Update Technical File for EU Class IIa Medical Software Products
joy.jian
During my process of putting together a technical file for an existing product but new software version, I started to doubt myself if I understand the concept of technical file correctly. We make Class IIa medical image processing software.
Here are my questions:
1. For the same software product family but new version, is it necessary to create a brand new stand-alone technical file?
For example, we have technical files for v2.1, v2.2, v3.1 etc, using the same format. Most contents are identical (ISO certificate, essential requirement checklists, intended use, etc.); some files need to be updated periodically (clinical evaluation report, risk management report, etc.); and some files are version-specific (IFUs, DMR, DHF, etc.)
My concern about keeping a non version-specific TF is that v3.1 does not replace v2.1 or v2.2 - they coexist on the market. The problem though is that the software evolves so quick that a new TF is required almost every few months.​
2. Is Technical File a living document? Or it only captures information at the time of creation?
Currently we create a TF when the new software version is picked for mass distribution. For instance, no TF was created for v2.3-2.9 since they are maintenance release.​
3. When is it necessary to submit a TH for notified body review?
NSAI reviewed our v2.2 TF, and v3.1 is decided to be the next major release accessible by all clients. Should we have NSAI approve our v3.1 TF before distributing it to customers?​
Any advice on the proper way of managing software Technical File is greatly appreciated! Thank you for your time.
Regards,
Joy
Al Rosen
The Technical File is a living document. The documents do not have to reside in the same location. You can create an index that lists or references the documents and their locations. If you identify the version information on the index, then each time you change the version, the index revision level will change. This can all be done according to your document control system.
yodon
Mr. Rosen's feedback is spot on but you included another question that probably warrants additional discussion.
This is a tricky question and the answer depends on the changes. Did the changes impact the indications for use? Did the changes impact the risk assessment?
I don't know if a full Technical File review would be required but I believe you're expected to at least inform the NB about the changes - especially if they are "significant."
suildur
The best way to decide is to contact your NB while the new version may differ in very different ways from the previous one. However there are some general answers to your questions.
(1) The product family is a tricky definition. Do you use it as a quality standard definition or a business definition? For instance, composite fillings (which are used instead of amalgams) are almost identical with composite bondings (ingredients are almost the same with different proportions), but the intended use and all other stuff are different. On the other hand, if you mean there is product family and there are types and models under this family, then it is okay to merge them in a single technical file. However, you must define every variation for each product. For example, you can even use 4 different brands for a single product, but you must submit 4 different IFU, label, packaging drawings etc for each brand in the technical file (you must also define that you use 4 different brands for that single product).
(2) It is a living documentation. It is so alive that sometimes it kills you to manage it :)
(3) If any info has to be changed in your technical file (including the QMS elements related to technical file documentation; for example a revision or a change in the production method), then you must contact your NB before making the change, so that they can approve it. Otherwise, you would be releasing a product to the market which is not approved by the NB which also means you violate the regulation.
