Using Minitab to do 6 Sigma Studies
amiuda
HI,
I really need help on Minitab to do 6 sigma studies.
Does someone can kindly share any PDF about Minitab & Six Sigma?
reynald
How about visiting their site: Minitab.com?
You can get several examples from there.
David-D
It would also help to specify what tools/techniques you are trying to use. Minitab is good at many, such as Statical Process Control, analysis of process capabilities, doing DOEs, and creating fishbone (Ishikowa) diagrams. It is a not good at identifying and scoping a project, getting management support, or selecting tools.
David
L
lord85
I attached an old version of guide to minitab.
I hope It will be helpful for you.
  • R&S_General_Guide_Minitab_0202_V3.zip
T Poisson regression using Minitab Statistical Analysis Tools, Techniques and SPC 3
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
J Including Repeats in DoE using Minitab Using Minitab Software 5
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
Y Using Minitab's ifelse command Using Minitab Software 1
B Measurement Uncertainty using Minitab Measurement Uncertainty (MU) 2
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Using Minitab 17's Stepwise Regression to Predict Feature Using Minitab Software 2
C Hardness Testing - Low Cpk's using Minitab Misc. Quality Assurance and Business Systems Related Topics 10
L Automate GR&R using Minitab on complex, multi-measurement assemblies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Please help to analyze Response Surface Methodology by using Minitab 16 Using Minitab Software 6
K Gage R on a 10 Piece Sample with a CMM using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S D-optimal Designs using Minitab Using Minitab Software 6
A Minitab - Using the INSERT command to copy-paste text from and to a worksheet Using Minitab Software 6
A Copy-Paste in Minitab using Session Commands Using Minitab Software 5
D The correct way to analyze Skewed Data using Minitab Using Minitab Software 3
S Using Minitab for Multinomial Logistic Regression Using Minitab Software 2
M Using Minitab to Compute & Compare the Mean and Standard Deviation Amount Using Minitab Software 7
Proud Liberal Minitab - Organizing a large number of graphs using file details Using Minitab Software 5
E Center Point Residuals on a Factorial Design using Minitab Quality Tools, Improvement and Analysis 3
M Experimental Design at Nested Gage R&R using Minitab 16 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Gage R&R without Operators (using Sensors) using Minitab Using Minitab Software 2
J Taguchi Analysis using MiniTAB Using Minitab Software 1
C Analyzing 3 Factors 3 Levels using Minitab Using Minitab Software 9
V Sample Range for a valid GRR using ANOVA in Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Taguchi DOE (Design of Experiments) example using Minitab Using Minitab Software 3
T Counting the Average Times of Alarms in a Process using Minitab Using Minitab Software 5
Z Using Sum Values for Category Data in Minitab Using Minitab Software 4
V Using Taguchi method in Minitab for Coil Winding Application Using Minitab Software 11
V How to calculate Machine Capability Study using Minitab Using Minitab Software 4
S Pulling Data In Real Time From Excel using Minitab 15 Using Minitab Software 2
M Using the Johnson Transformation in Minitab Six Sigma 1
T 4 Factor Optimization using Minitab Using Minitab Software 7
M Insert Empty Column Using Minitab Macro Using Minitab Software 2
M To find the Optimum Parameter Setting using Minitab (Doing DOEs) Using Minitab Software 18
S Process Capability questions - Calculating Cpu using Minitab Six Sigma 6
B Using Minitab for Chi Square using Weighted Cases Using Minitab Software 2
B Plotting Probability Exceedance using the Probability Plot Graph in Minitab Using Minitab Software 4
A Marketing Survey Analysis of Customer Surveys using Minitab Using Minitab Software 1
P Taguchi's Analysis using Minitab 16 Using Minitab Software 25
P Taguchi method using Minitab - DOE (Design of Experiments) Help Quality Tools, Improvement and Analysis 7
O Sales Forecasting by Using Time Series Decomposition [Minitab] Using Minitab Software 4
B Minitab Gage R&R using Defect Count per Unit Area Using Minitab Software 1
E Gage R&R or Anova two way? Using Minitab Using Minitab Software 1
T Process Capability Analysis Binomial or Normal using Minitab 15 Using Minitab Software 54
K Reproducibility between different lots using minitab Using Minitab Software 1
U How to filter out responses from Minitab - Questionnaire using a 5 point likert scale Using Minitab Software 3
D Control limit calculation (Xbar R charts) using Minitab Statistical Analysis Tools, Techniques and SPC 14
