Using Inspection Instructions to Modify Drawing Requirements
Mgoul
We buy plastic cylinders with an outer diameter of 10.000" - 10.005". Our supplier fails to meet this requirement about 30% of the time. However, the parts rarely measure outside the range of 9.998" - 10.007". As long as the material does fall within the 9.998" - 10.007" range we are always able to accept it as nonconforming.
Rather then modify the drawings, the component engineer for these parts keeps attempting to modify our inspection instructions to allow for the discrepancies.
We measure the OD in 4 places on each end using calipers. If any one of these 4 measurements is out of spec then the parts go into our nonconforming material review process. The component engineer wants to modify our inspection instruction to state that if the average of the 4 measurements meets the 10.000" - 10.005" then the parts are acceptable without issue and without documenting the discrepancy.
I need help making my case against this practice. I have argued it every way that I can think of and I'm not getting through. So please, lend your expertise to this issue and help me build a case or if you disagree, please tell me your side so that I can reconsider my position.
Obviously, the orthodox way to proceed is to determine what works (assuming that the cylinder must fit around or inside of something else) and change the specifications accordingly. Your engineer seems to understand that the specification is "broken," but might be trying to following the path of least resistance in fixing it. The only acceptable alternative (in my mind) would be to add the inspection instructions (or explicit reference to them) to the drawing. This involves changing the drawing, of course, which might be what the engineer is trying to avoid.
Having had some considerable experience with plastics I can understand the frustrations for both you and you supplier in meeting such a tight tolerance.
I guess the first question is who has control of the Drawing. Is it your company or customer drawing. I worked for a company that used almost ALL customer supplied drawings and these can be dvilishely hard to get changed sometimes.
If the Drawing is an in house drawing, then why is engineering so reluctant to change it??
Next question. How thick are the walls of the tube? How flexible? How flexible is it? How is it mounted on the product. How much "Out of Round" is acceptable.
If it is fairly flexible then an average might be an acceptable way to measure this. If it is not flexible then an average is no good since measurements could exceed a usable dim but still average out.
Bottom line on this is that The compnent Drawing IS part of your inspection instructions and it is the part of the instructions that needs changed if at all possible.
Peace
James
Mgoul
You are exactly on point Jim. Thank you for your prompt reply.
Unfortunately, the engineer is unwilling to change the drawing. We have had this argument many times regarding this part as well as several others with similar situations. I won't bore you with all of his reasons but I will share my favorite one; the one that made my head turn purple (and I quote):
1) "I don't want to change the drawing because then the supplier will start making the parts even worse and then I won't be able to accept the N/C parts for use in production!"
I apologize to all the good, quality-oriented people here on the forums for putting that last statement in this thread. I'm sure some of your heads are purple right now as well.
MIREGMGR
Is the component engineer arguing for only an averaging spec? So if they delivered a distorted part that measured 9.500", 9.750", 10.255", 10.505" at one end, that would be OK with the component engineer?
An averaging process would not be metrologically sound. It wouldn't even make common sense, as it would allow gross deviations as long as they average out.
If it were a conditional/secondary spec, applied only to parts that fall outside of the all-measurements-10.000"-to-10.005" primary spec but within the 9.998"-to-10.007" fallback spec, it in fact would give a different result in regards acceptable parts. A part that was 9.999", 10.000", 10.000", 10.000" would not meet the conditional spec as stated, even though per your description it sounds as if right now such a part would be passed by your material review process.
As suggested above, you need a primary (and only) spec that expresses what you require, and for which the supplier and your incoming inspection can have a common understanding of acceptable/non acceptable that is final.
Among other things, your current process must be having a negative impact on the quality culture at your supplier, since they're able to ship 30% of production to you that doesn't meet spec but does meet your requirements.
I think this is a good point. You're inviting cognitive dissonance (the unsettling feeling one gets when trying to hold disparate points of view simultaneously) when you say, on the one hand, that "quality" requires conformance to specifications and on the other hand say, "well, sometimes it does" when the specifications are wonky.
bobdoering
Stop X-bar/R Madness!!
Well, what is the supplier's response to the inability to meet the purchase order requirements? We have not heard that part of the story yet.
Beyond that point, using the average for a diameter is the weakest form of specification twisting. It has no meaning whatsoever. Min, max, true position, some functional approach has much more merit than a statistically insignificant piece of data as the average diameter.
What the engineer is likely saying is that he doesn't know exactly what will work and what won't, and can't be bothered to try and figure it out. In fairness to the engineer though, I've seen situations where "the system" is at least partially responsible for the phenomenon--the process for changing a drawing is too complex and slow, and the engineer is overloaded to begin with and has to resort to slapping band-aids on everything just to keep his head above water.
This sort of thing is one reason that it's good to have a formal engineering-change-request process. You should be able to submit a request in a situation like this, explaining the problem (and its potential for negative effects) and a proposed solution. The request should be initially reviewed at a level higher than the offending engineer (the engineering manager, e.g.) and that person should be ultimately responsible for deciding the course of action. Your situation is the type of thing that inevitably happens when engineers are left to their own devices (pun intended).
bobdoering
In fairness to the engineer, I have seen the average scam used before - and the approached approved by customers. So, even the customer can be complicit in not knowing exactly what will work and what won't, and can't be bothered to try and figure it out.
MIREGMGR
50% of the posts I make here are way off base in one direction, and the other 50% are way off base in the other direction...but on average I'm perfect. :)
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
John Predmore What size pinhole can be reliably detected using visual inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
B Gage R & R on Visual Inspection using the Cross Tabulation Method IATF 16949 - Automotive Quality Systems Standard 4
W Eliminating Paperwork using Inspection Stamps AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
G Filling out inspection report using calibrated pins Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K FAI (First Article Inspection) using Digital Design Data AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Q Success or failures using Quality inspection services in China Quality Manager and Management Related Issues 2
I Supplier Using Reference Part for PASS/FAIL Inspection Supplier Quality Assurance and other Supplier Issues 8
R Thread Inspection - Using go/no-go gaging to inspect threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
ScottK Using Lean techniques to speed First Article Inspection Lean in Manufacturing and Service Industries 13
Z Inspection of Flatness of a part using an electronic device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Using AQL to get true random sampling using General Inspection Level II AQL - Acceptable Quality Level 4
E Share experiences using a contract agency to perform source inspection Misc. Quality Assurance and Business Systems Related Topics 5
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
R MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
C Importer shell game - Using a third party logistics provider (3PL) in the EU EU Medical Device Regulations 5
S Work performed in Canada on US patients using US device Canada Medical Device Regulations 1
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R Clause 7.7 Replicate, Recalibration and Intermediate checks using Artifact ISO 17025 related Discussions 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
A Using Arduino based sensors for Poke-Yoke Manufacturing and Related Processes 6
M Using your Manufacturer's ISO certification ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
A Hospital IT expectations for connected medical device using WIFI Medical Information Technology, Medical Software and Health Informatics 0
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
J Class 1 Medical Device - Using a UPC over the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
