Use repackers 510(k)?
ascherp
#11
Sorry, I can't help you on that. I fear it is one of those things that the FDA has not spelled out, but requests anyway. Since 2012 I have accompanied seven FDA inspections of foreign firms. The investigators have requested to see such authorizations of all 510(k) owners. The reasoning is that as design owners of Class 2 devices they need to be able to control what is sold by whom and under what conditions. The authorizations need to include the requirement that the significant regulatory content of the 510(k) owner's labeling will not be modified by the relabeler (such as indications for use, warnings and contraindications, performance claims, or sterilization parameters) and that the relabeler will submit his labeling to the 510(k) owner for review and approval. In addition, if the 510(k) owner makes any significant changes to his labeling, for instance by adding a warning due to the complaints he has received, he must communicate it to the relabeler, who needs to incorporate the revision into his own labeling.
Apparently there are too many relabelers out there who make up performance claims and write up instructions for use that have nothing to do with the original content of the 510(k), compromising safety and effectiveness.
Ronen E
Problem Solver
Moderator
#12
Thank you.
All this is understood. I didn't suggest that anyone can market a deviating device based on an existing 510k. To put it simple, my question could be: "If the devices are identical as far as 510k contents are concerned, what does ownership [a commercial aspect that FDA doesn't formally track] have to do with regulatory compliance?"
I understand (and share) the "common sense" feel, and as I stated above I realise that this could be a FDA de-facto attitude, but I was wondering what the legal basis is. The FDA shouldn't be enforcing something that has not gone through proper authorization.
ascherp
#13
Hi Ronen. Actually I feel they're not enforcing ownership of the 510(k) as such, but rather of design. Ownership of the DHF is transferred with the 510(k), so to speak. The FDA considers the new owner of the 510(k) to be the new owner of the DHF and of the corresponding DMR and to be responsible for any design changes. That's the aspect of transfer of ownership the FDA is interested in and can enforce, not the commercial part. They just need to know with whom that responsibility lies.
Perhaps a well-defined agreement could keep both aspects clearly separated and transfer commercial ownership while design ownership remains with the original applicant? I haven't seen that as yet, but it should be possible. If it is spelled out clearly, then this particular transfer of (commercial) ownership would definitely not be a concern of the FDA and wouldn't have any regulatory consequences. I totally agree with you on that.
Ronen E
Problem Solver
Moderator
#14
"DHF responsibility" and "DMR responsibility" are relevant only if the design evolves. Surprisingly, some cleared devices designs stay stagnant for extended periods, even 10, 20 years. In such a situation, as far as I understand, all that is required for being fully compliant is access to the original, unchanged DMR.
I'll tell you about a real case I know. Entity AAA developed, manufactured and sold a medical widget in bulk, to other entities who integrated it in their own finished devices. AAA didn't need a 510k because the widget wasn't sold as a finished device. Entity BBB (essentially a commercial entity with no manufcaturing capabilities) then engaged AAA commercially, to place AAA's widget on the USA market as a packed, finished device. The nature of the widget is such that it can serve both as a "raw" component and as a finished device with a relatively small & simple addition at the back end of the process. AAA developed that process and provided the "finished" widget to BBB. BBB submitted and cleared the 510k under its name, but in fact AAA provided all the knowledge, and naturally gained acess to all the 510k files. BBB owned the 510k in the commercial sense (they paid for it, and it was in the contract), but the labeling showed AAA's details. That was done because AAA already had a good reputation in the market, and they were responsible for everything technical (including complaints) anyway. So far so good.
Years went by, and the entities parted for various reasons. BBB could no longer get the widget from AAA, and pretty much from anywhere, because AAA held important bits of the DMR as proprietary. Now, AAA wanted to market the widget itself, as a finished device. They had all the knowledge and there was a 510k in place. FDA didn't mind and didn't look for "permission" from BBB, because it was obvious that AAA didn't need any support from BBB for being perfectly accountable (as they have been all these years). The only problem was commercial - BBB took AAA to court for undue use of BBB's property - the 510k.
ascherp
#15
Yes, fortunately the FDA is reasonable in its interpretation and enforcement of the requirements according to the specific situation and device in question. The design control/DHF requirements didn't even exist until 1997, so an approved DMR is fine for older devices. Even now, DHF documentation for a simple device such as the one you describe would be very lean.
O
Oscar Wang
#16
Hi, guys:
i have a question here, transfering a 510(K) ownership means that new owner shall fully take responsibility of the design of this device. FDA will also check the DHF during the facility inspection. Do you have enough confidence to handle that?
