Using Customer Unit as Reference Standard
E
EMacP
Can someone help me to answer this question....
Currently my reference standard is send out for external calibration. Currently in hand I have a same model from one of my customer which I had just completed the calibration. Is there a possibility I can convert my customer's unit as my standard so that I can use it to calibrate another customer unit? If yes, what considerations do I have to follow? :confused:
G
George Weiss
You are asking an out of the box question, so here is an answer of same.
I have seen it done, that a device or material was temporarily tagged for identification purposes with a company ID, (your company equipment/material ID tag), and all normal documentation, including a file in your standards cabinet. The tagging was only for the moment, so the tag number never made it to a label on the standard. The temporary standard is now controlled as any other of your company’s standards, and their records. The customer’s calibrated item is evaluated as to it’s ability to perform the next calibration, meaning an uncertainty/specification analysis was done. Desireably a 4:1 TUR/TAR is present. A 1:1 TUR/TAR can be used in some cases where DUT bias is reported, and charted in normal course of calibration. A use-with-data-report-provided statement on CERT.
My opinion is that this is a poor idea, but is not excluded as an option.
You should consider discussing this with the customer who is getting his item tested with another customer’s standard. A written understanding would limit future issue(s)
A general comment would be, which is repeated in your quality procedures/manuals: "Write what you do, and do as you write"
You ask could I, and not should I. I hope this helps.
tbsiva
I feel its a bad idea of referring one customers model as reference standard... If u can do like this, the purpose of reference will be lost.........After sometime, u will compromise urself to use any calibrated model as reference std..
harry
From the practical and business aspect, doesn't make sense but from the traceability angle, why not? - provided the traceability chain is complete and properly computed and carried out.
E
EMacP
Thank you for the reply. This will not have happened when 2 of my standards have to be send for repair and cal at the same time. That is the reason I am checking whether this method can be used. I agreed abt the TUR/TAR 4:1 ratio and also the uncertainty of the standard. If using customer's unit is a not a good idea, isn't it the same if I loan a standard from company that do loaning service of instrument, making sure that the standard is calibrated with valid measurement report?
tomvehoski
What are the actual units that you and your customer are using? IIRC, ISO 17025 requires traceablity to SI units. If you are using kg and your customer is using pounds (lb) then I don't see much of an issue as there is a simple converstion (lb = kg * 2.2).
If you are using meters and your customer is using his shoe size, then you have a problem as there is no way to establish a conversion factor.
Jerry Eldred
I believe all of the previous answers have covered the topic details. In simple terms, I believe you should not use a customer's instrument to calibrate a different customer's instrument. However, as was answered above, there are circumstances where you require creative methods to properly calibrate instrument.
There are many things that it is better not to do, but it is acceptable with restrictions. I believe the restriction should be that you receive written permission from both customers, that the reference standard you use must be the exact model as the normal one you usually use or have equivalent specifications, and the certification must meet the same criteria as your original.
I believe your qualiy manual/policy should also include a policy on how to do this. If it does not include this, you may want to consider adding it. And for traceability, assign a temporary unique identification where you can maintain the certificate for the customer's instrument in your quality records.
On numerous occasions, I have used a customer's instrument, but it was always for the same customer, not for a different customer. That to me is the questionable detail.
I also would not do it if this was for an ISO17025 accredited calibration under any circumstances. This is because the ISO requires the standard to be under the control of the laboratory.
I think I h ave probably repeated much of what was already said.
tomvehoski
Ignore my post above. I read unit = unit of measure, not unit = piece of equipment.
Since you have not had control of the customer unit since it was calibrated, I would not trust it as a calibration standard. Even if you have a certificate for it that is traceable to the proper standards, how do you know it was not dropped, adjusted, broken, etc?
SteelMaiden
And, if your customer quits doing business with you, you no longer have the standard. Can you, probably. Should you, probably not. I think even if a customer sent a standard for our use, I'd still double check it with one of our own calibrated standards, where I have complete traceability.
Big Jim
From an ethical perspective, why not ask the owner of the equipment if they would do you a favor and let you use it to calibrate another customer's piece of equipment.
Depending on your relationship, how helpful you have been, and other circumstances not know by us, they just may be willing to be helpful. They may appreciate your initiative to ship the other customer's piece on time, and believe you would show the same devotion to them.
Make sure you have the traceability records you need though.
G How to assess Customer Satisfaction without using surveys ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
R Customer using their own version of the AIAG PPAP Forms APQP and PPAP 5
ScottK Using Customer Audits as part of the Internal Audit Plan for ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A Marketing Survey Analysis of Customer Surveys using Minitab Using Minitab Software 1
J Using 3 Basics to find Position - Customer says to use the X, Y and Z Basics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
Ajit Basrur Anyone using Net Promoter Scorecard (NPS) to Measure Customer Loyalty? Misc. Quality Assurance and Business Systems Related Topics 4
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
R MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
C Importer shell game - Using a third party logistics provider (3PL) in the EU EU Medical Device Regulations 5
S Work performed in Canada on US patients using US device Canada Medical Device Regulations 1
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R Clause 7.7 Replicate, Recalibration and Intermediate checks using Artifact ISO 17025 related Discussions 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
A Using Arduino based sensors for Poke-Yoke Manufacturing and Related Processes 6
M Using your Manufacturer's ISO certification ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
A Hospital IT expectations for connected medical device using WIFI Medical Information Technology, Medical Software and Health Informatics 0
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
J Class 1 Medical Device - Using a UPC over the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
M Raw stock material testing discrepancy using an XRF (x-ray fluorescence) analyzer Manufacturing and Related Processes 7
Z Using FMEA for Knowledge Management FMEA and Control Plans 6
