Until when can we CE-mark and sell MDD class 1 devices?
Our company designs, manufactures and sells class 1 to 3 medical devices (dental implants, abutments and tools to places them).
Under the current MDD our class 1 devices do not require notified body authorisation for CE-marking. That will change on May 26, 2020 when most likely all those class 1 products must be submitted to the notified body in order to be CE-marked under the MDR.
1) Can we continue to produce and sell our MDD CE-marked class 1 products under our current MDD CE-certificate until it expires on 1 April 2023, or can we only sell products manufactured before May 26, 2020, and must we therefore stock up before May 26 2020 to bridge the time until those class 1 products are CE-marked according to the MDR?
2) If we completely finish the development of our new class 1 products, currently still in the R&D-stage, before 26 May 2020, can we still register them according to the MDD, and not needing notified body authorisation?
Thank very much in advance for your help.
Ronen E
Problem Solver
Moderator
I think that the above contains several misconceptions / misperceptions.
1. You don't have to wait until May 26 to submit your devices for certification under the MDR. In fact, the sooner you submit them the better for you, because by May 26 they already have to be certified - otherwise you won't be able to place them on the EU market.
2. Class I devices that begin coming under require NB certification under the MDR (e.g. reuasable surgical devices) can't benefit the "MDD grandfathering", and must by May 26 be either certified under the MDR or withheld from placement on the market until such certification.
3. Manufacturing or completion of R&D dates are irrelevant. What matters is placement on the market (i.e. first transfer of title within the EU, so import is not included), because devices have to be compliant by at the time they are placed on the market. If you are interested in "stocking up" before May 26, it has to occur "on the other end" of the first transaction inside the EU (e.g. at a cooperating distributor's warehouse).
Class I devices that continue to be exempt from were subject to NB scrutiny under the MDDR may continue to be placed on the market under valid MDD certificates even after May 26.
Asia78
2. Class I devices that require NB certification under the MDR (e.g. reuasable surgical devices & sterile devices) can't benefit the "MDD grandfathering", and must by May 26 be either certified under the MDR or withheld from placement on the market until such certification.
3. Manufacturing or completion of R&D dates are irrelevant. What matters is placement on the market (i.e. first transfer of title within the EU, so import is not included), because devices have to be compliant by the time they are placed on the market. If you are interested in "stocking up" before May 26, it has to occur "on the other end" of the first transaction inside the EU (e.g. at a cooperating distributor's warehouse).
Class I devices that continue to be exempt from NB scrutiny under the MDR may continue to be placed on the market under valid MDD certificates even after May 26.
No,that is wrong. After may 26 2020, there shall be no more mdd devices class I placed on the market in Europe (if they are not already on the market, e.g in the distribution chain). Rumors are getting stronger that there shall be a delay of the date...
But it is definitely like this, I had a long discussion with our NB on this.
Ronen E
Problem Solver
Moderator
Sorry, you are correct, in the sense that class I devices that were exempt from NB scrutiny under the MDD have to migrate to MDR compliance by May 26 in order to be placed on the market after that date (either self- or NB-certified, according to their MDR classification).
The sentence I initially wrote (last one in my previous post) didn't make sense - devices that are exempt from NB scrutiny under the MDD don't have MDD certificates... I was thinking about one thing and writing another... Sorry for that and thanks for picking up. I edited my post above so hopefully it's correct now. I also slightly edited items 2 & 3 in that post, to make them a bit more accurate.
Can you say who your NB is?
No,that is wrong. After may 26 2020, there shall be no more mdd devices class I placed on the market in Europe (if they are not already on the market, e.g in the distribution chain). (...) I had a long discussion with our NB on this.
According to the MDR, Chapter X, Article 120, § 4:
"Devices lawfully placed on the market (…) prior to 26 May 2020 (…) may continue to be made available on the market or put into service until 27 May 2025."
I interpret this as MDD CE-marked class 1 devices may continue to be sold until 27 May 2025. This should also mean that if we can get our class I products currently in development finalised and registered with the competent authorities (and thus CE-marked) before 26 May 2020, we can also continue to sell those devices until 25 May 2025, provided no significant changes are made to them.
Ronen E
Problem Solver
Moderator
You are mis-reading this.
That clause talks about units already placed on the market by May 26 2020, i.e. units which have already changed ownership once within the EU. Such units may continue to be on-sold ("made available on the market") until years later. This applies to units, not models.
If your "MDD Class I devices" (units), that are not certified (i.e. non-m/s) are already on the market by May 26 2020 then yes, they may continue to flow in the supply chain and into final use (as well as 2nd hand sales, which are completely outside the scope of the MDD and MDR). However, units of the very same model, not already on the market (i.e. past the first transaction within the EU) by May 26 can't be placed on the market unless they also comply with the MDR, even if there are units from the very same design that are circulating in the supply chain as above.
For this reason, and as I already explained above, R&D finalisation date is less (or not at all) relevant to the issue, except for units of that new design that make it onto the market before May 26.
Watchcat
On a cheery note :sarcasm:, I heard, but cannot confirm, that NB's are telling their clients that their resources for technical file audits are already booked through 2020. If you are not already on their calendar, you are out of luck. That is the NBs that have already been designated, but I think this is likely to includes the resources of the NBs that are waiting for MDR designation, and perhaps even more so.
