Using Ppk to set up Control Plans - Injection molding
james r
My company use's the process in from the injection molding machines to control the quality of the parts being made. During the new mold samples the process parameters are saved using the machine SPC. The SPC data is then used to come up with control plan limits. My problem with this is that we are using Ppk calulations during this process to justifiy that our limits are right. I say this is wrong becuase there are no USL/LSL for the process to calualte the Ppk against. I'm I right?
Re: Using Ppk to set up Control Plans
Hi James,
Welcome to the Cove :bigwave:
Being weekend, the response may be slow and your question may not be answered promptly. :)
Kales Veggie
People: The Vital Few
James,
Make sure, I understand you correctly.
USL/LSL = specification limits, usually from a customer drawing?
UCL/LCL = control limits?
Does the machine have a control algorithm build-in to the PLC?
Control limits are established from the inherent variation of your process and are independent from the specification or acceptance limits. You also must find out if the measurement system is suitable to control the characteristic. (if the measurement system is not good, you might be measuring noise only)
What is the characteristic that you want to control with SPC? It sounds that you are controlling a machine parameter (temperature or pressure or so)
james r
we collect spc on fill time, transfer pressure, zone one temp, cushion, and cycle time. There are no USL/LSL limits for thse settings. The real problem is that some of the limits that are put on the control plan seem to narrow (+/_ 50 psi) to hold in a molding operation resulting in a continuous weaking of the process when we get a new batch on material.
bobdoering
Stop X-bar/R Madness!!
You are correct, Ppk will have to relate to specifications you develop. These are your process parameters, and what you are looking for from the SPC is changes from the norm as a signal that something is wrong and action is needed. To do this, you need to understand your process (material, machine and molds, in particular) to develop the appropriate understanding of the relationships of fill time, transfer pressure, zone one temp, cushion, and cycle time to successful product manufacture. I bring this up because some of these things are interrelated, and some are independent. Many are affected by lot to lot material variation - so you do not want to set up your specs on one lot, only to have the next lot blow your specs away.
The answer to developing specifications for your process is a DOE (design of experiments) to find out how much variation of each parameter is acceptable for the desired output. I am not sure what zone 1 temp is - if it is barrel or mold, but I would have barrel, nozzle and mold temps (do you use cooling water? Add it, too) in the DOE. Be sure to use several batches of material, also.
No, this is not a three hour job - and you may not be up to it. But, I suspect it is the most correct answer.
Oh, wait...the most correct answer is "It Depends." :cool:
james r
Thanks for the help
Of all the machine settings the following are critical to monitoring the process. mat'l temp, transfer pressure, mat'l flow, and cooling. With the machine SPC we are able monitor the front barrel zone, xfer pressure, fill time and cycle time to control the critcals. A DOE would help to understand the relationship and interactions of these outputs. great idea!
What I need is a proof soucre to show that trying to us the Ppk does not suit our needs. Can you provide any help there.
One thing that you have not made clear is the origin of the spec limits used to calculate Ppk.
Reading between the lines, it appears that the SPC data may be used to establish the statistical parameters (mean and standard deviation). Some multiple of the the standard deviation (e.g., 4 or 5) are used to create tolerances that result in an acceptable Ppk, which is then used to justify the use of the tolerances. Is this correct?
If this is the process that you are using, then I would agree with you. These are definitely tolerances that the process is capable of meeting, but this does not assure that the final product meets requirements. In addition, the argument is a circular argument.
The correct approach is the one recommended by bobdoering. Perform screening DOEs that identify the critical process parameters that affect the final product quality. Then perform optimization DOEs or Response Surface DOEs that identify both the optimum target values as well as the tolerances required in the process parameters in order to meet the final product requirements.
Going even further you could perform robust experimental designs that help you identify levels that minimize variation. This could either be the Inner/Outer Array noise experiments popularized by Taguchi, or the more efficient Split Plot experiments (process factors are the whole plot, and noise factors are the subplot) advocated by Box. Note: the analysis of the Split Plot experiment is more complex. JMP can analyze a split plot experiment directly, but Minitab must be tricked into performing the correct analysis.
J Using Pin Gages as a Measurement Tool for Ppk/Cpk studies Capability, Accuracy and Stability - Processes, Machines, etc. 11
L Cp/Cpk vs Pp/Ppk (Short term using population sigma) - Formulas to use? Capability, Accuracy and Stability - Processes, Machines, etc. 21
D Ppk - Capability calculation using the estimated sigma calculated from the Rbar/d2 Capability, Accuracy and Stability - Processes, Machines, etc. 16
M Any alternative method instead of using GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 26
R Using RPN to Confirm Risk Reduced to an Acceptable Level Risk Management Principles and Generic Guidelines 12
P Comparing Two Test Variables Using Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
J Using real time shelf life study as accelerated ISO 13485:2016 - Medical Device Quality Management Systems 1
C Clinical Trial using Prototype devices (EU MDR & ISO 14155) EU Medical Device Regulations 4
J Using an online software to maintain your QMS Quality Assurance and Compliance Software Tools and Solutions 7
S Process Monitoring using SPC software Quality Assurance and Compliance Software Tools and Solutions 6
R Using Scrapped NC items for training Medical Device and FDA Regulations and Standards News 15
M What is the Risk of Using Obsolete Versions of C=0 & ANSI/ ASQ Z1.4 Sampling Plans? ISO 13485:2016 - Medical Device Quality Management Systems 8
F Using non-randomized clinical study for change in existing 510(k) device? US Food and Drug Administration (FDA) 1
J Using MD on a flight EU Medical Device Regulations 9
K Using Google Drive/Docs ISO 13485:2016 - Medical Device Quality Management Systems 16
J What risk to cover when NOT using ISO 17025 accredited/certified labs for calibration ISO 17025 related Discussions 3
T Poisson regression using Minitab Statistical Analysis Tools, Techniques and SPC 3
T Using NICE for guidance during CER CE Marking (Conformité Européene) / CB Scheme 0
T Using Review articles from Pubmed for CER CE Marking (Conformité Européene) / CB Scheme 8
Tagin Using a meme generator to poke fun at quality Funny Stuff - Jokes and Humour 2
D Finding Optimum Design Parameters using Taguchi method? Using Minitab Software 2
V MSA - Using a R&R study for a Tape Measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
D Using electronic lab notebooks in the design control process ISO 13485:2016 - Medical Device Quality Management Systems 3
M Using a Non Certified vendor Supplier Quality Assurance and other Supplier Issues 8
H Using/Selling power banks with your product as a "mobile version" CE Marking (Conformité Européene) / CB Scheme 3
cgaro62 Using internal audits as part of document reviews Document Control Systems, Procedures, Forms and Templates 21
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
M MSA angle issue - Nylon parts using Aberlink 3D Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 20
J Using of CE marking - Two CE markings on the product CE Marking (Conformité Européene) / CB Scheme 5
R Using R package to implement Bayesian phase I/II dose-finding design for three outcomes ISO 13485:2016 - Medical Device Quality Management Systems 6
S Defibrillator Protection applicability When using Multiple applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Using Zinc Plated Steel in a Cleanroom Other Medical Device Related Standards 3
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
rerusk1 MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
