V&V phase: Justification of acceptance criteria (statistical method ) - (Medical Device)
Hello !
I am working in a medical device start-up (developping an invasive device) and we are currently finishing our specification phase and drafting our V&V master plan, to define the necessary tests to proove our specifications are well achieved.
We are struggling with one our test, and more specifically with its associated criteria and I hope someone here could help us with this!
One of our specification is "the temperature raising of the medical device does not lead to safety issue".
As there is no published article/study regarding the impact on our environment (temperature level vs. the defined part of body), we don't have a specific temperature limit that can be justified with litterature (and as we are the first to develop this device, we also don't have any concurent to compare with!).
The management does not want us to define a critieria based on our R&D testing, meaning that we can't use a nominal value/targeted temperature value as a criteria.
So for now we have the following strategy:
We'd show that the temperature does not lead to safety issue by performing these two tests :
- Preclinical study on animals : criterion are linked to histological results
- Temperature repetability testing : to show all our devices reach more or less the same temperature in order to give credit to our preclinical study
My questions are the following :
1) Can we just use the criteria "the temperature range of all tested devices is +/-2°C" without giving any further justification ? I'm not at ease with that at all but other point of view would be helpfull...
2) Is there any statistic method that could make a "link" between the number of tested devices and the results obtained to show the temperature is repeatable enough, but without nominal value to refer to ?
I thought of the "UTL=Mean+k*s" but the criteria is usually related to a predetermined specification limit like UTL=Mean+k*s<=USL
And sadly here, we are asked not to use an USL ...
I hope it's clear enough!
Thank you in advance for your feedback !
Mhal2
In these situations, it is normal to perform characterization studies to gain the knowledge needed to define a specification.
Product specifications must have engineering level of detail and must have a clear pass/fail criterion unless it is absolutely not possible to do so. It seems to me that it would be fairly easy for you to define a specification. You could even do some testing using a meat product from the grocery store or just use general information like what is the proper temperature for a baby's bathwater. Also, there has to be information regarding heat effect on tissue in the literature somewhere.
It is not clear to me how the repeatability would be related to safety. I think for safety you would be concerned only with the temperature values over time. Your spec should be something like, "Device temperature shall be less than or equal to xx degrees over xxx period of use."
Also, you need to know what "safety issue" you are trying to prevent. This is where your risk analysis comes in.
P 21 CFR 58 GLP Periodic Study Phase Inspection Report Other US Medical Device Regulations 0
R Using R package to implement Bayesian phase I/II dose-finding design for three outcomes ISO 13485:2016 - Medical Device Quality Management Systems 6
B 3-phase supply, overvoltage catogory, line-to-neutral and working voltage (IEC 61010-1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M Definition of Done - New Product Phase to the sustaining phase Manufacturing and Related Processes 3
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
K Product (Device) Life cycle - Product Life AFTER the Post Market Phase Medical Device and FDA Regulations and Standards News 3
M What to do in SOP Phase of Head unit testing? IATF 16949 - Automotive Quality Systems Standard 0
S Uncertainty Budgets - Phase Noise (SSB), Harmonics Measurement Uncertainty (MU) 2
K APQP Phase 3 - Team Feasibility Commitment APQP and PPAP 3
R Plan to Volvo Cars for capacity verification in Phase 3 of PPAP Customer and Company Specific Requirements 3
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
H IVD in US Phase III Clinical Trial - Non-CE Marked and Non-FDA Approved Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
A Power Traceability certificate for values for voltage, current and phase General Measurement Device and Calibration Topics 1
K TS 16949 Planning Phase: Raw Materials purchased from Distributer and the PPAP impact IATF 16949 - Automotive Quality Systems Standard 3
S Could Phase III Clinical Trials be taken without Phase I and II ? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
R Class III Medical Device Qualification in Phase 2? Qualification and Validation (including 21 CFR Part 11) 2
V How to Assess Process Capability at the Development or Optimization Phase Capability, Accuracy and Stability - Processes, Machines, etc. 6
V What Ford Phase PPAP Level should DV testing be submitted? APQP and PPAP 1
M Should we analyse risk at the quotation phase or after the order is received? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Raw Parts Inspections for NPI (New Product Introduction) Phase Supplier Quality Assurance and other Supplier Issues 1
K Task and Sub Tasks of Software Life Cycle Phase Quality Assurance and Compliance Software Tools and Solutions 1
J Project Management - "Quality Check" at each phase of a Project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Comments Required Regarding a Software Requirements Phase Tool Design and Development of Products and Processes 3
G Single Fault Condition for 3-Phase Medical System - IEC 60601 Clause 8.1b IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
V Measurement of Robustness of Product at Development Phase Six Sigma 2
M Excel Templates for Plan & Define Phase in NPI Process for Tire Manufacturer Excel .xls Spreadsheet Templates and Tools 1
D Phase 2 Revision to AS 9100 Rev C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R How to determine the reference voltage for three-phase transformer? IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
C Sub-Supplier compliance to Ford Phase 0 PPAP (Run at Rate) APQP and PPAP 3
V Should Feasibility be done in the APQP phase - TS 16949 Clause 7.2.2.2 IATF 16949 - Automotive Quality Systems Standard 2
K MSA (Measurement System Analysis) on Multi-Phase Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A Renault Quality plan - Quality Plan in Development Phase for Renault customer Design and Development of Products and Processes 4
D How to collect customer complaints/dissatisfactions during development phase? Customer Complaints 6
T Quality tasks for each Design Control Phase ISO 13485:2016 - Medical Device Quality Management Systems 4
V 5 Phase Correctice Action examples wanted Quality Tools, Improvement and Analysis 3
Q Phase 2 Audit - OFI for Supplier Performance and Monitoring IATF 16949 - Automotive Quality Systems Standard 3
Q TS 16949 Phase 1 Requirement Question IATF 16949 - Automotive Quality Systems Standard 2
R Change Control Required? Changes during the product gamma phase IATF 16949 - Automotive Quality Systems Standard 3
C Six Sigma Project - Using FMEA in the Analyze Phase Quality Manager and Management Related Issues 6
D How to practically-conduct, post production phase ISO 13485:2016 - Medical Device Quality Management Systems 1
M Phase 7 Procedures for a Managerial Consultation Company Service Industry Specific Topics 7
N Which SDLC (Systems Development Life Cycle) phase does Quality Assurance Participate Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Need help understanding Ford's Phase 0 PPAP APQP and PPAP 1
M Signatures Requirements for Design phase documents Design and Development of Products and Processes 3
S Why historical data & benchmark data is important in APQP planning phase APQP and PPAP 6
B Examples of APQP - Phase 1 & 2 APQP and PPAP 2
D Deming Cycle PDCA - The Check phase clarification, please Quality Tools, Improvement and Analysis 2
P AS 9100 - Initial Phase Audit - Certified with Majors or Minors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
S Can anyone provide APQP Timing Plan including Phase 5.0 APQP and PPAP 3
K We Passed Our Ts16949 Phase 1 Readiness Review IATF 16949 - Automotive Quality Systems Standard 1
