Updates to Technical Documentation
Philip B
We submitted our technical documentation for assessment to the MDR back in August and are still awaiting the review. We've been told by our NB that we can't make changes to the TD in the meantime. However, TD is a live thing and regular updates are necessary and we have several updates to make (updated VMP, CER etc). I've ended up with with two parallel TD files, one frozen since August and a live one I am updating. I wondered how others have handled this?
engemerson
you cannot make changes while you are under review by the NB, only after approval you could make the appropriate change, submit the technical documentation for review with the NB after approval, you can disclose it.
the structure of your documentation has to be like this:
3 folders (example)
FOLDER 1: CURRENT TECHNICAL FILE
FOLDER 2: TECHNICAL FILE AWAITING NB APPROVAL
FOLDER 3: OBSOLETE TECHNICAL FILE
no modifications can be made while transitioning from MDD 93/42 to MDR 745
see article 120 of MDR 745
Philip B
I've just re-read article 120 and it doesn't mention anything to do with the question I asked.
Five months (and counting) is a long time to keep your technical file frozen, we make regular updates normally (not to major things like intended use or design of course). Keeping your file updated seems to me to be a key regulatory and QMS requirement and I worry this will be a 'damned if you do, damned if you don't' NB situation.
engemerson
durante o processo de transição, não pode haver mudanças significativas que possam alterar o design, a indicação, o uso pretendido ou a finalidade.
no entanto, as atualizações devem ser baseadas no MDD, pois você não pode fazer a avaliação de conformidade da alteração com base no MDR, pois ainda não possui o certificado MDR.
ajustes como revisões de normas, nomenclaturas de gêneros podem ser atualizados, mas aconselho que informe seu RN sobre a mudança.
tivemos uma auditoria para a transição do MDD para o MDR e tudo isso foi apontado como não conformidade, pois fiz alterações na documentação técnica e enviei para análise, e tenho que ter dois documentos técnicos:
a corrente com base no MDD revisado
ou em processo de revisão com base no MDR.
veja este link abaixo.
Code:
https://www.advenamedical.com/authorised-representative/mdr-article-120-transitional-provisions/
twanmul
Translated for those who are too lazy
during the transition process, there can be no significant changes that may alter the design, indication, intended use, or purpose. however, updates must be MDD-based because you cannot do the mdr-based change compliance assessment because you do not already have the MDR certificate. adjustments such as revisions of standards, gender nomenclatures can be updated, but I advise you to inform your RN about the change. we had an audit for the transition from MDD to MDR and all this was pointed out as non-compliance, because I made changes in the technical documentation and sent it for analysis, and I have to have two technical documents: the current based on the revised MDD review process based on the MDR. see this link below.
From my experience, we have a "changes required log" in our QMS allocated to specific technical document references and a dedicated change window for our Technical Documentation to be updated and issued (kind of like the football player transfer window, just for these document change requests to be included in). This means that we spend less time on a routine basis updating our documentation for routine or minor changes and have the flexibility to be able to update if there is something really important or high risk that needs incorporating into the TD. This does take some quite detailed reconciliation when it comes to updating but does prevent the specific issue you've got here.
engemerson
Your analysis is correct about the updates.
there are two areas, the current MDD according to the validity period of the certified seru, and the other area is to review the documentation in compliance with the requirements of the MDR.
what has to be described in your procedures that significant changes must be communicated to your notified body (NB) and detail in the procedure what are significant changes.
the rest of the updates that are necessary, carry out as determined by the documentation of your QMS.
this conformity assessment will be reviewed by the auditor when performing a transition and monitoring audit.
Philip B
Thanks Twanmul
Ed Panek
QA RA Small Med Dev Company
This is similar I imagine to any regulatory dossier under review.
For any regulatory submission, it's expected that changes to details will occur. The question is how does it meet MDCG or FDA guidance on a substantial change. If mid review a major change is made I think the submission planning was not done well or something unpleasant happened..
I suggest you have a benchmark dossier that represents the actual approval conditions. From there letters or memos to file regarding small incremental changes to bring it up to speed. We made it a habit for EVERY change to device or QMS I write a memo comparing the change to the MDD/MDR and FDA guidance and the rationale why it doesn't require regulatory re-approval. We also discuss cumulative changes over the year at Management Review and why we will or will not alert FDA or EU about them.