A When will ISO13485 Update be Released? EU Medical Device Regulations 1
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Sidney Vianna IATF 16949 News Update on the IATF CARA Project (“Common Audit Report Application”) - 12/2020 IATF 16949 - Automotive Quality Systems Standard 1
M Trigger to update of TLL VDA Standards - Germany's Automotive Standards 0
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
D GMDN code update - Canada - Do you know if there is guidance? Canada Medical Device Regulations 0
Ninja Windows 10 100 % disk use after update Coffee Break and Water Cooler Discussions 33
mike10 QMS Update - Rev. up or start over? Document Control Systems, Procedures, Forms and Templates 3
M Do we need to create a new CER or can we just update the existing CER EU Medical Device Regulations 3
dgrainger Informational MHRA guidance update on withdrawal of Notified Bodies Medical Device and FDA Regulations and Standards News 0
F Software development plan for SW update IEC 62304 - Medical Device Software Life Cycle Processes 2
M Informational Update on ISO TC 210 JWG 1 activities Medical Device and FDA Regulations and Standards News 0
M Informational EU – October 2019 update – State-of-play of joint assessments of Notified Bodies in the medical device sector Medical Device and FDA Regulations and Standards News 2
M Informational US FDA Final and update guidances – Software Medical Device and FDA Regulations and Standards News 2
M Informational From Medtech Insight – QSR/ISO 13485 Harmonization Update: FDA Enforcement Discretion Likely When New Rule Stands Up; Draft Reg Coming By Year’s End; Medical Device and FDA Regulations and Standards News 0
M Informational Update from GOV.UK – Regulating medical devices in the event of a no-deal Brexit – UK Responsible Person Medical Device and FDA Regulations and Standards News 0
M Informational Device Shortages Update – The US FDA Announces Two New Innovation Challenges on Device Sterilization Medical Device and FDA Regulations and Standards News 0
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
M Informational Update – MDR and IVDR implementing measures rolling plan – 2 more NBs designated under the new regulations Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Digital Health Update: Mid-Year Update on Software Precertification Program Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Device Shortages Update: Challenges to encourage the development of new approaches to device sterilization Medical Device and FDA Regulations and Standards News 0
M Informational MHRA update – Medical devices: guidance for manufacturers on vigilance - June 2019 Medical Device and FDA Regulations and Standards News 0
M Is it compulsory to update the obsolete GMDN codes in ARTG? Other Medical Device Regulations World-Wide 4
M Informational USFDA – Digital Health Update: The FDA Announces an Opportunity for Test Case Volunteers for the Test Plan for the Software Precertification Program Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Guidance update – Requests for Feedback and Meetings for Medical Device Submissions: The Q-Submission Program Medical Device and FDA Regulations and Standards News 0
M Informational TGA – Webinar: An update on the consultation for the Regulation of Software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 0
M Informational EU – Update on state-of-play of joint assessments of Notified Bodies in the medical device sector Medical Device and FDA Regulations and Standards News 1
E Gamma Sterilization Product Update Manufacturing and Related Processes 2
M Informational EU – April 2019 update of the MDR and IVDR implementing measures rolling plan Medical Device and FDA Regulations and Standards News 0
B IEC 62304 - Update Checklist IEC 62304 - Medical Device Software Life Cycle Processes 2
M Informational ISO 14971 / ISO TR 24971 revision update – atualizações sobre a revisão Medical Device and FDA Regulations and Standards News 1
M Informational IMDRF – Proposed update to Clinical Evaluation documents Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
C Do we need to make a new OFI (Opportunity for Improvement) for each document/form we update? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
M Medical Device News Last update of the MDR and IVDR implementing measures rolling plan – December 2018 Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA Digital Health Update – New actions and documents Medical Device and FDA Regulations and Standards News 0
M FDA News Digital Health Update: USFDA Report on Non-Device Software Functions Now Available Medical Device and FDA Regulations and Standards News 0
M Medical Device News Letter to the health and care sector: update on preparations for a potential no-deal Brexit Medical Device and FDA Regulations and Standards News 0
Marc Software Update 23 November 2018 Forum News and General Information 1
M Medical Device News Joint Action On Market Surveillance Of Medical Devices (JAMS) Releases Progress Update EU Medical Device Regulations 0
Marc Attachment List Update - 2018-11-16 Forum News and General Information 0
K Medical Device Software Update in Field of AIMD IEC 62304 - Medical Device Software Life Cycle Processes 1
M Medical Device News Health Canada update - Applications for Medical Device Investigational Testing Authorizations Canada Medical Device Regulations 0
M Medical Device News IMDRF update - 26-09-18 - Cybersecurity, Premarket Reviews, Personalized Devices Other Medical Device Regulations World-Wide 0
M Medical Device News TGA update 26-09-18 - Medical Devices Safety Update, Volume 6 September 2018 Other Medical Device Regulations World-Wide 0
M Medical Device News Health Canada Update - 05-09-18 - Pilot Device Advice Canada Medical Device Regulations 0
S How to enforce my colleagues to update SOPs? Document Control Systems, Procedures, Forms and Templates 4
M Medical Device News Health Canada update 28-08-18 - Licensing Requirements for 3D-Printed Devices Canada Medical Device Regulations 0
Marc 2018 Software update - Donations Appreciated Forum News and General Information 21
L Re-calibrate after software update? Calibration Frequency (Interval) 3
