Using a Kanban Lifecycle for the Software Development
Marc_G
I am new in the field of medical software. My company manufacture software for in vitro diagnostic device.
We are thinking about using a kanban lifecycle for the software development, but it seems to be difficult to use it with 62304 and 21 CFR part 820.
Do you have any experience that could help me in the decision of using kanban or not ?
sagai
i think you can forget it.
tasks can not be unified into the same size in sw developement, however it is a cornerstone in kanban.
moreover kanban is simply a cycle time optimization for discrete manufacturing. sw development is a non deterministic process.
br
Sz.
sagai
it could be really deep :)
the result of the sw development is a source code (i mean what really touches the customer's wallet).
mostly it is distinguished from requirement engineering and treated differently than a requirement.
But in the reality the code itself nothing else than design documentation, more surprisingly it is also a specification, a specification for the compiler or a specification (for low level coding when using 0 and 1 only) for the microprocessor.
Okay, than coming back to more specifically to your question.
The sw development, which results the code, is non deterministic, because 1oo% surely if you give companies the same specification, they will not produce the same source code or the same specification for the microprocessor.
In contrast, when there is a discrete manufacturing specification, surely the end product will be the same. (or you can fire the one creating something else :) )
br
Szabolcs
michellemmm
Quest For Quality
br
Szabolcs
Thank you.
Currently, I am involved with documentation of a project in accordance with DO178B. The guideline that was given to us by our customer for SDD is : the document to be written in such a manner so that...for two programmers develop almost identical source code as long as they follow the software standards. I am not sure if this is practical or possible or deterministic?
sagai
Hi Michelle,
I do not think when there is a common programming guideline the two developer will develop the same source code. Surely they have different resolution patterns in their mind due to different education, culture, etc., and grow up background. Even twins not likely develop the same source code regardless they had the same environment and education background.
In your case the reason could be the voting approach.
When there are two (our even more) source code developed based on the same requirement set but by entirely separated developers (or companies), than the verification of proper operation above of the "traditional" verification way could be that these programs (with the same functionality) incorporated into a framework program and typically in real time decision system, all the individual program proposes a decision but the final accepted decision will be the majority decision of the proposed ones.
I do believe sw development is non deterministic as long as human does that.
br
Sz.
Marc_G
My point about kanban is more about using lean and agile software development practicies and not to have the capacity to reproduce the same software.
But seeing the 62304 added with the part 820 prescriptions, it seems difficult to manage project with these practicies.
I found an interesting link from at the bottom of the kanban wikipedia page.
"Software Engineering Radio, Episode 156: Kanban with David Anderson"
sagai
IEC62304 and 21CFR820 is not about project management. (there are very minimal requirements for that, mainly on the area of planning)
Project management can be any method, waterfall, agile, etc.
br
Sz.
ab001
The way I understand Kanban is
A Kanban is a standing order used to make only the right amount of widgets at the right time. For example, please make 100 widgets to refill this bin. (where having a full bin means production can continue)
Well-planned, properly designed Kanbans have very little management overhead and very little time delays.
Please make 100 lines of code doesn’t quite make sense.
I thought Agile/Scrum had the concept of a working build. This working build is similar to a Kanban (as sagai said earlier, code is different to widgets)
Please make a working build that satisfies requirement 1
Please make a working build that satisfies requirement 1 and 2
Etc.
Keep using the local terminology. Adding another Japanese word won’t necessarily help.
If you want Lean in software development, look for Seven Wastes in Services.
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
R MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
C Importer shell game - Using a third party logistics provider (3PL) in the EU EU Medical Device Regulations 5
S Work performed in Canada on US patients using US device Canada Medical Device Regulations 1
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R Clause 7.7 Replicate, Recalibration and Intermediate checks using Artifact ISO 17025 related Discussions 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
A Using Arduino based sensors for Poke-Yoke Manufacturing and Related Processes 6
M Using your Manufacturer's ISO certification ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
A Hospital IT expectations for connected medical device using WIFI Medical Information Technology, Medical Software and Health Informatics 0
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
J Class 1 Medical Device - Using a UPC over the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
M Raw stock material testing discrepancy using an XRF (x-ray fluorescence) analyzer Manufacturing and Related Processes 7
Z Using FMEA for Knowledge Management FMEA and Control Plans 6
Sidney Vianna NASA to Develop a Novel Approach for All-Electric Aircraft Using Cryogenic Liquid Hydrogen as Energy Storage World News 2
S How many of you are using Robotic process automation for calibration lab management? ISO 17025 related Discussions 0
J Including Repeats in DoE using Minitab Using Minitab Software 5
S Legal Manufacturer FDA Reporting Obligations for Using New Contract Sterilization Site Other Medical Device Regulations World-Wide 0
John Predmore What size pinhole can be reliably detected using visual inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
