Validation Method Requirements - 21 CFR Part 820
biogic
#11
Hi Ronen,
Sorry for the confusion, the document I was referring too was in another response.
My frame of reference for method validation relates to the verification activities that we use during our process validation and ongoing process monitoring. In other words, how do we validate the tests that we use to validate our product and processes?
Perhaps their are no guidances specifically written for our circumstance and your suggestion of using the guidance provided for drugs and biologics would be prudent.
rjhill
#12
I work at a medical device company. We use no analytical test methods, we build electro mechanical devices. However, we have been challenged by FDA on this topic. My experience with them is that the expectation is that we have proof that our "test methods/test procedures/measurements" produce reliable answers. We have taken this to mean the test procedures
(test methods) we use to collect data, whether a measurement as part of a design verification test, a measurement used in process validation, or a measurement performed on the product at final QC, need to produce an answer that is reliable.
In my opinion, most of our measurements are direct (physical dimensions, tensile force, electrical resistance) and can be performed with general lab equipment designed for that purpose. These are calibrated so the accuracy, precision, bias... sections of TMV are taken care of. When we are using them in a way they were not intended - like using the resistance of a fluid to determine the purinty of fluid - the calibrated instrument may be accurate, but where is the proof that the purity of the fluid is being reliably determined? This is what TMV would provide.
Now, if we are using a piece of test equipment that we designed in house, we must now verify all the elements of TMV.
One other element we review for apparent straightforward measurements is if it is easy for the person performing the measurement to influence the result. Example, the operator's ability to use an optical comparator for precise measurements in a room with no ability to reduce the ambient light - how consistently can he repeat his measurements, and can they be be replicated by another person using the same optical comparator? Gage R&R (a part of TMV) can take care of this.
Because to the lack of guidance we have endless discussions on this topic; Quality Engineering leans toward TMV on every measurement, Product Engineering leans towards only doing a TMV on custom measurement equipment.
From consultants I have spoken to on this subject - be able to defend you test measurement results. That is, if you did not perform a TMV - why not?
biogic
#13
Thank you for relaying your experience and some great advice.
Much appreciated
Sybarite
#14
With regard to your specific question. If you modify the method, you should have at least qualified that using a different instrument does not impact the accuracy or precision of the assay.
Food for thought.
To the OP, this is probably your easiest solution. Your reagent/kit manufacturer will have certain claims around linearity, precision, accuracy, etc... and the burden to prove that those claims are reproducible with your custom method lies with you.
If you are using less than the method's full range, or require less precision/accuracy for your purposes, then you can design a validation or verification that proves your custom method at least satisfies your needs, if not meets the original method's full claims.
The take-home message is that ALL methods that are used for verification/validation/acceptance must be validated methods, whether the manufacturer or the end user conducts the validation.
Hope this helps.
rjhill
#15
My company interprets the CFR as any "test" that is used to make a quality decision needs validated (testing involves measurement or qualitative assessment). Therefore formal verification tests, QC tests, QC cosmetic assessments, and measurements made as part of process validation are all measurements or assessments that need validated.
L ISO 17025 Para. 5.4.5 - Method (Calibration Procedure) Validation Requirements ISO 17025 related Discussions 2
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
R Please share your method used for PEMS Validation IEC 62304 - Medical Device Software Life Cycle Processes 5
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
F Irradiation Sterilization Validation Maximum Dose - VDmax 25 method (ISO 11137) EU Medical Device Regulations 2
P Test Method Validation for Tensile Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
P Production Line Pump Cleaning Validation Method Question Qualification and Validation (including 21 CFR Part 11) 0
A Risks related to Method Validation and Stability Studies Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
S Test Method Validation or MSA for Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Test Method Validation on Elongation Machine General Measurement Device and Calibration Topics 0
C Cotton Swab Method Validation for clean uniforms, bins and poly bags Other Medical Device and Orthopedic Related Topics 4
J Attribute Test Method Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Effect of Fixtures on Test Method Validation Design and Development of Products and Processes 1
E Validation of Method(s) in Testing Laboratories General Measurement Device and Calibration Topics 9
K Validation of an Analytical Method that relies on Multi-Variate Calibration General Measurement Device and Calibration Topics 7
V Pharmaceutical Analytical Method Validation and Gauge R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
K Do we need to perform Analytical Method Validation upon Relocation? General Measurement Device and Calibration Topics 5
S ANOVA and Test Method Validation for a Drug Delivery Device Statistical Analysis Tools, Techniques and SPC 4
A Writing a Procedure for Validation of an Analytical Method General Measurement Device and Calibration Topics 5
S Medical Device Mechanical Test Method Validation Design and Development of Products and Processes 8
S Writing a Test Method Validation Procedure as well as Validation of Test Methods General Measurement Device and Calibration Topics 1
V The approach/criteria of setting Acceptance Limits Method Validation Parameters Statistical Analysis Tools, Techniques and SPC 1
L Method for Poka-Yoke (Mistake Proofing) Validation prior to SOP APQP and PPAP 6
B Mojonnier method (determining fat and total solids) validation General Measurement Device and Calibration Topics 1
B Handling, Storage and Distribution - Package Validation Test Method Options? US Food and Drug Administration (FDA) 7
N Design validation challenges - Suggestions for an effective validation method Qualification and Validation (including 21 CFR Part 11) 5
S Method Validation for qualitative tests (specifically Absence/Presence) General Measurement Device and Calibration Topics 2
A Training slides on Method validation & Traceability needed General Measurement Device and Calibration Topics 1
S Test Method Validation Help - New titration test method, not defined in the USP Qualification and Validation (including 21 CFR Part 11) 2
J Test method validation on raw materials, intermediates and final device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
T Anyone have an example of a calibration method validation procedure? General Measurement Device and Calibration Topics 4
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 2
C Spreadsheet Validation and Release Qualification and Validation (including 21 CFR Part 11) 2
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
M Sterile packing validation tests to be performed and protocol Other Medical Device and Orthopedic Related Topics 1
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
C ISO 19227 Validation Cost Other Medical Device Related Standards 2
A CNC Mill and Lathe - Validation Manufacturing and Related Processes 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
B Oracle Cloud ERP Validation during Quarterly Patch ISO 13485:2016 - Medical Device Quality Management Systems 1
D Software validation team Misc. Quality Assurance and Business Systems Related Topics 3
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 2
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
