Interesting Discussion Using "Not A Calibrated Device" or "No Calibration Required" stickers
DAHSR
Registered Visitor
What are the rules for using "Not A Calibrated Device" or "No Calibration Required" stickers? When would you use such a label? Would every tool that exists in your facility that is not calibrated required to be identified with a "Not A Calibrated Device" or "No Calibration Required" sticker?
In our Machine Shop we use wrenches, torque wrenches, pliers, files, screwdrivers, hammers, allen wrenches, socket wrenches, etc. Do these need to be identified with a "Not A Calibrated Device" or "No Calibration Required" sticker?
Wesley Richardson
Wes R
No sticker would be required on items like wrenches, pliers, files, screwdrivers, hammers, allen wrenches, socket wrenches. These are not used to perform a measurement.
Calibration is required for torque wrenches, screwdrivers that have an adjustable torque value, feeler gauges, micrometers, calipers, steel scales, thread ring and thread plug gages, etc., if these affect the quality of your product.
For our clocks on the wall, I put a sticker "Calibration Not Required." However if that same clock is used to time a process, such as heat treating, then I would calibrate the clock, or provide a different means of timing for the operator, such as a calibrated stopwatch, calibrated chart recorder, etc.
Be cautious with the "Not Calibrated" and "Calibration Not Required" stickers, however. If you place this on a micrometer, and then it is used to measure a dimension on your product, it creates two problems. 1. It would be an audit deficiency if found, and more importantly, 2. if it is not calibrated, you really have no idea what that dimension actually is.
Wes R.
DAHSR
Registered Visitor
CALIBRATION & TOOLS
The use of a torque wrench in this application is not used to measure, verify or record data, is not a customer requirement, does not affect product quality and is not used to accept or reject product. Does any of this matter? Does the fact that I have an "adjustable" tool within the four walls of my facility require that tool be calibrated or identified as not requiring calibration.
In the summary about wall clocks and a sticker "Calibration Not Required." Is every piece of time displaying equipment in your facility labeled with "Calibration Not Required" like the wall clock in the cafeteria or each employees wrist watch or your computer monitor display?
Hershal
Metrologist-Auditor
Look at it logically (yeah, I know, that is outside the ISO realm at times).....the late Phil Stein phrased it best.....if the measurement matters, calibrate the equipment.....if the measurement does not matter, why make it?
Put another way, if you are making a measurement that matters to your device or product, calibrate the measuring device. If the measurement does not matter enough to calibrate the instrument, then why make the measurement at all? Now, use some common sense.....wooden rulers are an example of an item that should never be calibrated without some real specific reason.
As for NCR stickers, Wesley is right.....be careful with them.....use them only where you need them, not on things like pliers and hammers.
Hope this helps.
Hershal
Al Rosen
That was the point I was trying to make in my first post, but my sarcasm was wasted.
Charles Wathen
Involved - Posts
We have a Calibration Assessment form that is completed by the person requiring calibration. On this form, the Engineer has to answer some basic questions to help them determine if calibration is truly required or not, such as the logic that Hershal mentioned. If it's determined that calibration is not required, then we issue a Calibration Not Required label. If calibration is required, then we have to complete section B of our form that details the mfg's specs, our calibration ratio and measurement uncertainty, and a calibration procedure that has to be generated.
Dave Dunn
Regarding items such as the hammers, pliers, etc., those wouldn't fall under calibration requirements as they are not measuring and test equipment, nor are the forces that they apply to products or tooling measurable or adjustable in application.
On the other hand, a torque wrench as mentioned, or for another example an adjustable air hammer might need to be calibrated, depending on the requirements of the process. It's not so much the type of tool, but the application that it's used for that dictates whether calibration is required. If a fastener simply needs to be fastened, use a screwdriver. If it needs to be fastened to a specific torque, use a calibrated torque screwdriver.
QChas
Involved - Posts
Save the stickers!