I don't normally pass along rumors of this nature, but this one seems likely to work with the math. Newly designated NBs all seem to be following the policy of serving existing clients first. Many of their existing clients will, in addition to wanting previously MDD certified devices certified under the MDR, have additional (Class I) devices that need certification. Also, with fewer NBs, existing clients will be hard-pressed to "jump ship" to another NB. So, not much room in the queue for anyone but existing clients, and for NBs that have yet to be designated, existing clients alone probably make up a queue that could easily stretch well into 2021. And get longer every day, as MDD certificates for devices that are transitioning expire every day.
Isn't this ANVISA all over again?
D Is it okay to CE mark the product until the RoHS2 directive goes into effect? CE Marking (Conformité Européene) / CB Scheme 7
T EXCEL - How do I make the cell stay blank until a date is entered in N7? Excel .xls Spreadsheet Templates and Tools 6
S ISO 9001 Certification Renewal until 2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Weibull analysis of life time test of 8 electric motors until failure Reliability Analysis - Predictions, Testing and Standards 9
A CE Certificate is valid until 3.12.2013 - Can I still sell the products in Europe? EU Medical Device Regulations 10
Randy It's only 97 days until the 2013 DAYTONA 500 Coffee Break and Water Cooler Discussions 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
A Special 510k Update - Cease Sales and Distribution until a Decision is Rendered? Other US Medical Device Regulations 11
X Cannot Verify until Customer uses Product - Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
P CBs are not permitted to certify to AS9100 Rev C until 2011? True or False? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
D Gap Analysis - Three months until our ISO/TS 16949 3rd party surveillance audit IATF 16949 - Automotive Quality Systems Standard 4
G Until where goes ISO TS 16949 for Suppliers ? IATF 16949 - Automotive Quality Systems Standard 1
D Assessment Time - Time Taken Until In-Patient is Assessed Statistical Analysis Tools, Techniques and SPC 1
ScottK XP supported until 2012, Vista until 2011? After Work and Weekend Discussion Topics 1
A Positive Control of in-process nonconforming parts until rendered physically unusable Nonconformance and Corrective Action 3
ScottK Crud! Less than 3 weeks until the next CMQ/OE exam Professional Certifications and Degrees 11
Crusader ISO 9001 Update Delayed until the Middle of 2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Record Retention - Obsolete revisions shall be maintained until the next revision Records and Data - Quality, Legal and Other Evidence 24
R Holy liftin' - 11 days left until I become a Mrs.! Coffee Break and Water Cooler Discussions 32
V ISO Review of TS 16949 Extended until approximately 2008 IATF 16949 - Automotive Quality Systems Standard 12
Wes Bucey To sue, or not to sue: That is the question until you are the person bringing suit... Coffee Break and Water Cooler Discussions 73
T How long until we get 'Official Paper' Certificate? Registrars and Notified Bodies 6
S Purchasing Procedure - Purchasing process is not complete until product is received? IATF 16949 - Automotive Quality Systems Standard 11
S Audited against ISO 9002/3/1:1994 until December 2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D PPAP parts held until new PPAP APQP and PPAP 1
T CE Marking - Bench mark Device from same manufacturer CE Marking (Conformité Européene) / CB Scheme 2
V New Product Model CE Mark Certification under MDR EU Medical Device Regulations 0
P Violation of CE mark - Re-use of single-use Products CE Marking (Conformité Européene) / CB Scheme 2
K One CE Mark holder - multiple manufacturing sites EU Medical Device Regulations 3
A First CE-mark class III implantable device under MDD EU Medical Device Regulations 8
F List of countries that 'prefer' a CE Mark CE Marking (Conformité Européene) / CB Scheme 1
C Surgical mask stability testing (CE mark) EU Medical Device Regulations 2
M MDR EU Distributor for our CE Mark product in the for Netherlands EU Medical Device Regulations 6
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
Ed Panek CE Mark Requirements on Kits (off the shelf product requirements met) CE Marking (Conformité Européene) / CB Scheme 2
R IVDR CE Mark for Class A products - Declaration of Conformity CE Marking (Conformité Européene) / CB Scheme 2
G UVC sterilizer CE Mark CE Marking (Conformité Européene) / CB Scheme 5
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
M CE Mark and 510(k) -Global registration requirements for every country Other Medical Device Regulations World-Wide 3
A CE Mark and PMCF study EU Medical Device Regulations 3
T CE mark start date for a device EU Medical Device Regulations 7
P API monogram mark requirements Oil and Gas Industry Standards and Regulations 1
S CE Mark - Classification Confusion EU Medical Device Regulations 12
N CE Mark for Class 1 medical device CE Marking (Conformité Européene) / CB Scheme 11
Y CE Mark - Placing the CE mark on medical device labels EU Medical Device Regulations 2
B Need For BIS Standard Mark? Imported OEM's Power supply,Li-Ion Battery Other Medical Device Regulations World-Wide 0
D Vietnam requirement of CE mark for medical devices CE Marking (Conformité Européene) / CB Scheme 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
S CE mark on a medical device - Textile product CE Marking (Conformité Européene) / CB Scheme 2
V CE Mark under MDD or IVDR - IVD company doing Virtual Manufacturing Other Medical Device Regulations World-Wide 3
