Use of Exact Text with the Graphical Symbols in User Guides
sreenu927
Hi All-
Is it mandatory to have the exact text of symbols in the user guides?
For example - on the label, if we use the the "open book with "i" symbol, and can we use the similar text having the same intent or the exact text from the EN 980 or ISO 15223 as such - "see user documentation" or "consult instructions for use.
And for temperature symbol - "temperature limit" as per the ISO 15223 std or a similar verbiage like "upper and lower limits of temperature" or "range of temperature?
Thanks,
Sreenu
sreenu927
Hi J0anne,
Thanks. In between, could you pls share what exactly it was indicated in pg3. Sorry, I think, my subscription was expired with Techstreet and unable to open the std.
Thanks,
Sreenu
drewsky1
I have a similar question in regards to ISO15223and the title of the symbol for Do Not Re-use. There is a note (see below) that speaks to synonyms for Do Not Re-use. Is is acceptable to use one of the synonyms such as "Single Use" instead of Do Not Re-use? Currently our labeling has the text "Sngle Use" beside this symbol and we feel it is okay to leave as is and still be compliant to ISO 15223. Does anyone agree/disagree?
5.4.2​
Do not re-use Indicates a medical
device that is
intended for one
use, or for use on a
single patient during
a single procedure.​
NOTE Synonyms for
?Do not re-use? are ?single​
use? and ?use only once?.
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
D What is the exact Temperature Coefficient Value to be set on a Conductivity Meter? General Measurement Device and Calibration Topics 2
shrutisancheti Exact Classification for Trans Radial Compression Device per EU directive 93/42/EEC EU Medical Device Regulations 2
C Do titles that are called out in processes and procedures have to be exact? Document Control Systems, Procedures, Forms and Templates 3
C Calibration Dates - Exact day or end of month? General Measurement Device and Calibration Topics 24
G What is the exact meaning of Single Fault condition? EU Medical Device Regulations 4
R Using Exact Words from ISO 9001:2008 in Level 1 Document (Quality Assurance Manual) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
S Definition OEM (Original Equipment Manufacturer) - Exact definition of OEM Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
ScottK Definition Copy Exact - Committment to abide by a Process Control Plan without deviation Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 34
J What is the exact meaning of "calendar year"? TS2-Rules2 clause 4.13 IATF 16949 - Automotive Quality Systems Standard 20
M Can two exact forms be placed in one centralized location with two different QA-P-#'s Document Control Systems, Procedures, Forms and Templates 12
apestate Exact Format of Clause 2 References ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
O Software for comparing text of PDF files Contract Review Process 2
C Medical Device Molded Parts with Text on Them EU Medical Device Regulations 3
M I am looking for the text of the copyright 'rules' for AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M Final rule on use of symbols on labeling - Symbols without text under some conditions Other US Medical Device Regulations 12
N Microsoft Word - How to make high-light go away after text is put in Excel .xls Spreadsheet Templates and Tools 5
J Macro Question: Get Column Name by Column Number / or Use Text constant to link on a Using Minitab Software 1
O Importing Data via Script - Assign Column as Text (Minitab) Using Minitab Software 3
somashekar Clause 7.5.5. as in the text and in the Annex B (ISO13485:2003) ISO 13485:2016 - Medical Device Quality Management Systems 1
A Minitab - Using the INSERT command to copy-paste text from and to a worksheet Using Minitab Software 6
D Resolution V Factorial Design with 5 factors (3 numerical and two text) Using Minitab Software 1
1 Excel 2010 Conditional Formating of Text Excel .xls Spreadsheet Templates and Tools 1
D Changing Text Procedures into Flowcharts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
B Descriptive Statistics where the Data Type is Text? Using Minitab Software 4
G Validation of our Statistical Software - Statistical "text book" examples needed Statistical Analysis Tools, Techniques and SPC 1
2 Minor Document Change Control - Minor text changes to work procedures Document Control Systems, Procedures, Forms and Templates 9
R Combination of Text and Flowchart based Procedures Document Control Systems, Procedures, Forms and Templates 18
Marc Block unwanted text messages on your Apple iPhone World News 5
Z Subsetting based on values in a text column in Minitab Using Minitab Software 1
Marc NIST Handbook of Mathematical Functions reference text World News 0
R Text associated with EN 980 Symbols Other Medical Device Related Standards 10
Marc 2016 Bug Hits Text Messages, Payment Processing After Work and Weekend Discussion Topics 3
P 8.2.3.1 - What is the meaning of this text? IATF 16949 - Automotive Quality Systems Standard 10
M Minitab Macro-Command 'NUMERIC' to convert a text column to an numeric column Using Minitab Software 8
smryan Excel Cell or Text Formatting help Excel .xls Spreadsheet Templates and Tools 27
S CE Mark - What is the meaning of CE or CE0050(text inserted here) CE Marking (Conformité Européene) / CB Scheme 3
smryan How to get chart to ignore text/blank? Excel .xls Spreadsheet Templates and Tools 3
P Problem with text verification - Text of the auditor certificate Coffee Break and Water Cooler Discussions 1
M Minitab Pareto Chart Text Adjustment Using Minitab Software 10
S 14001 text (html) & on-line management systems ISO 14001:2015 Specific Discussions 8
ScottK Can anyone recommend good Project Management Text Books Career and Occupation Discussions 4
Antonio Vieira Learn any language! Text to Speech - It's easy to speak for example Portuguese After Work and Weekend Discussion Topics 3
D ISO 9004 in a text format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Procedure as per TS 16949 - Consultant changed text procedure to flow chart Document Control Systems, Procedures, Forms and Templates 49
R UL Requirements - Received a variation notice - Safety caution text Various Other Specifications, Standards, and related Requirements 3
M Text Documentation - There is such a thing as overkill Document Control Systems, Procedures, Forms and Templates 2
G ISO 9001 Procedures: Flowchart vs. Text - Pros and Cons ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
apestate Keeping Procedures Simple - 15 person machine shop using text procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
