Using Arduino based sensors for Poke-Yoke
a.temel
Greetings All,
I work in an injection molding company as a QA eng. and i have some ideas for poke-yoke systems based on arduino.I know this device isnt designed to work in a manufacturing env. but its cheap and could solve huge quality issues.
For example,we install metal nut to a plastic part and sometimes operator skip this process by mistake and this could be easily solved with a metal detecting circuit.But i m afraid to suggest this to menagement because,
a) Its not my area of expertise,
b)I dont know if it would be reliable in the long run,
Kindly expecting your insights.
Tagin
It would seem that there would need to be two sensors: one to detect when the assembly is present to be checked, and one for the actual metal detection. Then, there would need to be some notification or intervention as a result of a failure, such as a flashing light, buzzer, email alert, shutting off power to that station, etc.
As for reliability, the concern would be false positives, so you would want to try to make the design so that if it fails, it always fails as false negative.
Those devices are cheap enough that replacement cost probably isn't an issue. Most of the cost would be in the initial configuration design and any software programming. But that should be reasonable for a simple device like an Arduino.
Maybe you could propose in more general terms that "an automated QC check device" would be advantageous. Then, give as an example, "maybe something not too complex - like an Arduino."
Hopefully, management is not going to be negative just because you have an idea for improvement.
Bill Levinson
Industrial Statistician and Trainer
Re: "sometimes operator skip this process by mistake "
Shigeo Shingo (Zero Quality Control: Source Inspection and the Poka-Yoke System) dealt with problems of this nature very frequently and yours is very similar to those for which he has numerous case studies. The case studies often used mechanical sensors like limit switches to detect the presence (or absence) of parts that were supposed to be there.
If the part is in a jig or fixture, where the metal nut will always be in the same place, the metal detector (or limit switch) could be placed to detect the nut. Alternatively, if the part leaves the work station on a conveyor or work slide, a gate could be installed that will not open unless the metal detector senses the presence of the metal nut. Shingo's examples often had a sensor that would actually prevent a nonconforming part from leaving (jidoka or autonomation).
(Does not constitute formal engineering advice)
optomist1
A Sea of Statistics
don't know your firms budget constraints...but a sure fire method is (and its is $$$) an AOI or automatied optical inpsection....camera machine vision to confirm correct fastener is in place correctly oriented etc...this then requires among other things use of a Golden Rabbit and a Red Rabbit...know good and bad part or assembly.....once properly vetted/proven and implemented works well. If this route (easier to rationalize the captial expenditure as well) is taken the AOI system can be implemented across other process steps and other production lines.
a.temel
@Bill Levinson
We have a gate system already.Gate is only activated if the nut assembly machine sends the signal.Problem is, this systems costs between 3000-5000 euros.So we cant implement it for every part.My idea is like this.Arduino controls magnetic sensor and movement sensor.If both is activated when operator drops the part into the box,part is ok.If only movement sensor is activated but not the magnetic sensor,part is NG.And all this costs below 50 euros.But i dont know if its reliable because i didnt see anyone in our line of business use arduino based sensors before
@optomist1
We use AOI's only for critical parts for OEMS.And they are even more expensive.
Bill Levinson
50 euros is about the price range for a typical Shigeo Shingo error proofing system. If the movement sensor detects the part but the metal detector doesn't detect the nut, I suppose it could stop the box from continuing (jidoka/autonomation) and use a visual or audible control to alert the operator.
optomist1
A Sea of Statistics
@Bill Levinson
@optomist1
I kind of suspected that might be the case....but when justified and properly implemented they are worth the effort...Cheers optomist1
H Using/Selling power banks with your product as a "mobile version" CE Marking (Conformité Européene) / CB Scheme 3
cgaro62 Using internal audits as part of document reviews Document Control Systems, Procedures, Forms and Templates 20
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
M MSA angle issue - Nylon parts using Aberlink 3D Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 20
J Using of CE marking - Two CE markings on the product CE Marking (Conformité Européene) / CB Scheme 5
R Using R package to implement Bayesian phase I/II dose-finding design for three outcomes ISO 13485:2016 - Medical Device Quality Management Systems 6
S Defibrillator Protection applicability When using Multiple applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Using Zinc Plated Steel in a Cleanroom Other Medical Device Related Standards 3
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
rerusk1 MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
C Importer shell game - Using a third party logistics provider (3PL) in the EU EU Medical Device Regulations 5
S Work performed in Canada on US patients using US device Canada Medical Device Regulations 1
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R Clause 7.7 Replicate, Recalibration and Intermediate checks using Artifact ISO 17025 related Discussions 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
M Using your Manufacturer's ISO certification ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
A Hospital IT expectations for connected medical device using WIFI Medical Information Technology, Medical Software and Health Informatics 0
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
J Class 1 Medical Device - Using a UPC over the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
