Using a Tape Measure for +/- 1/16" Tolerance - Large Welded Assemblies (6 to 12')
kwalityguy
I am returning to an industry that uses a tape measure to measure large welded assemblies (6 to 12'). The typical tolerance is +/- 1/16", basically throwing the 10 to 1 rule out the window.
What is out there for gages besides a Romer which isn't very practical to wheel around outside in a steel yard or around a welding area?
I looked around Elsmar but didn't find a similar thread (hard to believe).
harry
Are you sure the 1/16" tolerance apply to the length? To my mind, they apply to the legs, etc (refer to the relevant welding codes) but not the length. Just ask yourself whether any welder is able to keep to this tolerance bearing in mind that a generally used welding rod is much bigger than that.
kwalityguy
Yes, I used a 12' Gold for several years to inspect fiberglass truck roofs and hoods. What I'm looking for is something I can give 3 inspectors for incoming, roving/in-process and final inspections. I think a portable CMM would be too cumbersome. Not my first choice.
kwalityguy
I thought about those but they are limited to line of site and they need something to reflect off of (inside diameters/lengths). Not so good for outside dimensions/cross taping a flat sheet for squareness. Need something like a linear scale except it's flexible like a tape measure.
K
kgott
I know welded assembles have to fairly precise but I don't know about 1/16th. An assembley could easily expand or contract that much depending on the whether or not its measured on a hot day or a cold day.
It may have been originally measured and cut or welded on a cold day in the workshop and inspected (measured) on a hot day out in the yard and exposed to direct sunlight and show more than 1/16 change in length or between sets of holes increasing the possiblity of NC.
If your using tapes I suggest it would advisable to calibrate them in the winter and again the summer so that any creep or contraction can be known and factored into things.
You shouldn't bind yourself to "rules" that don't serve a good purpose. How you measure, and what you measure with, should be determined by objectively assessing the risks. If there's a long history of measurement with tapes and no associated problems, why change now?
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
R MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
C Importer shell game - Using a third party logistics provider (3PL) in the EU EU Medical Device Regulations 5
S Work performed in Canada on US patients using US device Canada Medical Device Regulations 1
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R Clause 7.7 Replicate, Recalibration and Intermediate checks using Artifact ISO 17025 related Discussions 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
A Using Arduino based sensors for Poke-Yoke Manufacturing and Related Processes 6
M Using your Manufacturer's ISO certification ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
A Hospital IT expectations for connected medical device using WIFI Medical Information Technology, Medical Software and Health Informatics 0
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
J Class 1 Medical Device - Using a UPC over the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
M Raw stock material testing discrepancy using an XRF (x-ray fluorescence) analyzer Manufacturing and Related Processes 7
Z Using FMEA for Knowledge Management FMEA and Control Plans 6
Sidney Vianna NASA to Develop a Novel Approach for All-Electric Aircraft Using Cryogenic Liquid Hydrogen as Energy Storage World News 2
S How many of you are using Robotic process automation for calibration lab management? ISO 17025 related Discussions 0
J Including Repeats in DoE using Minitab Using Minitab Software 5
S Legal Manufacturer FDA Reporting Obligations for Using New Contract Sterilization Site Other Medical Device Regulations World-Wide 0
John Predmore What size pinhole can be reliably detected using visual inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
