Usage of Calibrated Equipment - Vernier Caliper
anil123
The vernier caliper was calibrated and found OK. However it was not taken for the use till its next calibration due date and after the due date it was taken for the use. Does this caliper can be taken as it is for the usage. Please guide.
Stijloor
Re: Usage of calibrated equipment
If it can indeed be verified that the caliper has not been used (because it was in storage), the calibration due date can be extended and the caliper can be issued for use. Now, if this caliper is used on a very infrequent basis, why not specifying: "calibrate prior to use"? The standard (in 7.6) gives you that option too.
Stijloor.
N
NANDAKUMAR_A
Dear Mr.Anil,
In my view , it is not necessary and again it depends on the duration of storage and preservation.
However for audit purpose we can corss verify any reference value and record before use , to ensure the validity of Calibration.
Nandakumar
Ron Rompen
While both Stijloor and Nandakumar are correct, in my experience it is difficult to ensure that the suggested process (extend date, calibrate prior to use, cross-reference to standards prior to use) is consistently followed out, and to provide evidence that it is.
As a general guideline, I would suggest performing the calibration as scheduled; this is not an onerous or time-consuming task, and will (probably) be easier in the long run.
Stijloor
Time and cost should be considered as well.
Stijloor.
silentrunning
Could you use this tool and then send it out for calibration / verification? If you quarantined the product until the accuracy was verified, it seems this would be acceptable. Comments?
Also, if you were going to extend the calibration date, wouldn't there have to be a written provision for this in your procedures?
Doug
DrM2u
Doug
Assuming that there is a documented procedure, having a written provision does not guarantee that the procedure is followed (see Ron's comment).
From various practices that I have encountered in the past, there is one that made most sense to me. Some companies (and many calibration software packages) keep records of the verification/calibration date and the date the equipment is placed in use. The verification/calibration interval starts when the equipment is placed in use and is followed regardless of how much or how little the equipment is used during said period of time. The verification/calibration records and results are used to determine any need to adjust the frequency. This way the equipment is not verified/calibrated when there is no need for it (time and cost savings) and is verified/calibrated at established time intervals OF USE to ensure suitability and reliability of the measurement results (part of clause 7.6, I think). Of course, this approach is valid only for inspection & test equipment that does not change its calibration condition over time if not used. A vernier caliper is probably one of the most rugged variable gauges in use.
dhghan
We set our caibration due date every 2 years instaed of yearly.This is set after the equipment for 2 continous yearly calbration period show that the accuracy is consistent. Any comments on this?:)
U
Umang Vidyarthi
It depends upon the following:
1. What your procedure says?
If your procedure strictly requires you to adhere to the calibration cycle, then you do not have any option.
2. How is your calibration cycle arrived at?
Calibration cycle needs to be determined in accordance with the usage. A vernier caliper used on production line will have a shorter calib.cycle than the one used by the inspection guy.(This does not apply to instruments which are affected by weather conditions vis heat, humidity etc.)
3. Do you maintain issuance record of all the instruments?
If your procedure permits and your recods verify that the instrument was not in use for the said period, then you can skip the calib.cycle.
As stated above, the calib cycle has to be determined in accordance to its usage. Hence the 2 yrs. cycle, arrived at in your case, is perfectly okay.
