Validating Custom adaptations of Medical Devices
I work for a medical device manufacture that brings in 80% finished product that is custom fit to clients. We do the final assembly and this "Custom" work. Some of this work is routine (make a piece 2" shorter) some does involve custom bending of sheet stock and welding. I can't possibly cover every adaptaion in the MDR. I do cover every adaptation in the DHR. I'm not sure this is enough to satisfy validation for this change. Any comments on this will be very helpful.
As far as what needs to be changed think of someone with partial use of their right hand. Some people can use 2 fingers some 3 and so on, we have to accomodate all of these but can not anticipate or test every iteration.
G
Gert Sorensen
Re: Custom adaptation
I moved your post to this forum, where we might get some more useful input.
Do you need to cover it? Is it possible for the MDR to document the product to stage X, and then let the DHR cover it from stage X to Y? If it were described in your system how you organize it, then this might be a possibility. I would consult my Notifying Body on things like this to get their input.
Why would you validate this? What is the rationale behind that decision?
Al Rosen
Could this be similar to contact lenses or dentures? I wonder what someone would do in that situation?
Al Rosen
There is no Notified Body in the US, only FDA.
:jawdrop:
Thanks for moving the thread.
I had not thought about dentures, it is kind of the same idea.
As far as validation goes I mean our product is tested in certain configurations (think seat belts in a car). If I change the mounting location for these I can't show a new test report for the change. Be mindful that I made the change because the client can't use the device unless I make the change.
I can show a trail through the device history file. What I'm not sure about is if that is enough of a trail back to the MDR.
G
Gert Sorensen
I do not see the need for validation in this case. IMO you need to test the individual custom made pieces thorougly to make sure that the piece will perform as expected by the customer (given the fact that it is custom made I am guessing protesis?). The normal interpretation is that you need to validate a process if you can not feasably verify the outcoming result. Usually it would need to be a repetitive process. In this case I think that you should consider recording and proving your employees ability to perform the task at hand: Welding, bending etc. to ensure that the outcoming result will be satisfactory. Aditionally you could/should have some defined criteria for the performance of the produced item, and you should verify that these have been met.
Have you considered contacting FDA for guidance on the requirements for the documentation in these kinds of matters?
Al Rosen
:topic: Who approves and gives certifications under ISO or QS then??
The OP was in the FDA forum before you moved it to the ISO 13485 forum. The OP made references to terms MDR (I assumed from the context that he meant DMR) & DHR (here I thought he meant DHF for Design History File not Design History Record). These are common to FDA. Notified Bodies are more concerned with the Technical File rather than DMRs, DHFs and DHRs.
Thanks for the input. I was out sick for 2 days so I have not looked at the forum. I meant to put DMR in the 1st post. Which is the Device Master Record. This is the procedures and specs for the device. The DHR is the Device History Record which is all of the records that show the device was made in accordance with the DMR.
I've been doing some research on the dentures and I think this may lead me down the correct path. I don't have it in front of me so I can not cite the reference but I will post it some time today.
Thanks to all.
sanjoh
Is the "Custom" built to a prescription from a Physician?
N Validating Software before getting approved as Class 2 device US Food and Drug Administration (FDA) 5
Ed Panek Validating Excel (XLS) formulas 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
A Validating my own application developed with Agile Qualification and Validation (including 21 CFR Part 11) 5
T Risk analysis of QMS software - Validating software we use for QMS ISO 13485:2016 - Medical Device Quality Management Systems 5
H Validating Nondestructive leak testing machine Qualification and Validation (including 21 CFR Part 11) 3
S Validating a Bonding Process Qualification and Validation (including 21 CFR Part 11) 3
M FDA's expectation for validating OTS software updates Other US Medical Device Regulations 8
R Re-validating revised Medical Device and Aerospace Product COTS software ISO 13485:2016 - Medical Device Quality Management Systems 2
J Validating a stopped test due to never finding any defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Validating multiple injection molding machines efficiently ISO 13485:2016 - Medical Device Quality Management Systems 5
J Grouping Products and Testing Sterile and Biocompatibility - Validating Products Other Medical Device Regulations World-Wide 3
G Validating a Process Based on Lot Release Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Meeting the Requirement of Clause 7.5.2 on Validating Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Validating a Product through Tool Control and Tool Inspections Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
G Validating a Sandblasting Process - Any pointers? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
G Testing and Validating a New Vertical Milling Machine AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Q Validating Tape Measures used to Measure Product Conformity to Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Protocol for Validating Pull Tester and Force Gage Qualification and Validation (including 21 CFR Part 11) 9
T Validating Supplier Statement - Rusty shield that supplier denied responsibility Manufacturing and Related Processes 7
M Validating 3rd Party Software which Tracks Archived Samples Qualification and Validation (including 21 CFR Part 11) 2
Q Validating ESD (Electrostatic Discharge) Flooring ISO 13485:2016 - Medical Device Quality Management Systems 2
M Procedure for Validating Laser Marking & Electropolishing of Orthopedic Implants Other Medical Device and Orthopedic Related Topics 13
Q Validating the AOI process (Automated Optical Inspection) Reliability Analysis - Predictions, Testing and Standards 9
K Validating a gage/fixture in-house under TS 16949 - Need information General Measurement Device and Calibration Topics 2
C Validating a Gage R&R spreadsheet - Defining Formulas in spreadsheet cells Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G Software Validating Adobe Professional according to Part 11? Quality Assurance and Compliance Software Tools and Solutions 10
D Validating software in materials testing - Integrated system of individual components General Measurement Device and Calibration Topics 3
D Validating Multimeters (how to) General Measurement Device and Calibration Topics 8
E Configurable/Custom made or accessories? EU Medical Device Regulations 0
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
K Usability for custom made medical devices IEC 62366 - Medical Device Usability Engineering 5
A Registration requirements for custom branded device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
J Iterative design and production for custom made products ISO 13485:2016 - Medical Device Quality Management Systems 3
J Validity / outcomes measure for custom made medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
I Custom software services to be used by medical software ISO 13485:2016 - Medical Device Quality Management Systems 1
J Custom made medical devices - Wheelchairs EU Medical Device Regulations 6
T Custom made medical device MDD vs MDR definition CE Marking (Conformité Européene) / CB Scheme 12
M Informational ANVISA regulation for personalized/custom medical devices – RESOLUÇÃO – RDC Nº 305, DE 24 DE SETEMBRO DE 2019 Medical Device and FDA Regulations and Standards News 0
M Custom Medical Device For Clinical Study Other Medical Device Regulations World-Wide 1
B Sterilization of a custom medical device Other Medical Device and Orthopedic Related Topics 1
D Medical device development - Custom test equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
J Custom-made implants (Class IIb) and pre-commercialization clinical trials in Spain EU Medical Device Regulations 4
C If it's not a custom-made medical device... What is it? Clinician requests EU Medical Device Regulations 11
R Custom Records and Quality Systems - Products that change frequently Other US Medical Device Regulations 3
T Requirements and standards for medical custom Electrical Connectors EU Medical Device Regulations 2
W Product or Service? Custom Engineered Capital Equipment Manufacturer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Medical device procedure tray - Adding products in Custom packs Other Medical Device and Orthopedic Related Topics 3
J ISO 9001:2015 - Clause 8.3 - Design in the Custom Manufacturing industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K DoC (Declaration of Conformity) for Custom Made Medical Devices EU Medical Device Regulations 1
