Use of Y1 capacitors for MOPP (means of patient protection)
BMR96
I would like to see if anyone can clarify a point on Y1 capacitors. Section 8.5.1.2 says that a Y1 cap can be used as 1 MOPP if it passes the dielectric strength test of 2 MOPP. I have heard it said, and it stands to reason, that to achieve 2 MOPP with Y1 caps, you simply put 2 caps in series. The standard gives guidelines for using Y1 caps in series, but it does not explicitly say that 2 caps in series will actually be equivalent to 2 MOPP. So, any thoughts on this? Is it as simple as 2 caps = 2 MOPP?
Thank you.
Peter Selvey
Yes, it is fairly common practice, and obviously the intended purpose of the statement about keeping the values the same capacitance.
Clause 8.5.1.1 is the basic clause that says 2 MOP are required, I guess that stays in the background.
W Part Change Request - Standard (OTS) electronic parts (resistors, capacitors etc.) IATF 16949 - Automotive Quality Systems Standard 3
J RoHS Components with Lead Exemptions (Capacitors on a PCB) RoHS, REACH, ELV, IMDS and Restricted Substances 11
M Failure Analysis on Cracking SMT Capacitors Problem Solving, Root Cause Fault and Failure Analysis 7
R Failure of X-Capacitors complying with IEC 60384-14 IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
somashekar Tolerance of Multilayer Ceremic Capacitors (MLCC) of Y5V material Manufacturing and Related Processes 1
somashekar Information sharing: Week 21, 2010 (CAPACITORS, TRANSFORMERS, RELAYS) The Reading Room 2
S PPAP Submission Required for Electronics Components i.e., Resistors, Capacitors, etc. APQP and PPAP 3
M Cpk for attribute data? Performing SPC on capacitors - Capacitance measurement Statistical Analysis Tools, Techniques and SPC 9
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Accessible parts per 8.4.2 b) - Touch currents in combination with MOOP or MOPP? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T Clearance and Creepage according to Subclause 8.9.1 for MOPP IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S IEC 60601-1 - MOPP and MOOP Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
W Body-worn brain stimulator (MOPP isolation requirements) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F MOPP in battery powered device with metal enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
N USB Powered EEG - USB provides 1 MOPP want 2 MOPP IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Medical Device Electronics - Secondary to output isolation for 1 MOPP IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
S Number of MOPP for Type BF Applied Part (Medical Device Electronics) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
U USB Connector Operator Protection (MOPP) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
F How to provide 2 MOPP (Means of Patient Protection) - Heating Rod IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P Effective way for DC/DC conversion for 2 MOPP @ 250VAC IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Do Medical Sterile Drapes count as MOPP? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Surface mount resistor as a MOPP (Means Of Patient Protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
M Applicability of Means of Protection, working voltage in an Automated External Defibrillator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J President does not know what the Quality Policy means ISO 13485:2016 - Medical Device Quality Management Systems 10
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
P Uncertainty and Significantly Different Means - Buffer Solutions Measurement Uncertainty (MU) 4
G Definition Parallel Loop - Does anyone know what the term Parallel loop means? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
N Explanation - Quality means doing it right when no one is looking ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Question on Table 6 "Test voltages for solid insulation forming a MEANS OF PROTECTION IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Uncertainty Measurement - What this accuracy specification "1% + 10^5": means? General Measurement Device and Calibration Topics 2
F MOP (Means Of Protection) - Creepage and Clearance questions IEC 60601 - Medical Electrical Equipment Safety Standards Series 19
L What does "conformance matrix" means in terms of ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F Evaluation of MOP (Means of Protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
E Correlated data or not? Determining the significance of differences in means Statistical Analysis Tools, Techniques and SPC 3
Q Definition C - What the "C" in C=0 Sample Plan means Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
J Minitab Sample Size Calculation: 1 Sample t vs Minimum Sample Size for Means Using Minitab Software 3
L What exactly does Configuration Management in ISO 9001, Clause 7.5.3 means? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
somashekar Friday the 13th - What it means to people around here. Coffee Break and Water Cooler Discussions 9
M Can I continue using IEC60601-1 Ed2 PSU for MOOP (Means Of Operator Protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
B Test of Means or Medians for Non Normal Populations? Using Minitab Software 6
F What Compliance to ISO 9001, 6.2.2 Competence, Awareness and Training Means ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
A Customer Demands (MSA=Bias + GRR/2). Can somebody explain what it means? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Ford Acronym - What the acronym "ym" means in Ford lingo? Customer and Company Specific Requirements 1
S How to Design the Means of Protection for Home Use Unit IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Definition Disposition Definition - Disposition means Prevention of Recurrence? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 24
Wes Bucey Keeping your cool means keeping your job Career and Occupation Discussions 12
D Means Of Protection of the Video OUT of an Internally powered device IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
bobdoering From SME: What the Stimulus Plan Means to Manufacturers World News 1
