Upgrading to TS 16949 - A Management Overview and Kickoff Document
rdd007
Hi ... I recently created a management overview for a client who is upgrading to TS from ISO (though I have to say they've been stuck with an auditor who follows the more elemental older version of ISO) -- Since I got so much from the Cove, I thought I'd share it in turn ...
I'd appreciate any comments ... Thanks
Ray
Jen Kirley
Quality and Auditing Expert
Re: Upgrading to TS -- Management Overview Doc
I have just a couple of thoughts on this.
The presentation looks very nice, but I was wondering about what you used to base your articulations of things like philosophy, focus, and differences.
Some of us find TS pretty prescriptive, and I have to question if "two major methods are usually used [to define and document a process] because they capture and display so much information". I usually see written process documents, and have found not very many people are skilled at making flow charts and turtle diagrams to describe their processes.
So I wonder how objective your presentation's material is.
E Wall
Just Me!
Hi ... I recently created a management overview ...
Really seems odd to me that the focus of transition was from 9001:1994 rather than v2000 which is completely different. I can only presume it was done based on this comment:
...they've been stuck with an auditor who follows the more elemental older version of ISO...
That being said, if I were in the management team, I would have an issue with construction of a presentation that isn't based on the actual active standard the organization is certified to. I would want to know what actual changes should be needed. If the org is not where they ought be, that should be clarified also in same presentation. In this way the management team would have sufficient information to make all appropriate changes needed.
My additional concern: You don't mention if this auditor is internal or external to the organization, but someone should adviise that replacement or retraining is necessary.
Q
QSRFUN
Ray
I think you really hit it with Page 6 (procedures ~vs~ processes). I am not sure that the mgmt. level at a lot of companies really even understands a lot of this but hopefully you can get through to a few. (I just mean that a lot of them think it's a "quality" thing and would rather ignore it and let someone else worry about it.)
I did the same thing (TS to ISO9001:2k) last year so I know what you are going through......keep going.....:O)
RickT
I find it fascinating when reading overviews of ISO/TS 16949, that most seem to ignore clause 0.5 which is the goal of TS. Interestingly enough has not changed from that of QS-9000.
It contains 5 points which they expect to find throughout the QMS
1. Continual Improvement
2. Defect Prevention
3. Reduction of Variation
4. Reduction of Waste
5. Customer Specific Requirements.
Raffy
Hi Ray,
What we did is to create a roadmap using the project approach. Phase 1 – Appraisal & Planning. Phase 2 – Documenting the System. Phase 3 – Operational and Implementation. Phase 4 – Registration.
Hope this helps.
Best regards,
Raffy:cool:
Cats Clause Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
H Upgrading ISO 9001 to TS 16949 - Plastic injection molding company IATF 16949 - Automotive Quality Systems Standard 13
B Upgrading our QS-9000 system to TS 16949 - Where do I start? IATF 16949 - Automotive Quality Systems Standard 6
T Are registrars taking a harder line on upgrading QS-9000 certs to TS 16949? Registrars and Notified Bodies 10
L Upgrading to TS 16949 from QS-9000 IATF 16949 - Automotive Quality Systems Standard 7
G Upgrading: ISO 9001:2000 to TS 16949 IATF 16949 - Automotive Quality Systems Standard 3
R 'Upgrading' to TS 16949:2002 from QS-9000 IATF 16949 - Automotive Quality Systems Standard 2
Marc Your opinion on upgrading to Xenforo 2.2 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 5
shrutisancheti Upgrading medical device at healthcare establishments (user facility) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Upgrading Systems from CFR 211 to CFR 820 (drug+device combination) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
T Reduced Audit days when UPGRADING from AS9100 to TS16949 - Is it possible? IATF 16949 - Automotive Quality Systems Standard 2
C Upgrading an old Supermicrometer General Measurement Device and Calibration Topics 3
R QMS System Upgrading - Should the HSE and Finance functions be included? Quality Manager and Management Related Issues 15
T Upgrading to AS9120A - Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N Template for a Quality Plan upgrading to ISO 13485 from ISO 9001 ISO 13485:2016 - Medical Device Quality Management Systems 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Upgrading of QMS from ISO 9001 to ISO 13485 - Quality Manual Revision ISO 13485:2016 - Medical Device Quality Management Systems 5
N Upgrading ISO 13485:2003 QMS to FDA 21 CFR 820 Compliance ISO 13485:2016 - Medical Device Quality Management Systems 1
W Questions about upgrading from ISO 9001 to ISO 13485 or do I have both? ISO 13485:2016 - Medical Device Quality Management Systems 13
J Upgrading an existing Management System into a full-fledge QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
J Upgrading ISO9001 to ISO13485 - Relationship of ISO9001 to ISO13485? Registrars and Notified Bodies 7
Claes Gefvenberg Upgrading the Windows OS PC? After Work and Weekend Discussion Topics 29
A Upgrading from ISO9001:2000 to AS9120 - Difficulties? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
M Criteria for Auditor Selection and upgrading their auditing skills General Auditing Discussions 6
N Upgrading to ISO 9000:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Procedures - New Revision or Original Issue - Upgrading to ISO9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R QS Shop upgrading to ISO 9K2K QS-9000 - American Automotive Manufacturers Standard 1
Marc Upgrading to ISO 9001:2000 - Changing Documentation Document Control Systems, Procedures, Forms and Templates 4
C IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records IATF 16949 - Automotive Quality Systems Standard 15
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 6
O IATF 16949 News Upcoming Changes to IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
V IATF 16949 GM CSR 10.2.4 Error-proofing requirement IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 Clause 7.2.2 - On the job training IATF 16949 - Automotive Quality Systems Standard 2
L IATF 16949 8.3 Exclusions Manufacturing and Related Processes 5
H Clause matrix for 16949 IATF 16949 - Automotive Quality Systems Standard 3
D IATF 16949 7.3.1 Awareness- Supplemental IATF 16949 - Automotive Quality Systems Standard 2
Q IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J Implementation, establishment and certification of IATF 16949. IATF 16949 - Automotive Quality Systems Standard 6
xfngrs 3 year audit cycle IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
D IATF 16949 Process Map IATF 16949 - Automotive Quality Systems Standard 19
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
D IATF 16949 Certification and Letter of Conformance expiry (Help!!!) IATF 16949 - Automotive Quality Systems Standard 8
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
T Justification of "Design Excluded" in IATF 16949 Design and Development of Products and Processes 5
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
Ron Rompen IATF 16949 8.5.1.4 IATF 16949 - Automotive Quality Systems Standard 7
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