In our tooling shop each toolmaker has his own gages. Rather then going to the expense of calibrating every tool, we identified a set of company tools used for accepting product. This way the toolmaker does what he has always done until he is "finished". Then he records the results with the company calibrated gages making note of the gage # used in the inspection. Our QMS states that "only gages with stickers on our master gage list require calibration". Saved a lot of money and kept everyone happy.
So when do the toolmakers' gages get calibrated? Is there a requirement for it? It's certainly possible to skirt the letter of the standard and use loopholes to avoid making good sense, but the fact is that gages need to be calibrated on a regular basis, regardless of who they belong to.
S Using Calibrated OD mic over non-Calibrated ID mic for final dimension Manufacturing and Related Processes 17
G Filling out inspection report using calibrated pins Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D Calibration of Pin Gages using a Calibrated Caliper that measures to 4 decimal places General Measurement Device and Calibration Topics 15
H "Internal Calibration" using other Calibrated Equipment Calibration Frequency (Interval) 13
M Inhouse Calibration of Regulated Power Supplies (RPS) using calibrated Multimeter General Measurement Device and Calibration Topics 7
D ASTM E-18 - We test our rockwell tester using calibrated test blocks General Measurement Device and Calibration Topics 3
M Any alternative method instead of using GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 26
R Using RPN to Confirm Risk Reduced to an Acceptable Level Risk Management Principles and Generic Guidelines 12
P Comparing Two Test Variables Using Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
J Using real time shelf life study as accelerated ISO 13485:2016 - Medical Device Quality Management Systems 1
C Clinical Trial using Prototype devices (EU MDR & ISO 14155) EU Medical Device Regulations 4
J Using an online software to maintain your QMS Quality Assurance and Compliance Software Tools and Solutions 7
S Process Monitoring using SPC software Quality Assurance and Compliance Software Tools and Solutions 6
R Using Scrapped NC items for training Medical Device and FDA Regulations and Standards News 15
M What is the Risk of Using Obsolete Versions of C=0 & ANSI/ ASQ Z1.4 Sampling Plans? ISO 13485:2016 - Medical Device Quality Management Systems 8
F Using non-randomized clinical study for change in existing 510(k) device? US Food and Drug Administration (FDA) 1
J Using MD on a flight EU Medical Device Regulations 9
K Using Google Drive/Docs ISO 13485:2016 - Medical Device Quality Management Systems 16
J What risk to cover when NOT using ISO 17025 accredited/certified labs for calibration ISO 17025 related Discussions 3
T Poisson regression using Minitab Statistical Analysis Tools, Techniques and SPC 3
T Using NICE for guidance during CER CE Marking (Conformité Européene) / CB Scheme 0
T Using Review articles from Pubmed for CER CE Marking (Conformité Européene) / CB Scheme 8
Tagin Using a meme generator to poke fun at quality Funny Stuff - Jokes and Humour 2
D Finding Optimum Design Parameters using Taguchi method? Using Minitab Software 2
V MSA - Using a R&R study for a Tape Measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
D Using electronic lab notebooks in the design control process ISO 13485:2016 - Medical Device Quality Management Systems 3
M Using a Non Certified vendor Supplier Quality Assurance and other Supplier Issues 8
H Using/Selling power banks with your product as a "mobile version" CE Marking (Conformité Européene) / CB Scheme 3
cgaro62 Using internal audits as part of document reviews Document Control Systems, Procedures, Forms and Templates 21
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
M MSA angle issue - Nylon parts using Aberlink 3D Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 20
J Using of CE marking - Two CE markings on the product CE Marking (Conformité Européene) / CB Scheme 5
R Using R package to implement Bayesian phase I/II dose-finding design for three outcomes ISO 13485:2016 - Medical Device Quality Management Systems 6
S Defibrillator Protection applicability When using Multiple applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Using Zinc Plated Steel in a Cleanroom Other Medical Device Related Standards 3
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
rerusk1 MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
