Use of OD Indicator Micrometers - Round Feature vs. Flat Surfaces
Q
QC Rick
I have recently heard of this technique of setting up an indicator Micrometer (OD) that if your are going to measure a round feature you set up the tool with a round gage (Deltronic gage pin) and conversely, if you are going to measure flat surfaces you use gage blocks!?
(Note this goes for any OD micrometer.)
Personally I have never heard of this and have not been taught this technique in any class (24 years). :notme:
Comments and or direct information is very much welcome! ;)
I haven't used an indicating mic in a while, but when I did I usually set it with whatever was convenient--blocks or a pin. I don't think they're generally of much use except for sorting. You can do a simple experiment for yourself--just set it with a pin and measure a block of the same size. I doubt that you'll see any difference.
True Position
I would guess a potential difference would be wear on the anvil faces, something used to gage round parts would more likely have uneven ( shaped wear compared to something used to measure flat faces. I suspect it doesn't make a difference in 99%+ of cases.
justncredible
Hawat is close.
You can check the paraellism of the mic advils with a gage ball. Since only the highest spots are hitting at a single time. It works and is a valid way to prove a mic is out of paraelle.
Is it good for setting up to check parts, no not really since you might set to a pit or other surface error on the advils. In the use of a mic you will use feel or in the case of a indicator mic a spring, in both cases you will be moving the part on the advils and looking for the reading. Setting to a gage pin could increase the error of the reading, a risk in any measurement.
So either can be used and are, someone was bs'ing you.
K Biological indicator system classification under MDR EU Medical Device Regulations 2
K EIFU indicator symbol - Class I labels as per EU MDR EU Medical Device Regulations 3
F Broken indicator Coffee Break and Water Cooler Discussions 0
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
K Further Analysis of Departmental KPI (Key Performance Indicator) Statistical Analysis Tools, Techniques and SPC 2
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
G How to develop a strategy to eliminate an indicator who has been 0 forever? Preventive Action and Continuous Improvement 1
E How to perform Discrimination check for Dial Indicator? General Measurement Device and Calibration Topics 2
M How to prepare for a PLI (Professional Learning Indicator) job test Career and Occupation Discussions 6
C Calibration Key Performance Indicator AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
L Remote Control Inspection Digital Indicator with a TIR (range) function Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L "Morale" as an indicator - How to track "morale"? Misc. Quality Assurance and Business Systems Related Topics 16
L IEC60601-2-44 - Indicator Light Requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Interpreting the Calibration Report for my Dial Indicator General Measurement Device and Calibration Topics 3
D Procedure for use of a Digital Indicator and a Height Gage Document Control Systems, Procedures, Forms and Templates 6
D Calibration of a Dial Indicator only used to indicate 0 General Measurement Device and Calibration Topics 7
M What Indicator should we use to follow Incident Containment Nonconformance and Corrective Action 2
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
B How the indicator is integrated with other activities in the procedure? Customer Complaints 6
J I'm looking for a Thin Drop Dial Indicator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B KPI (Key Process Indicator) for Document Control Center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Looking for a copy or template of a In House Calibration Report for a Dial Indicator General Measurement Device and Calibration Topics 1
A Dial Test Indicator Repair Procedure General Measurement Device and Calibration Topics 3
S Environmental Objective, Target, and Performance Indicator - Differences? ISO 14001:2015 Specific Discussions 16
M Can a KPI (Key Process Indicator) be created against Nonconformances? Nonconformance and Corrective Action 8
1 Acceptance criteria and related standard for 1 micron Lever Type dial Indicator General Measurement Device and Calibration Topics 5
D Please help to set Weighing Indicator SI4010R General Measurement Device and Calibration Topics 1
M Biological Indicator Ethylene Oxide Sterilization Other Medical Device and Orthopedic Related Topics 11
Z Dial Test Indicator Flaw General Measurement Device and Calibration Topics 7
N Digital Temperature Indicator Calibration (Thermocouple) - Using a reference junction General Measurement Device and Calibration Topics 1
P What is the appropriate indicator better than GDP and GNP? Coffee Break and Water Cooler Discussions 0
A Dial Test Indicator Design & Operation when Approach Angle is Different General Measurement Device and Calibration Topics 5
S Digital Dial Indicator Recommendation General Measurement Device and Calibration Topics 4
U P Charts - Subgroup Sizes? Process Control Indicator Statistical Analysis Tools, Techniques and SPC 3
Q Dial Indicator Verification Procedure - ANSI/ASME B89.1.10M-2001 General Measurement Device and Calibration Topics 13
A KPI (Key Process Indicator) - Cost of Non Quality Benchmarking 8
A Positive Performance Indicator (PPI) for Energy/Utilities organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Efficiency Indicator examples wanted - TS 16949 5.1.1 Process efficiency IATF 16949 - Automotive Quality Systems Standard 3
D Key performance Indicator - Travel @ Tourism ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Which Indicator is Best to Evaluate our HR Training Programs? Training - Internal, External, Online and Distance Learning 7
J Effects of substrate on biological indicator organisms US Food and Drug Administration (FDA) 2
D Monthly Indicator to Monitor Employees Clocked-in Time Statistical Analysis Tools, Techniques and SPC 8
L Qualifying an Interapid 312b-3 Indicator - Disappointment General Measurement Device and Calibration Topics 6
J How to Calibrate a Digimatic Dial Indicator? General Measurement Device and Calibration Topics 5
B Tolerance for Digital Indicator Calibration - Machinists Indicators General Measurement Device and Calibration Topics 1
G Staff KPI (Key Performance Indicator) .xls Excel format Excel .xls Spreadsheet Templates and Tools 4
D ANSI B89.1.10, AGD and Mil A-A-2348 Dial Indicator Standards Various Other Specifications, Standards, and related Requirements 2
Y Definition DPPM - Quality Indicator? Using DPPM instead of DPMO as our OQA quality indicator Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Sidney Vianna Automotive product new environmental performance indicator World News 4
S How to calibrate a Bore Indicator? MIL-STD-120 "Gage Inspection"? General Measurement Device and Calibration Topics 4
