I must admit to a bit of confusion when comparing the right-hand pane with the main larger left hand pane of your QMS home page; the entire right-hand pane is entitled "Management System", but its contents did not seem to match the 9 sub-sub-heads under the "Management System" sub-head in the main larger left hand pane?
Referring to the first illustration in the article, the “larger left hand pane” is the content of the home page of our system. When you go to any other page in the system, be it of the same or a different process, the content will be different.
The “right hand pane” we call the process navigation menu, or “nav”. It lists all documents that belong to the process that this document belongs to. In this case Quality Management. When you go to any other page listed in this pane, this pane will be unchanged. This is accomplished by “including” the QM nav in every page that belongs to the QM process. When you go to any page that belongs to a different process, the contents of this right hand pane will not be the same as in the homepage anymore, as it will list then the docs from that other process. For example, the third illustration in the article shows a Project Management document, and the nav is for the PM process.
There is another important “pane”: the main menu. It is the long string of two and three letter codes near the top-right of the page that starts with “QMS | SM | 5s | ...”. This pane doesn’t change throughout the whole document system. Clicking on one of these codes takes you to the home page of a process, where that process’s description is.
So, in summary, the content “pane” varies with every page. The nav “pane” varies by process. The main menu at the top of every page doesn’t vary.
The subheads under Management System on the left, well those from 3 to 8, are “Description” documents. Their contents describe how each section of the standard is implemented in our QMS. The illustration is from the 2008 version of the standard, the current one is a little different. These description docs are useful to auditors (internal and external), but not so useful for day to day work, so they were omitted from the navigation panel. This is why the right and left panes don’t match. (But i should mention that omitting docs from nav panels in our wiki is rather exceptional.)
Yes, your Sample QMS Wiki Organization was the landing page I was referring to. Several routes to accessing the more detailed information. If you start with the old-school 200 page Operations Manual for all the things team X does (which I created probably 15 years ago at least - design a structure with several broad headings; the Chapters, then the subsets within those broad categories; the subheadings, then populate the actual content, then slap a T of C at the front, etc), then transfer all that good information into a flat structure of 500 topics/web pages with hyperlinking connections, people seem to suffer from a vague sense of unease, that they do not "know where they are" in the wider scheme of things, or that they are possibly missing something vital that may be on another page that they do not know about. A "way in" like yours, giving them a structure and hierarchy of information, will give more peace of mind, I now think.
Indeed. Users do not feel lost in our wiki thanks to the two menus in each page: the main menu on top of the page and the nav pane on the right.
Also, the wiki’s “easy linking” by adding brackets to any word or phrase encourages links within the content. We train folks to spot potential useful links and create them.
If you, say, add a new sub-category of information, would your system functionality enable the various navigation menus to auto-update?
Yes. The navs are “included” content. This means that these panels live on their own wiki page, but are included into other pages through the wikis “include” command. When you update a nav page, all the pages that included it are automatically updated.
Furthermore, when you change the title of a page, all the links that point to that page in other pages are updated with the new name of the page. These auto-updates include nav pages. It is really easy to keep the whole system consistent and in-synch.