S Predicate Material 510(k) US Food and Drug Administration (FDA) 1
S Predicate Material 510(k) Medical Device and FDA Regulations and Standards News 3
J US Device Listing when not the 510(k) owner Medical Device and FDA Regulations and Standards News 2
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
S Special 510(k) for orthopedic implant 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Label change - 510(k) Medical Device and FDA Regulations and Standards News 5
G We want to add Covid-2 /19 to our air filter 510 K Medical Device and FDA Regulations and Standards News 0
A The refund of 510(k) user fee Medical Device and FDA Regulations and Standards News 0
A Which guidance do you use for guiding the requirements of IFU for 510(k) submission? Medical Device and FDA Regulations and Standards News 5
A 510(k) review timeline 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L Impact on 510(k) to use an additional manufacture US Food and Drug Administration (FDA) 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
Watchcat Advantages to pursuing a Special 510(k) instead of a Traditional 510(k) Other US Medical Device Regulations 5
A 510(k) registration and listing US Food and Drug Administration (FDA) 1
Aymaneh Traditional 510(k) Declaration of Conformity Other Medical Device Regulations World-Wide 3
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
A Several sections of traditional 510(K) have the same or similar requirement of content. US Food and Drug Administration (FDA) 4
A Some questions about voluntary consensus standards in traditional 510(k) submission US Food and Drug Administration (FDA) 6
A Some doubts about traditional 510(k) submission US Food and Drug Administration (FDA) 5
A Bench test report translation to English for 510(k) submission Other US Medical Device Regulations 2
S Special 510(K) - Labeling change from Rx to OTC Other US Medical Device Regulations 11
J 510(k) for a control kit for an external IVD test kit 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Y Expanding the indications for use for a 510(k) cleared device Medical Device and FDA Regulations and Standards News 4
T First 510(k) submission - Class II software as medical device US Food and Drug Administration (FDA) 4
T Submitting MR Compatibility Data for 510(k) Cleared Device Other Medical Device and Orthopedic Related Topics 2
M CE Mark and 510(k) -Global registration requirements for every country Other Medical Device Regulations World-Wide 3
Z 510(k) usage - Company has 2 physically similar products Medical Device and FDA Regulations and Standards News 2
K 510(K) File eCopy Submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 16
Q Need clarification on requirements.... Class i, gmp & 510(k) exempt Medical Device and FDA Regulations and Standards News 12
D Redacted 510(k)s - Example wanted Document Control Systems, Procedures, Forms and Templates 17
K Changing the Address in 510(K) Approved Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
K Completing Design Controls after 510(k) Clearance Other US Medical Device Regulations 11
P Predicate Device Information for 510(k) Submission Medical Device and FDA Regulations and Standards News 4
M 510(k) 10993 Biocompability Testing Other US Medical Device Regulations 15
D First 510(k) Submission - Don't Forget Tips US Food and Drug Administration (FDA) 5
K Reporting a Change of Contract Manufacturer for a 510(k) cleared device Other US Medical Device Regulations 5
K Mammography Machine Bench Testing - FDA 510(K) US Food and Drug Administration (FDA) 5
D Is Human Factors testing mandatory for a 510(k) submission? Human Factors and Ergonomics in Engineering 16
D Pre-Submission after 510(K) Submission? Other US Medical Device Regulations 4
M Informational US FDA Final Guidance – Special Premarket Notification [510(k)] Pathway Medical Device and FDA Regulations and Standards News 0
M CBE (Change Being Effected) 510(k) Submission Other US Medical Device Regulations 2
K 510(K) Submission (Traditional) for Medical Device US Food and Drug Administration (FDA) 17
F Replacement Bone Screws - Traditional 510(k) or Special 510(k)? Other US Medical Device Regulations 7
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
Watchcat Informational FDA Proposal to "Modernize" the 510(k) - 2019 Other US Medical Device Regulations 1
B 510(k) clearance claim on medical device product packaging Other US Medical Device Regulations 6
shimonv Referring to previously submitted biocompatibility results in a new 510(k) submission Other US Medical Device Regulations 1
L A Taiwan company want to sell Class I medical device (510(k) exempt) on Amazon, should we register with FDA? US Food and Drug Administration (FDA) 4
B Submit a 510(k) with a Predicate cleared but not Listed US Food and Drug Administration (FDA) 9
R 510(k) Biocompatibility vs Cleaning Validation Other Medical Device Related Standards 4