Umang :D
Z 510(k) usage - Company has 2 physically similar products Medical Device and FDA Regulations and Standards News 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
A Query regarding MS Excel usage Excel .xls Spreadsheet Templates and Tools 2
V System suitability or stability during continuous usage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
T CMM measurement and usage in the Automotive Industry Calibration and Metrology Software and Hardware 2
B M&TE (Measurement and Test Equipment) Usage Records (Logs) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Usage of Parts from OQ (Operational Qualification) Mold Validation ISO 13485:2016 - Medical Device Quality Management Systems 4
E IEC & UL 60601-1 Plastics Flammability - Guidance on flame-rated plastics usage IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
K Calibration Interval based on Usage Calibration Frequency (Interval) 14
P Effective Road Usage Coffee Break and Water Cooler Discussions 9
K Autoclave Log - Do we have to monitor the usage for every load? General Measurement Device and Calibration Topics 3
M How to analyse document usage for Sharepoint? Document Control Systems, Procedures, Forms and Templates 4
renenatasha Usage of web articles in DHF (Design History File) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
G Usage and Calibration History for Calibration Frequency AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Function for Effects - Beginner in usage of the IQRM FMEA and Control Plans 3
D Off Label Usage (Class II Medical Device - Blood Bank Software) US Food and Drug Administration (FDA) 3
E Test Data Accuracy Usage - Ethics Capability, Accuracy and Stability - Processes, Machines, etc. 6
P DFX & DFLSS (DFSS) Techniques & Processes - Real world example of the usage Six Sigma 1
C Stability Trials (Shelf Life, Expiry and Usage Dates, etc.) for Medical Devices Design and Development of Products and Processes 4
P Relationship between Crimping ID & Crimping Depth - Minitab usage Statistical Analysis Tools, Techniques and SPC 3
T Disinfectant usage in a Clean Room Setting procedure ISO 13485:2016 - Medical Device Quality Management Systems 6
G Question concerning process troubleshooting and process FMEA usage in job shops FMEA and Control Plans 5
M An Honest Gauge R&R Analysis - Proposed usage of Donald Wheeler Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
Crusader Company Policy about Internet Usage and Access Coffee Break and Water Cooler Discussions 10
G Adjusted Control Limits - Usage of Control Charts Statistical Analysis Tools, Techniques and SPC 26
S Auditor Credential, usage of General Auditing Discussions 8
K Bar coding of gages on usage instead of time General Measurement Device and Calibration Topics 4
B Identifying Peak Demand and Usage with Start/End Time - Hospital Hospitals, Clinics & other Health Care Providers 3
P Aspect & Impact Assessment For Electricity Consumption and water usage ISO 14001:2015 Specific Discussions 2
C Ignorant Cell Phone Usage (Cell Phone Etiquette) Coffee Break and Water Cooler Discussions 24
M Approval vs. Point of Release and Concession Usage Document Control Systems, Procedures, Forms and Templates 1
B Case studies of 8D usage in non- automotive industries, administration areas needed Nonconformance and Corrective Action 0
S Develop and Train Project Management Team in Effective APQP Usage APQP and PPAP 5
A Engineering Manual for general usage for our engineer group Document Control Systems, Procedures, Forms and Templates 2
S Best way to learn Minitab Usage Using Minitab Software 9
S Usage Log - Calculating Time Difference in Excel - Start time and end time Excel .xls Spreadsheet Templates and Tools 21
S Company Internet / Email Usage Policy Document Control Systems, Procedures, Forms and Templates 3
T Conducting an Energy Usage Audit - Seeking template or form Miscellaneous Environmental Standards and EMS Related Discussions 3
B Radical attempt to increase usage of public transport in Newport, South Wales Coffee Break and Water Cooler Discussions 0
A Computer usage in statistical calculation & inspection activities Statistical Analysis Tools, Techniques and SPC 5
M Lever type dial gauge - Usage of a dimensional 'test indicator' for measurement General Measurement Device and Calibration Topics 10
A Customer not willing to reveal the usage or function of the part to the supplier Philosophy, Gurus, Innovation and Evolution 18
M Documentation and Usage of Work Instructions Document Control Systems, Procedures, Forms and Templates 6
H Real World Usage Profile Statistical Analysis Tools, Techniques and SPC 4
M Renault vs. AIAG FMEA - Would like details of it's usage and any training aids FMEA and Control Plans 4
W Acceptable Quality Levels (AQL) - What is the usage of AQL 100 to 1000? AQL - Acceptable Quality Level 10
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
G Can calibrated device values be used instead of manufacturers spec? General Measurement Device and Calibration Topics 2
M Where to obtain a calibrated DICOM image? ISO 13485:2016 - Medical Device Quality Management Systems 1
