Using the results from GR&R (Gage R&R) Analysis - One sided dimension
brahmaiah
#21
Re: Using the results from GR&R Analysis - One sided dimension
Here it is. Some company firewalls are overly paranoid.
Your xls. work sheet is showing only GRR against process variation.It does not mention the formula 100(Tol./6) which you have assumed,
Pl.ref.MSA Manual for clarification.
V.J.Brahmaiah
#24
Miner,
Thanks for the explianation, I have 1 more question.
When calculating the %GR&R against TV it is 100(R&R/TV)
When calculating the %GR&R against Tol it is 100(R&R/(Tol/6))
Why is the Tolerance divided by 6
There are a lot of equations floating around, and rather than tell you that they are wrong I am going to give you the MBB's favorite answer: "It depends".
AIAG started it when they revised the MSA manual from the 2nd edition to the 3rd edition. They decided to simplify the equation by changing how the 6 multiplier was used in the K constants and the formulae.
Bottom line: the change amounted to whether you used (6*StdDev)/Tol or StdDev/(Tol/6). The 6 was hidden in the revised K constants. Some spreadsheet equations stayed with the 2nd edition K constants and moved the 6 into the formula, so it got confusing.
Use the Ford MSA software validation data set to validate your spreadsheet, and there should be no concerns. If I have time later, I'll link to it, but you can also search for it within this forum.
swarbur4
#25
Thank you for all of your time and expertise, I have changed your worksheet for the honest GR&R and made it into a combined GR&R incorperating both MSA method and Wheelers. I have also changed to the Average and Range Method from Anova method for the calculations in Wheeler. I changed from Anova so I can better explian the steps to my colleagues
I know it needs some tidying up, but could you please take a look at it and tell me if you think the equations I have used are correct.
Simon
#26
I would be happy to review it. It may take a day or two, but I will get to it. I used the ANOVA to avoid the messy d*2 factors as well as adding the interaction.
M MSA 4 - Results of GR&R Study using Range & Average Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Marc Using Bing for Search? You're getting Google Search Results! After Work and Weekend Discussion Topics 10
E Adding value to audit using checklist & getting results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Using Certified Results from your Supplier - Chemistry report and Tensile results Supplier Quality Assurance and other Supplier Issues 12
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
R MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
C Importer shell game - Using a third party logistics provider (3PL) in the EU EU Medical Device Regulations 5
S Work performed in Canada on US patients using US device Canada Medical Device Regulations 1
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R Clause 7.7 Replicate, Recalibration and Intermediate checks using Artifact ISO 17025 related Discussions 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
A Using Arduino based sensors for Poke-Yoke Manufacturing and Related Processes 6
M Using your Manufacturer's ISO certification ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
A Hospital IT expectations for connected medical device using WIFI Medical Information Technology, Medical Software and Health Informatics 0
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
J Class 1 Medical Device - Using a UPC over the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
M Raw stock material testing discrepancy using an XRF (x-ray fluorescence) analyzer Manufacturing and Related Processes 7
Z Using FMEA for Knowledge Management FMEA and Control Plans 6
Sidney Vianna NASA to Develop a Novel Approach for All-Electric Aircraft Using Cryogenic Liquid Hydrogen as Energy Storage World News 2
S How many of you are using Robotic process automation for calibration lab management? ISO 17025 related Discussions 0
