Interesting Discussion Using "Not A Calibrated Device" or "No Calibration Required" stickers
#51
I'm composing a "calibration not required" memo and I plan of referring to the accuracy required justifies that no calibration is needed. We have aluminum rulers used in measuring fabric and straps. The rulers did not come with a manufacturers certificate of tolerance. The tightest tolerance is 1/2" of the items being measured. Isn't this a case of true "Calibration not required" AND a reason to take the measurement?
In a similar way, I use a form to document the reasoning behind "Calibration Not Required" and justify individual or families of equipment - for example process equipment gauges which indicate the presence of (oil) pressure.
Helmut Jilling
Auditor / Consultant
#52
You could do that and some auditors would accept it. But, there would always be an audit trail and a discussion about, "Are you sure it is only measuring something with a 1/2" tolerance?" I mean, even 2x4 lumber has tighter tolerance than that. And, tape measures can be off. I had a recent situation where I was working with a handyman on my closet, and the measurements I made were a 1/8" difference than the measurements he made with his tape. So, it can happen.
Perhaps a simpler and more effective solution would be to buy a 3 or 6 foot steel ruler, have it verified, tape it down on a table, then use it as a master to verify all your other rules and tapes. That way they are verified, you have records, and there is no debate during audits. Simple, elegant solution.
hogheavenfarm
#53
I agree. How do you even know if your ruler is good to 1/2". It should be, but "should be" and what it "actually is" are different. I would want to see some kind of validation that would document that the ruler is valid to use. A master somewhere would do the trick nicely. Get a 12" (or any size) strip of steel and use a calibrated gage to measure it, and done. Just check your rulers against that. No need to "calibrate" them to it, just validate they indicate the correct measurements.
#54
As calibration is nothing more than comparison to a "master" source, what you're suggesting is calibration. The act of calibration doesn't imply that adjustment is necessary or possible. The type of calibration being suggested introduces traceability issues, so nothing is really being gained by doing it in a situation where it appears that any form of calibration won't add any value. Doing something to avoid the wiles of an incompetent auditor isn't helpful either.
hogheavenfarm
#56
I am suggesting calibration as a "one time" item. Thus "validation" prior to use. If someone brought in one of those "fisherman rulers", you know the type that 1" is really half an inch, the measurement could be off "per the ruler".
We validate rulers here, once, then label them "reference only", and "validate if damaged".
This is for items that are non critical (better define that), or items that will be inspected again further down the line. This way, there is a documented record that the equipment being used is at least looked at for suitability. Is it unnecessary? That depends on your customer/auditor. Do I do things for the auditor, NO, but management does.
Ninja
Looking for Reality
#57
Seems a good place to repeat my post from a while ago re rulers...no stickers required ('cause they're a PITA)
See my post here...on this thread topic...
Just contact the manufacturer of the ruler, get the goods, and be done with labels on rulers altogether...
#58
Call it "validation" if you want to, but it's still calibration. I'm a bit behind on ISO 9001, but in the 2008 version (7.6) it says this:
Where necessary to ensure valid results, measuring equipment shall
a) be calibrated or verified, or both, at specified intervals, or prior to use, against measurement standards traceable to international or national measurement standards; where no such standards exist, the basis used for calibration or verification shall be recorded (see 4.2.4)...
(My emphasis)
Assuming this is unchanged or substantially the same in the current version, the organization gets to determine when calibration is necessary, not the auditor.
BlytheRP
#59
Maybe the group can help me with this one: I wrote a nonconformance for a new machine that had not been validated via our change control process (requirement). This equipment also had a dial indicator. The other 3 older machines had calibrated dial indicators. The corrective action says that calibration of the dial indicator is not necessary because it does not make critical quality measurements and just used as a "guide." based on ISO 9001:2015 should this be the case?
eule del ayre
#60
Good Morning Sir BlytheRP, guide for what? if it's use as a guide, it's not valid saying that calibration of the dial indicator is not necessary 'cause you're saying that you use it as a guide, making it a reference in what you do.
S Using Calibrated OD mic over non-Calibrated ID mic for final dimension Manufacturing and Related Processes 17
G Filling out inspection report using calibrated pins Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D Calibration of Pin Gages using a Calibrated Caliper that measures to 4 decimal places General Measurement Device and Calibration Topics 15
H "Internal Calibration" using other Calibrated Equipment Calibration Frequency (Interval) 13
M Inhouse Calibration of Regulated Power Supplies (RPS) using calibrated Multimeter General Measurement Device and Calibration Topics 7
D ASTM E-18 - We test our rockwell tester using calibrated test blocks General Measurement Device and Calibration Topics 3
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
R MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
C Importer shell game - Using a third party logistics provider (3PL) in the EU EU Medical Device Regulations 5
S Work performed in Canada on US patients using US device Canada Medical Device Regulations 1
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R Clause 7.7 Replicate, Recalibration and Intermediate checks using Artifact ISO 17025 related Discussions 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
A Using Arduino based sensors for Poke-Yoke Manufacturing and Related Processes 6
M Using your Manufacturer's ISO certification ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
A Hospital IT expectations for connected medical device using WIFI Medical Information Technology, Medical Software and Health Informatics 0
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
J Class 1 Medical Device - Using a UPC over the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
M Raw stock material testing discrepancy using an XRF (x-ray fluorescence) analyzer Manufacturing and Related Processes 7
Z Using FMEA for Knowledge Management FMEA and Control Plans 6