T Technical Directives (TD's) not used for Technical Updates - Audit Nonconformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Technical File Updates and Notified Body Notification EU Medical Device Regulations 5
R What function normally updates/maintains the Technical File? EU Medical Device Regulations 11
M Subscribe to harmonized standards updates EU Medical Device Regulations 5
B Risk Management Procedure updates needed for 14971:2019 ISO 14971 - Medical Device Risk Management 11
G Updating FMEAs after Design Updates FMEA and Control Plans 4
Z Over The Air (OTA) updates for medical device Other US Medical Device Regulations 1
Y Software updates considered servicing (7.5.4) ISO 13485:2016 - Medical Device Quality Management Systems 4
S Regular updates of clinical evaluation report EU Medical Device Regulations 6
M Find updates to REACH and Rohs regulations REACH and RoHS Conversations 1
K Software Updates in the Field and ISO scope ISO 13485:2016 - Medical Device Quality Management Systems 2
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
H Layered audit updates after COVID-19 shutdowns Process Audits and Layered Process Audits 0
R Plea for advice on transitioning between Notified Bodies (label updates) Medical Device and FDA Regulations and Standards News 1
I Revision History Date - date of updates or date of release? ISO 13485:2016 - Medical Device Quality Management Systems 2
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
U What is the process for making updates to our Processes? Design and Development of Products and Processes 11
M Informational US – MITA UPDATES SERVICING AND REMANUFACTURING WHITE PAPER Medical Device and FDA Regulations and Standards News 0
M Informational Several revised or updates USFDA guidance - 9/9/2019 Medical Device and FDA Regulations and Standards News 12
K Unique Device Identifier for updates to legacy standalone software Other US Medical Device Regulations 1
M CER (Clinical Evaluation Reports) updates - Product Codes EU Medical Device Regulations 2
V Who should define and own the Design and Development Plan and how to maintain the updates and revisions. ISO 13485:2016 - Medical Device Quality Management Systems 2
G KPC & KCC verification and updates FMEA and Control Plans 15
M Informational US FDA – FDA provides updates on the agency’s continued commitment to evaluating postmarket safety of Essure device Medical Device and FDA Regulations and Standards News 0
C Updates on Documentation for outsourced OEM from ISO 13485:2003 to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 4
K Risk Analysis Updates due to complaints ISO 14971 - Medical Device Risk Management 10
M Medical Device News FDA News - 27-08-18 - 2018 Learning program and GUDID updates Other US Medical Device Regulations 0
M Updates to EN 62366 & ISO 14971? Other Medical Device Related Standards 3
B Company Name Change - ETL Labels and Report Updates CE Marking (Conformité Européene) / CB Scheme 2
C Change Order necessary to document FMEA Updates? FMEA and Control Plans 1
F Quality Manual Updates - ISO 9001:2015 and API Q1 9th Editition Quality Management System (QMS) Manuals 15
Booker Update our PFMEA after Supplier updates their PFMEA? FMEA and Control Plans 4
M Updates on proposed EU Medical Device Regulations - June 2016 EU Medical Device Regulations 20
Q FDA - Annual Report Submission Format and QMS updates Other US Medical Device Regulations 2
M FDA's expectation for validating OTS software updates Other US Medical Device Regulations 8
M Automated Revision Updates - Notifications of new revisions for ISO's to subscribers Document Control Systems, Procedures, Forms and Templates 2
E Design Dossier/DHF Updates - What to Keep EU Medical Device Regulations 2
Jim Wynne Windows 8.1: No Security Updates Without Update 1 After Work and Weekend Discussion Topics 4
T Select Updates for Non-Clinical Engineering Tests - Intravascular Stents Other US Medical Device Regulations 0
Sam Lazzara February 2013 Medical Device "State-of-the-Art" updates Other Medical Device Related Standards 6
Ronen E Updates to FDA standards recognition - Aug 2012 Other US Medical Device Regulations 0
BradM Class action lawsuit against Apple - iPod Software updates - 2006 thru 2009 After Work and Weekend Discussion Topics 2
M ISO TS 24971 Updates and formal objection of the European Commission to ISO 14971 ISO 14971 - Medical Device Risk Management 24
A Current Control Periodic Document Reviews - Process Updates in the FMEA FMEA and Control Plans 3
Mikey324 How to Check for Legal (OSHA Federal & State) Updates Occupational Health & Safety Management Standards 5
G Recent Updates to 21 CFR Part 820? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Predicate Device Requirements - Firmware vs. Software Updates 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
H Paper based DHF (Design History File) updates for Software Updates 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Regulatory Requirement Updates? Medical Device Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 6
Sam Lazzara US FDA CFRs April 1, 2010 updates are live Other US Medical Device Regulations 0
