Using Calibrated OD mic over non-Calibrated ID mic for final dimension
Scott.Hilton
So we have a supplier who has chosen to save money by not calibrating their ID mics. The practice they have been using and will not change, is that on ID's they take the "measurement" with the ID mic that is not calibrated, remove the ID mic from the bore and then gage an OD mic over the ID mic for the reading.
This is on ID's that have total tolerances of .003-.005 metal components. I find this to be not only a poor practice, but an unacceptable one. I believe that in order to be accurately recorded final dimensions they should be taking direct measurements and not introducing variance. However, the person over supplier quality says this is a perfectly acceptable industry practice.
I am newer here, but not new to the industry (Oilfield) and I have been through enough customer audits that I would be be both embarrassed if this was my personal practice and I would also expect a corrective action from my customer. So I am concerned with this stance.
That being said, I am human and can be wrong. So, does anyone any points of clarification or industry standards they could point me towards in researching this method of inspection? The drawings do not call out a specific industry standard to use, so any insight would be greatly appreciated.
SH
normzone
It can be done in that range with reliability, but he's living on the edge. It's reliant on technique, which is a mix of training, experience, and give-a-damn.
Of course that applies to all measurement. If I wanted to fuel the fire, I'd take a known piece and do some multiple readings and record them. Then have somebody else do the same. You should be able to figure out what kind of error the process is generating.
This is no different than doing transfer measurement by any other method when you don't have exactly the calibrated tool you wish you had to do it. Piston ring grooves get measured by shade tree mechanics who only own a set of pincher calipers and a six inch vernier caliper. ID bores get measured using telescope micrometers and an OD micrometer.
They're trying to save some money on calibration - they could always calibrate them once in a blue moon and document that as the plan.
Scott.Hilton
Normzone,
I've always been involved with a philosophy that those are exceptions to the rules of inspection when no other options are available. I understand spring calipers get used at some places in ID grooves etc., however that is when another tool simply was not available to do the job. Using a tool that is actually meant to be calibrated as a transference method seems to introduce variability to an inspection process for no other reason than to save some bucks in calibration.
Maybe it is because I have been on a more tightly monitored side of the industry that has already adapted automotive and semiconductor industry practices and am now more exposed to the big equipment side. I guess maybe I will have to learn to loosen my parameters a bit, but that concerns me.........because these products directly relate to environmental and human safety, which is how I always want to view what is best when validating products meet design intent.
normzone
Well, I'd be curious about the reliability of the measurements. From what you describe the feature must be a bore, since if it was a groove the inside mic could not be removed to perform the transfer operation. And it must not be too deep, since the hand can only get such a tool in so far.
Measurements of such features are heavily dependent on skill. If the person doing this is good, I'll put money on the data being within a few tenths of the actual. If the person performing the measurement is not skilled or is running short on give-a-damn, it won't matter what tool they use or if it's calibrated or not.
It sounds as though one of those three point bore gages would be the most user friendly and reliable method, and it would only be one tool to calibrate.
Michael_M
Using an inside micrometer and then transferring it to an OD micrometer is the typical practice I followed for years (when I made parts big enough to use an ID micrometer). I never trusted the inside micrometer enough to use it as the actual measurement device. On a hole size with a tolerance of .003-.005 (total tolerance I assume not +/- .003-.005) I would be willing to accept the transfer. I might tighten up the tolerance a bit (and if I was performing the measurement I would tighten up).
Are you having quality issues with the supplier? Do you have any specific purchase order clauses that restrict this type of measurement? If no to these questions, I would not pursue it. If yes to these question then you have someplace to start.
normzone
[Michael M] - I don't understand your statement. No matter how you approach it, you ARE using the inside micrometer as the actual measurement device. You're just choosing to obtain your readout from another separate device.
blargon
Slightly beside the point, but does your supplier have a good calibration procedure in place to calibrate the OD mics with gauge blocks?
