Use of "N/A" in a Document - Is an explanation a requirement?
Marcelo
#11
Anyway, although I used the auditing as a justification, in my opinion it?s more important to the company that people do know what they are doing, including justifying why something is non-applicable. Recording it or not is less important than the knowledge.
Marc
#12
One more thought came to me from the past (working at the torpedo facility) - we pushed on the procedure writers to add when a step or signature would be applicable in the procedure itself rather than leaving it to the memory of the workers/inspectors doing the job, for procedures that could be N/A for the same reason on multiple occasions. Then if the procedure already had printed in it "applicable only to Type B parts" or "Not applicable to type D and E parts" then all you had to do was circle that statement and annotate N/A.
The main problem I see is, if it?s not recorded, and an auditor asks why, will someone be able to clearly justify? I see this every time in audits, people say something is not applicable, but when asked why, they tremble and gag and do not give an answer. To an auditor, this clearly smells like a good audit trail for more problems.
If you can guarantee that people can justify on the spot if asked for a rationale, surely you do not need to record. Otherwise...
I agree with all of the above. Just to add :2cents:
My first thought is to ask yourself how critical it is in your specific situation. In some cases, especially regulated industries, there is a potential risk factor *in some cases* where there is an NA in a space on a form without an explanation as to why it is NA. But then again, it may be that your company procedure for that form says a simple NA is OK without explanation.
In most companies I think allowing an NA is relatively standard on forms which are "multi-use". If the form is not for multi-use, that field would not be there to begin with.
Since you say your GMP procedure states that any time "N/A" is used in any document, it must be followed with an explanation of why the field is marked "N/A" it says to me that at some time someone in your organization, for what ever reason, put that clause in and probably did so because of a risk factor, real or perceived. Technically you should be able to track back through the change history of your GMP procedure to see when that clause was put in and by whom. Then ask the person for the reason for the clause.
Or in short - Someone in your company "owns" the company GMP procedure. Ask that person why that clause is there.
SRQAAuditor
#13
Hi Peter,
So, the two medical device companies I have worked for have both had a document called Good Documentation Practice. That document is part of the documented quality manual, and has the requirement for proper use of "N/A".
SRQAAuditor
#14
Hi Pete,
I have been with two medical device manufacturers. Both companies have had a Good Documentation Practice document, which states the requirement for giving an explanation when using N/A on quality records. Best of luck in your new company.
B Legal document explanation for supplier charging Misc. Quality Assurance and Business Systems Related Topics 6
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 14
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
D Are medical device companies required to document every change made to their website? Document Control Systems, Procedures, Forms and Templates 2
M Informational IMDRF draft document – Principles and Practices for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
R Training Matrix for Document revisions ISO 13485:2016 - Medical Device Quality Management Systems 4
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
