Marking (Conformité Européene) / CB Scheme 6
Marc Definition UBL - Universal Business Language Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
M Universal Process Audit Form Document Control Systems, Procedures, Forms and Templates 1
N Any ULM (Universal Length Measuring device) Users? Calibration and Metrology Software and Hardware 5
A Haimer Universal 3-D Sensor Calibration - No Calibration Needed? General Measurement Device and Calibration Topics 13
G Revision Control - Per document vs Universal control Document Control Systems, Procedures, Forms and Templates 7
P Finding UMDNS (Universal Medical Device Nomenclature System) Codes Other Medical Device Related Standards 6
B Universal Medical Device vs. Global Medical Device Nomenclature Systems Other Medical Device Regulations World-Wide 2
G Universal FMEA - Small job shop stamper FMEA and Control Plans 3
J Universal phone charger approved After Work and Weekend Discussion Topics 4
M Universal Master Square/Toolmakers Surface Plate Square Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
I Laboratory for Checking Tensile Strength using UTM (Universal Tensile Machine) General Measurement Device and Calibration Topics 13
I Does Anyone know how to check Universal Tensile Machine (UTM) ? Reliability Analysis - Predictions, Testing and Standards 5
N Universal/International Symbol for Tolerance and/or Calibration Levels? General Measurement Device and Calibration Topics 7
F What the heck is Universal 57 font? MS Word asks for the font Universal 57 After Work and Weekend Discussion Topics 7
D Line clearance - Routine components in the prep room for universal use ISO 13485:2016 - Medical Device Quality Management Systems 8
B Non-sterile - Does anyone know of a universal symbol? ISO 13485:2016 - Medical Device Quality Management Systems 5
L Looking for a universal(?) example to illustrate what happens when an error occurs Nonconformance and Corrective Action 4
W Nonconformance ID tags - Seeking universal non-conforming Red Tag - Approx. 4" x 6" Document Control Systems, Procedures, Forms and Templates 3
Marc Rule discussion 2 - Universal Healthcare Coffee Break and Water Cooler Discussions 15
L Universal Studios Coffee Break and Water Cooler Discussions 2
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M Bacteriostasis/Fungistasis Testing Other Medical Device and Orthopedic Related Topics 6
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
D Essential performance and EMC immunity testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Q Summative Usability Evaluation Testing: prior or during Clinical Investigation? Human Factors and Ergonomics in Engineering 6
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Device mounted at IV pole - what about mechanical stability testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Cochlear Implant Testing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
JoCam Electrical Testing for Japan, PSE or CB Scheme Other Medical Device Regulations World-Wide 0
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
P Testing cloud-based backups IT (Information Technology) Service Management 7
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Flammability testing Reliability Analysis - Predictions, Testing and Standards 0
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