Eredhel
Quality Manager
Is it maybe a language issue? It's common for us to use telescoping gages and dial bore gages, both of which are measured to an OD mic at each reading. To the question about the standard, if I'm not mistaken as long as the tool is measured to a verified tool then it's ok. But we calibrate our ID mics and there aren't nearly as many ID mics as other measuring tools so I'm wondering if it's something else going on.
normzone
The dial bore gages I'm familiar with are set to nominal off of a gage block stack with end blocks in a holder, then the reading is taken from the dial on the bore gage. Why would one use an OD micrometer over that device when it contains a readout mechanism of it's own?
Eredhel
Quality Manager
We have mic stands instead. We just lock an OD mic into the measurement we want and keep it on a stand for checking dial bores and telescoping gages.
G Filling out inspection report using calibrated pins Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D Calibration of Pin Gages using a Calibrated Caliper that measures to 4 decimal places General Measurement Device and Calibration Topics 15
H "Internal Calibration" using other Calibrated Equipment Calibration Frequency (Interval) 13
M Inhouse Calibration of Regulated Power Supplies (RPS) using calibrated Multimeter General Measurement Device and Calibration Topics 7
D ASTM E-18 - We test our rockwell tester using calibrated test blocks General Measurement Device and Calibration Topics 3
D Interesting Discussion Using "Not A Calibrated Device" or "No Calibration Required" stickers General Measurement Device and Calibration Topics 63
M Any alternative method instead of using GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 26
R Using RPN to Confirm Risk Reduced to an Acceptable Level Risk Management Principles and Generic Guidelines 12
P Comparing Two Test Variables Using Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
J Using real time shelf life study as accelerated ISO 13485:2016 - Medical Device Quality Management Systems 1
C Clinical Trial using Prototype devices (EU MDR & ISO 14155) EU Medical Device Regulations 4
J Using an online software to maintain your QMS Quality Assurance and Compliance Software Tools and Solutions 7
S Process Monitoring using SPC software Quality Assurance and Compliance Software Tools and Solutions 6
R Using Scrapped NC items for training Medical Device and FDA Regulations and Standards News 15
M What is the Risk of Using Obsolete Versions of C=0 & ANSI/ ASQ Z1.4 Sampling Plans? ISO 13485:2016 - Medical Device Quality Management Systems 8
F Using non-randomized clinical study for change in existing 510(k) device? US Food and Drug Administration (FDA) 1
J Using MD on a flight EU Medical Device Regulations 9
K Using Google Drive/Docs ISO 13485:2016 - Medical Device Quality Management Systems 16
J What risk to cover when NOT using ISO 17025 accredited/certified labs for calibration ISO 17025 related Discussions 3
T Poisson regression using Minitab Statistical Analysis Tools, Techniques and SPC 3
T Using NICE for guidance during CER CE Marking (Conformité Européene) / CB Scheme 0
T Using Review articles from Pubmed for CER CE Marking (Conformité Européene) / CB Scheme 8
Tagin Using a meme generator to poke fun at quality Funny Stuff - Jokes and Humour 2
D Finding Optimum Design Parameters using Taguchi method? Using Minitab Software 2
V MSA - Using a R&R study for a Tape Measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
D Using electronic lab notebooks in the design control process ISO 13485:2016 - Medical Device Quality Management Systems 3
M Using a Non Certified vendor Supplier Quality Assurance and other Supplier Issues 8
H Using/Selling power banks with your product as a "mobile version" CE Marking (Conformité Européene) / CB Scheme 3
cgaro62 Using internal audits as part of document reviews Document Control Systems, Procedures, Forms and Templates 21
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
M MSA angle issue - Nylon parts using Aberlink 3D Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 20
J Using of CE marking - Two CE markings on the product CE Marking (Conformité Européene) / CB Scheme 5
R Using R package to implement Bayesian phase I/II dose-finding design for three outcomes ISO 13485:2016 - Medical Device Quality Management Systems 6
S Defibrillator Protection applicability When using Multiple applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Using Zinc Plated Steel in a Cleanroom Other Medical Device Related Standards 3
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
rerusk1 MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
